Mosrite Celebrity II models Serial Numbers List (1960s - 1970s, Hollow Body.)
Postby 101Volts » Thu Nov 30, 2023 2:33 pm
Thread Introduction:
Welcome to the Mosrite Forum Serial Numbers List for Mosrite Celebrity II Models. Either check this initial post, or go to the most recent post (or close to it) for the most recent update of the list. This is also not the first list for Celebrity models. You can find Sarah's List for all Celebrity models here at Archive:
https://web.archive.org/web/20140910013 ... age29.html
If you want to see the Mosrite Forum Serial Number Lists for either the Celebrity I or III, they are here:
Celebrity I:
viewtopic.php?f=6&t=8185
Celebrity III:
viewtopic.php?f=6&t=8184
Contributing to this List:
If you happen to own a Mosrite Celebrity II (the II model - not the I or III) of any type (6 string guitar, 12 string guitar, or bass) and would like to contribute information, I'll need info (and I'd also like pictures, if possible) of these areas:
1 - Pic of the front of the guitar.
2 - Pic of the back of the guitar (to show how the neck is attached - Mosrite usually had a neck plate for these, but sometimes had 3 or 4 screws with ferrules.)
3 - Pic of the sticker seen through the F-hole (if still present.)
4 - Pic of the Serial Number, which is stamped into the fretboard near the Neck Pickup (if the number is still present.)
5 - Pic of the headstock, front and top side.
6 - Pic of the headstock, rear.
7 - (Only applies to 6 String Guitars, unless there's somehow a 12 string with this tailpiece) - A pic of the Moseley Tailpiece, where it says "Moseley." Some of the tailpieces have a Patent Number, and I'd like to tell when that starts.
These last 3 are not absolutely necessary, but would also help:
8 - Pic of the Dates on the Potentiometers (if the pots are original.) They come in either Week-Year Format (so 45-66 would be in November 1966) or it's the reverse.
9 - Pic of the Neck Heel where it meets the body (if there's a date stamped, which probably doesn't exist past October 1966.)
10 - Pic of the Neck Pocket (if there's a date, again, which may not exist past October 1966.)
Model Specifications:
The Mosrite Celebrity II model is a Hollow Body Instrument with an F Hole. It has a Moseley Vibrato Tailpiece, a body that's 1 7/8" inches deep, and Pickups that do have pole pieces.
24.50" Scale Length (Guitar - 6 String & 12 String.)
30.25" Scale Length (Bass.)
Mosrite Single Coil Pickups (possibly with AWG 44 or 43 in the Guitar Pickups, and AWG 42 in the Bass Pickups.)
Body Wood:
I need to check this.
Neck Wood:
Maple with Indian Rosewood Fretboard.
Recent Updates:
2023:
November:
30th and 31st:
Started List.
Added:
Guitar M0182 - Dark Red.
December:
1st - Added:
6 Strings: M0015 (Sunburst,) M0295 (Red,) M0344 (Green.)
12 Strings: C0025 (Sunburst.)
11th:
More details added to M0182, M0295, and M0344.
28th:
M0375 added.
2024:
January:
17th:
Added this Bass:
N0052 - Sunburst, Neck Sunburst, Headstock Black. 3 Bolt Neck. --- https://reverb.com/item/68888624-mosrit ... 7-sunburst
April:
28:
M0126 (Sunburst) Added.
29:
M0337 (Green) Added.
September 30, 2025:
Added:
2DL105 - Honeyburst. Has a 4 bolt neck plate. https://reverb.com/item/85862376-1973-m ... _sold=true
Serial Number List:
Mark X (4 String Bass: )
Confirmed Numbers:
Strange Numbers Section:
None yet listed.
Partially Accounted For:
None yet listed.
