Mosrite Celebrity (Pre-Numbers) & Celebrity I models Serial Numbers List (1960s - 1970s, Hollow Body.)
Postby 101Volts » Thu Nov 30, 2023 2:25 pm
Thread Introduction:
Welcome to the Mosrite Forum Serial Numbers List for Mosrite Celebrity & Celebrity I Models. Either check this initial post, or go to the most recent post (or close to it) for the most recent update of the list. This is not the first serial number list for Celebrity models. You can find Sarah's List for all Celebrity models here at Archive:
https://web.archive.org/web/20140910013 ... age29.html
If you want to see the Mosrite Forum Serial Number Lists for either the Celebrity II or III, they are here:
Celebrity II (1 7/8" deep, pickups with pole pieces, Moseley tailpiece.)
viewtopic.php?f=6&t=8186
Celebrity III (1 7/8" deep, smooth pickup covers, Trapeze stop tailpiece.)
viewtopic.php?f=6&t=8184
Contributing to this List:
If you happen to own a Mosrite Celebrity or Celebrity I (not the II or III) of any type (6 string guitar, 12 string guitar, or bass) and would like to contribute information, I'll need info (and I'd also like pictures, if possible) of these areas:
1 - Pic of the front of the guitar.
2 - Pic of the back of the guitar (to show how the neck is attached - Mosrite usually had a neck plate for these, but sometimes had 3 or 4 screws with ferrules.)
3 - Pic of the sticker seen through the F-hole (if still present.)
4 - Pic of the Serial Number, stamped into the end of the fretboard near the Neck Pickup (if still present.)
5 - Pic of the headstock, front and top side.
6 - Pic of the headstock, rear.
7 - (Only applies to 6 String Guitars, unless there's somehow a 12 string with this tailpiece) - A pic of the Moseley Tailpiece, where it says "Moseley." Some of the tailpieces have a Patent Number, and I'd like to tell when that starts.
These last 3 are not absolutely necessary, but would also help:
8 - Pic of the Dates on the Potentiometers (if the pots are original.) They come in either Week-Year Format (so 45-66 would be in November 1966) or it's the reverse.
9 - Pic of the Neck Heel where it meets the body (if there's a date stamped, which probably doesn't exist past October 1966.)
10 - Pic of the Neck Pocket (if there's a date, again, which may not exist past October 1966.)
Model Specifications:
Basic differences between "Pre-Number Celebrity" and "Celebrity I" models:
The Mosrite Celebrity model (that is, the pre-number system version) is a Hollow Body Instrument with an F Hole, a Moseley Vibrato Tailpiece, and Pickups that do have pole pieces. The 6 string guitar version's body is usually 2 7/8" inches deep, although some later versions are 1 7/8" deep. The neck on these pre-numbered versions is a 2 bolt with a tenon joint (not counting Basses, if those exist, as none are currently listed.) There's no access plate for the output jack, or the volume or tone controls; they are attached directly to the body.
The Mosrite Celebrity I model (introduced likely at the same time as the II and III models) also has a 2 7/8" deep body, but the neck is attached with more screws and it's not attached by a tenon neck joint. The output jack and knobs are on a plastic plate that can be unscrewed for easy access.
Specifications expected for both types:
24.50" Scale Length (Guitar - 6 String & 12 String.)
30.25" Scale Length (Bass.)
Mosrite Single Coil Pickups (possibly with AWG 44 or 43 in the Guitar Pickups, and AWG 42 in the Bass Pickups.)
Body Wood:
I need to check this.
Neck Wood:
Maple with Indian Rosewood Fretboard.
Recent Updates:
2025:
October 6, 2025:
Added:
A0??? - Red - May be one of the first 100, so this one's early which is why I put it in the list. It has a finish crack near the upper F Hole. Was on eBay in September 2025.
