D67 Audio FUZZMITE problem
M.G.
Postby M.G. » Wed Jan 21, 2009 12:02 pm
I have a D67 Fuzzmite that is acting up - the footswitch will click on the fuzz, but it won't always click back to the straight signal. Sometimes it is there, but more often it is not. No signal at all. Faulty switch perhaps? Unfortunately I didn't buy the pedal direct and I don't have any contact info for the maker.
Re: D67 Audio FUZZMITE problem
Postby dubtrub » Wed Jan 21, 2009 12:09 pm
M.G. wrote:Faulty switch perhaps?
Most likely. That's where I'd start. ;)
Check all leads to the switch and back to thier origin.
Deke Dickerson
Postby Deke Dickerson » Wed Jan 21, 2009 1:17 pm
Replace the switch and if that doesn't fix it, PM me, I'll put you in contact with the guy you need to talk to.
M.G.
Postby M.G. » Wed Jan 21, 2009 1:21 pm
Thanks, Deke. Will do.
Postby Dennisthe Menace » Wed Jan 21, 2009 9:16 pm
M.G. wrote:Thanks, Deke. Will do.
Mike, also, check to make sure that there are not any wires that might be touching something that
they AIN'T suppose to be touching :mrgreen: . Believe it or not, that could also create those symptoms ;) .
M.G.
Postby M.G. » Wed Jan 21, 2009 9:36 pm
Thanks, Dennis - I'll check that out as well when I open it up again.
Postby Mr. Bill » Thu Jan 22, 2009 11:39 am
If you haven't tried it yet, clean the switch with some deoxit or some other contact cleaner. Sometimes the switch will gum up and not make contact, but it will usually respond to cleaning.
Postby oipunkguy » Thu Jul 01, 2010 6:25 pm
this forum is awesome. I have a similar problem with a pedal of mine, and it seems like a no brainer to hit the switch with a little contact cleaner and see if it helps. one of those moments where you say duh! why didn't I think of that?
Postby Dennisthe Menace » Thu Jul 01, 2010 7:23 pm
Aaron, we have all done that! (LOL) ;) .
Users browsing this forum: No registered users and 112 guests