Mark I (6 String Guitar: )
Confirmed Numbers:
M0015 - Sunburst, but a bit better looking? Neck Sunburst, Black Headstock. 3 Bolt (Ferrules) Neck. Kluson Deluxe (Metal Button) Tuners. Pot Codes are 1346651, BA811 3901. Guitar was posted on Reverb in 2011/2012.
https://reverb.com/item/7695-mosrite-ce ... 7-sunburst
M0126 - Sunburst. Found mentioned at the Facebook group "Mosrite Guitars," and it was for sale in Guitar Center. https://www.facebook.com/groups/5297862 ... 369657139/
M0182 - Dark Red. 2 piece 3 bolt (ferrules) neck with Kluson Deluxe metal button tuners. Owned by Drew Palmer.
https://www.facebook.com/groups/mosrite ... 735720709/
https://reverb.com/item/53238325-mosrit ... t-wine-red
M0295 (Number on Fretboard seems to be misprinted M03295.) - Red. 2 Piece 4 Bolt (Ferrules) Neck. Has "Diamond" Tuners. https://reverb.com/item/65190234-mosrit ... th-gig-bag
M0337 - Translucent Green. Has a weirdly shaped headstock. Tuners were replaced.
M0344 - Translucent Green. 2 Piece 4 Bolt Neck. Has "Diamond" Tuners. https://reverb.com/item/72854989-mosrit ... cent-green
M0375 - Unknown finish.
Partsrites with Wrong Necks:
H1212 - Red Finish. Wrong number prefix, this is from a Combo. The body is a Celebrity II or III looking body (albeit weird if it is one.) The neck has "Diamond Tuners" (right era for them as a partsrite,) the body has a Trapeze Tailpiece, the neck screws are Flatheads, the pickups aren't Mosrite Pickups, and the Neck Pickup Slot is angled when it shouldn't be if it was an official Celebrity II or III. There is also no potentiometer access plate. It's unclear if this is a Celebrity II or III body or something else.
Unknown & Unconfirmed Numbers:
None yet listed.
1970s 6 String Models:
Confirmed Numbers:
Deluxe model [has Mosrite Humbuckers:]
2cL052 - Red Burst, Red Burst Headstock. Has neck plate.
https://reverb.com/item/58420201-mosrit ... _sold=true
Mark XII (12 String: )
Confirmed Numbers:
C0025 - Sunburst. 3 Bolt Neck.
https://reverb.com/item/68393211-mosrit ... unburst-25
None yet listed.
Total Instruments Accounted For:
4 String Basses:
0 Known # 4 String Basses,
0 Partly Known # 4 String Basses,
0 Unconfirmed # 4 String Basses.
6 String Guitars:
1960s:
7 Known # Guitars,
0 Partly Known # Guitars,
0 Unknown # Guitars.
1970s:
1 Known # Guitars,
1 Partly Known # Guitars,
12 String Guitars:
1 Confirmed # 12 String Guitars,
0 Partly Known # 12 String Guitars,
0 Unknown # 12 String Guitars.
Total: 10 Instruments. 9 Confirmed Numbers, 1 Partial Number, 0 Unconfirmed.
Finishes & Variants Accounted For:
Sunburst
Reference Photo of a Celebrity II 6-String Guitar Model for Facebook Preview:
Re: Mosrite Celebrity II Serial Numbers List (1960s - 1970s.)
Postby 101Volts » Thu Nov 30, 2023 2:35 pm
Total Updates List:
2023:
November:
30th and 31st:
Started List.
Added:
December:
1st:
Added M0295 (Red) and M0344 (Green.)
Post reserved in case of future updates (2.)
Post reserved in case of future updates (3.)
Post reserved in case of future updates (4.)
Re: Mosrite Celebrity II models Serial Numbers List (1960s - 1970s, Hollow Body.)
Postby 101Volts » Sun Apr 28, 2024 8:59 am
Welcome to the serial numbers list for Mosrite Celebrity II Models. Either check this initial post, or go to the most recent post (or close to it) for the most recent update of the list.
If you want to see the serial number lists for either the Celebrity I or III, they are here:
Celebrity I:
Celebrity III:
Body Wood:
Neck Wood:
Recent Updates:
2023:
November:
30th and 31st:
Started List.
Added:
December:
1st - Added:
11th:
28th:
M0375 added.
2024:
January:
17th:
Added this Bass:
April:
28:
Serial Number List:
Confirmed Numbers:
None yet listed.
None yet listed.
Confirmed Numbers:
None yet listed.
Confirmed Numbers:
None yet listed.
Confirmed Numbers:
None yet listed.
4 String Basses:
6 String Guitars:
1960s:
6 Known # Guitars,
1970s:
0 Known # Guitars,
12 String Guitars:
Total: 8 Instruments. 7 Confirmed Numbers, 0 Partial Number, 0 Unconfirmed.
Sunburst
Users browsing this forum: No registered users and 203 guests