A0155 - Red, Red Burst Neck, Headstock Red Burst on Rear and Black on Front. Listed on Reverb around Late August - Early September 2025. --- https://reverb.com/item/92136804-mosrit ... ric-guitar
A0212 - Red, Red Burst Neck, Headstock Red Burst on Rear and Black on Front. Husk with a few parts, with finish in damaged condition. Showed up on Reverb in Late April - Early May 2025. --- https://reverb.com/item/89355930-projec ... ric-guitar
A0426 - Red, Red Burst Neck, Headstock Red Burst on Rear and Black on Front. Has some wear on edges of headstock. Showed up on Reverb around Late September - Early October 2024. --- https://reverb.com/item/83390805-1968-m ... a-red-ohsc
A0442 - Red, Red Burst Neck, Headstock Red Burst on Rear and Black on Front. Showed up on Reverb around Late September - Early October 2024. --- https://reverb.com/item/83640704-mosrit ... ginal-case
November 9, 2025:
Added:
A0053 - Red, Red Burst Neck, Readstock Red Burst on Rear and Black on Front. Showed up on eBay in October / November 2025.
March 11, 2026:
Added these "From Sarah's List," so I have no pics.
Basses - Five 2 Bolt Types, and one 3 or 4 Bolt Type:
L0006 - Burgundy - (F.S.L.)
L0035 - Red - (F.S.L.)
L0096 - Red - May have a thinner body - (F.S.L.)
L0097 - Neck only, put on guitar body A0641 - (F.S.L.)
L0162 - Sunburst - May have a thinner body - (F.S.L.)
LL0022 - Teal - "Square logo" (?) - (F.S.L.)
Guitars - Thirty Four.
A0001 - Sunburst
A0005 - Red - "Decopage/Tremolo" (?) - May be a thinner body than expected.
A0010 - Red
A0037 - Red - May have a thinner body.
A0057 - Red - May have a thinner body.
A0058 - Red - May have a thinner body.
A0081 - Sunburst
A01xx (Unclear digits) - Natural - Has P90 pickups and a Bigsby?
A0142 - Red
A0159 - Red - May have a thinner body. (F.S.L.)
A0168 - Sunburst - May have a thinner body. (F.S.L.)
A0172 - May have a thinner body. (F.S.L.)
A0184 - May have a thinner body. (F.S.L.)
A0209 - Red - May have a thinner body. (F.S.L.)
A0222 - Unknown Finish - (F.S.L.)
A0310 - Sunburst (F.S.L.)
A0329 - Sunburst (F.S.L.)
A0387 - Sunburst - May have a thinner body. (F.S.L.)
A0412 - Stripped - Mayhave a thinner body. (F.S.L.)
A0438 - Red - (F.S.L.)
Likely to be 1 7/8" body section but still with a 2 bolt tenon neck:
A0513 - Red - May have a thinner body. (F.S.L.)
A0533 - Sunburst - May have a thinner body. (F.S.L.)
A0540 - Sunburst - (F.S.L.)
A0577 - Sunburst - Tremolo/Block markers (F.S.L.)
Unclear Neck Type section:
A0600 - Sunburst (F.S.L.)
A0641 - Red - Has a bass neck L0097 (so it seems likely that this is still in the 2 bolt tenon neck department) (F.S.L.)
A0679 - Celebrity - Sunburst (F.S.L.)
A0741 - Celebrity-I - Sunburst (F.S.L.)
3 or 4 Bolt Neck:
A0809 - Celebrity-I (F.S.L.)
A0816 - Celebrity (F.S.L.)
A0832 - Celebrity-I - Sunburst (F.S.L.)
A0837 - Celebrity - Sunburst (F.S.L.)
A0848 - Celebrity-I - Natural (F.S.L.)
A0885 - Celebrity-I - Sunburst (F.S.L.)
Updates 2 and 3:
Added these:
A0665
A0801.
Serial Number List:
Before we start with any numbers, some instruments are marked as (F.S.L.) which means "From Sarah's List" which is found at the link below:
https://web.archive.org/web/20120222021 ... age29.html
Any instruments marked From Sarah's List (F.S.L.) are ones that I have no visual confirmation for unless they show up later, so I've placed them where they make the most numerical contextual sense, but the list may be a bit inaccurate to where each F.S.L. instrument ought to really be.
Mark X (4 String Bass: )
Confirmed Numbers:
Celebrity (Pre-Celebrity I)
Pre-Celebrity I models have a 2 bolt tenon neck, and no control knobs access plate under the knobs.
L0119 - Red, with Black Headstock. 2 Bolt Tenon Neck. Showed up on Facebook in Later September 2025. https://www.facebook.com/groups/5297862 ... 250417139/
L0139 - Red, with Black Headstock. 2 Bolt Tenon Neck. Maybe this one should go under another list, but for now, I'll put it here. https://www.facebook.com/groups/5297862 ... 779212139/
Celebrity I:
Celebrity I models are a continuation of the earlier models, but with 3 and 4 bolt necks and more finish varieties.
LL0004 - Red Burst. Has mini headstock tuners (known as "Duckfoot Tuners" but they're Mini Headstock Tuners.)
LL0008 - Blue. 3 Bolt Neck. Found on Facebook. https://www.facebook.com/groups/3294258 ... 597275893/
LL0009 - Natural. (Stripped?) - 4 Bolt Neck.
https://reverb.com/item/70590269-mosrit ... ral-blonde
Strange Numbers Section:
None yet listed.
Partially Accounted For:
None yet listed.
Mark I (6 String Guitar: )
(Note: I don't have body depths given for most of these. The thinner body depth for the Pre-Numbers Celebrity might have come earlier than I had expected.)
Confirmed Numbers:
Pre-Celebrity I ("Celebrity" model) with 2 Bolt Tenon Neck Joint and a Thicker Body Depth [2 7/8":]
A0001 - Sunburst - (F.S.L.)
A0005 - Red "Decopage/Tremolo" (?) - May be a thinner body than expected. (F.S.L.)
A0010 - Red - (F.S.L.)
A0037 - Red - May have a thinner body. (F.S.L.)
A0053 - Red, Red Burst Neck, Readstock Red Burst on Rear and Black on Front - Showed up on eBay in October / November 2025.
A0057 - Red - May have a thinner body. (F.S.L.)
A0058 - Red - May have a thinner body. (F.S.L.)
A0081 - Sunburst - (F.S.L.)
A01xx (unclear number) - Natural - Has P90 pickups and Bigsby. (F.S.L.)
A0142 - Red - (F.S.L.)
A0168 - Celebrity-II - Sunburst (F.S.L.)
A0212 - Red, Red Burst Neck, Headstock Red Burst on Rear and Black on Front. Husk with a few parts, with finish in damaged condition. Showed up on Reverb in Early 2025. --- https://reverb.com/item/89355930-projec ... ric-guitar
A0260 - Red, Headstock Red Burst on Rear and Black on Front. 2 Bolt Neck, No Control Plate. Belongs to Lec Tron. --- Update, May 6 2025: Put up for sale on Reverb at $1,200. https://reverb.com/item/87196699-1967-m ... reat-shape
A0222 - Unknown finish - (F.S.L.)
A0398 - Red (Refinished.) Headstock Red Burst on Rear and Black on Front. 2 Bolt Neck. Has Control Plate with seemingly not original extra switches.
https://reverb.com/item/70179485-1966-m ... y-time-red
A0412 - Stripped - May have a thinner body. (F.S.L.)
Later Pre-Celebrity I ("Celebrity" models) with 2 Bolt Tenon Neck Joint and a Thinner Body Depth [1 7/8":]
A0504 - The pickguard's smaller than A0260. Pots read "1346647" then "BA811-3901," dating to November 1966. "Helen" is written inside the guitar, and it also reads inside "1 of 2." This guitar is in terrible condition, and so the owner's parting it out - the top and back have wood splits and wood separation, the guitar had its paint badly "repaired," and the original finish was covered with another paint that reacted badly to the paint underneath it. Whoever painted it with clear coat even painted the fretboard and strings, they were horribly sloppy with it. They even put caulking on the guitar to attempt bonding the back and front back together.
A0515 - Red Burst, Headstock Black on Front with Red Burst on Rear. Parted out by GibsonDependable in Mid 2025, the new owner's at a Mosrite Group on Facebook and he put a Shade Tailpiece + Roller Bridge + Pickups on it.
A0540 - Sunburst - Could have a bigger body - (F.S.L.)
A0577 - Sunburst - Has block fretboard markers (Modified?) - (F.S.L.)
A0600 - Sunburst - (F.S.L.)
Unknown Body Depth Section:
A0641 - Red - Body only. Has a bass neck for L0097, so this is probably still a 2 bolt tenon neck - (F.S.L.)
A0665 - Red - Parted out by Gibsondependable. This one's still a 2 bolt tenon neck.
A0679 - Sunburst - (F.S.L.)
A0741 - Sunburst - (F.S.L.) May be 3 or 4 bolt neck, but it's not clear.
Celebrity I [Body of 2 7/8" Deep again] with 3 or 4 Bolt Neck:
A0800 - Natural. Showed up on Facebook, and it has a 4 bolt neck without a neck plate but with ferrules. String Guide not original.
A0801 - Red Burst. Parted out on eBay. 4 Bolt Neck.
A0809 - Unknown Finish - (F.S.L.)
A0816 - Unknown Finish - (F.S.L.)
A0832 - Sunburst - (F.S.L.)
A0837 - Sunburst - (F.S.L.)
A0848 - Natural Finish - (F.S.L.)
A0854 - Sunburst. Was for sale in Guitar Center in February / March 2025, found on Reddit. https://www.reddit.com/r/Mosrite/commen ... /#lightbox
A0879 - Blue. 4 Bolt Neck, and "Diamond" Tuners. https://www.facebook.com/groups/mosrite ... 553281452/
A0885 - Sunburst - (F.S.L.)
Unknown & Unconfirmed Numbers:
1970s Models:
Confirmed Numbers:
1c0004 - Red, Red Burst and Decorative "Foil" Headstock. Grover Tuners. "Banana" Control Plate. https://www.facebook.com/groups/9674777 ... 042366304/
1c0045 - Sunburst, Headstock Sunburst. Control plate is "Banana" Shaped. Seen in the comments here: https://www.facebook.com/share/p/14tpxRmbKV/
1c0086 - Sunburst. (F.S.L.)
1c0121 - Natural. (F.S.L.)
1c0146 - Natural. (F.S.L.)
1c0149 - Natural. (F.S.L.)
1c0187 - Sunburst. (F.S.L.)
1c0192 - Natural. (F.S.L.)
1c0197 - Honey Gold.
https://reverb.com/item/32770775-mosrit ... _sold=true
1c0199 - Honey Gold. 4 Bolt Neck Plate.
https://reverb.com/item/67162562-mosrite-gospel-1970s
1c0211 - Sunburst. (F.S.L.)
None yet listed.
Mark XII (12 String: )
Confirmed Numbers:
W0140 - Natural Finish, possibly stripped. Parted out. 3 Bolt Neck. --- https://reverb.com/item/84724835-mosrit ... _sold=true
None yet listed.
Total Instruments Accounted For:
4 String Basses:
7 Known # 4 String 2 Bolt Neck Basses,
4 Known # 4 String Later Neck Basses,
0 Partly Known # 4 String Basses,
0 Unconfirmed # 4 String Basses.
6 String Guitars:
1960s:
38 Known # (and speculated # from Sarah's list) 2 Bolt Tenon Guitars,
10 Known # 3 or 4 Bolt Neck Guitars,
0 Partly Known # Guitars,
0 Unknown # Guitars.
1970s:
11 Known # Guitars
1 Unknown # Guitars.
12 String Guitars:
1 Confirmed # 12 String Guitars,
0 Partly Known # 12 String Guitars,
0 Unknown # 12 String Guitars.
Total: 72 Instruments. 71 Confirmed Numbers, 0 Partial Numbers, 1 Unconfirmed.
Finishes & Variants Accounted For:
Sunburst
Reference Photo of a Celebrity I (or II) 6-String Guitar Model should be posted here for Facebook Preview. Both look similar. (I may change this photo later.)
Re: Mosrite Celebrity I Serial Numbers List (1960s - 1970s.)
This is the "Total Updates Tally" Reply for keeping track of which instruments were added, and when.
2023:
November:
30: Posted list without any instruments on it.
December:
1st:
Added A0260 - Red, with Headstock Black on Front and Res Burst on Rear. 2 Bolt Neck, No Control Plate.
10th:
Added:
1960s:
Bass LL0009 - Natural. (Stripped?)
Guitar A0398 - Red (Refinished.) Modified.
1970s:
Guitar 1c0199 - "Honey" Transparent.
11th:
1c0197 - "Honey" Transparent.
2024:
April 5 - Added Bass LL0008 in Blue. Found on Facebook.
May 10 - Added:
A0879 - Blue. 4 Bolt Neck, and "Diamond" Tuners.https://www.facebook.com/groups/mosrite ... 553281452/
May 13 - Added:
May 23 - Added:
A0504 - Strange guitar. The body is 1 7/8" thick in stead of the deeper depth, the pots read "1346647" then "BA811-3901," dating to November 1966. "Helen" is written inside the guitar, and also "1 of 2." This guitar is in terrible condition - the top and back have wood splits and wood separation, the guitar had its paint badly "repaired," and the original finish was covered with another paint that reacted badly to the paint underneath it. Whoever painted it with clear coat even painted the fretboard and strings, they were horribly sloppy with it.
2025:
January 19, 2025:
Added 1c0045 - Sunburst, Headstock Sunburst, "Banana" Control Plate. Seen in the comments here: https://www.facebook.com/share/p/14tpxRmbKV/
March 6, 2025:
May 3, 2025:
Added these from Sarah's list, linked below:
1c0086 - Sunburst.
1c0121 - Natural. Supposed to be a 1973 model.
1c0146 - Natural. Supposed to be a 1974 model.
1c0149 - Natural.
1c0187 - Sunburst.
1c0192 - Natural.
1c0211 - Sunburst.
Sarah's List:
https://web.archive.org/web/20131126050 ... age29.html
May 6, 2025:
A0260 was put up for sale. https://reverb.com/item/87196699-1967-m ... reat-shape
June 11, 2025:
LL0004 (Bass, Red Burst) Added.
August 6, 2025:
Added A0515 - Red Burst, Headstock Black on Front with Red Burst on Rear. Parted out by GibsonDependable in Mid 2025.
August 18, 2025:
Updated the model info at the start to make it more clear about distinction between Celebrity (pre-number system) and Celebrity I models.
August 31, 2025:
Corrected my errors of putting the Celebrity and Celebrity I models together without dividing them.
September 5, 2025:
A0515 - Red - Updated.
September 6, 2025:
A0515 - Red - Updated. It also has a 1 7/8" body.
September 29, 2025:
Added a Celebrity (2 Bolt Tenon Neck) Bass:
September 30, 2025:
Added:
October 6, 2025:
Added:
November 9, 2025:
Added:
Post reserved for future updates. (2.)
Post reserved for future updates. (3.)
Post reserved for future updates. (4.)
Re: Mosrite Celebrity I models Serial Numbers List (1960s - 1970s, Hollow Body.)
Postby 101Volts » Thu May 23, 2024 8:38 am
Welcome to the serial numbers list for Mosrite Celebrity I Models. There are few guitars on the list, yet.
If you want to see the serial number lists for either the Celebrity II or III, they are here:
If you happen to own a Mosrite Celebrity I (mind, the I model - not the II or III) of any type (6 string guitar, 12 string guitar, or bass) and would like to contribute information, I'll need info (and I'd also like pictures, if possible) of these areas:
The Mosrite Celebrity I model is a Hollow Body Instrument with an F Hole, a Moseley Vibrato Tailpiece, and Pickups that do have pole pieces. Its body is thicker than 2 inches, but I must double-check how deep it is.
Body Wood:
Neck Wood:
Recent Updates:
2024:
May 10 - Added:
May 13 - Added:
May 23 - Added:
Serial Number List:
Confirmed Numbers:
Celebrity (Pre-Celebrity I, but with the same body depth:)
L0139 - 2 Bolt Tenon Neck. Maybe this one should go under another list, but for now, I'll put it here. https://www.facebook.com/groups/5297862 ... 779212139/
Celebrity I:
None yet listed.
None yet listed.
Confirmed Numbers:
Pre-Celebrity I ("Celebrity" model) with 2 Bolt Tenon Neck Joint:
Deep Body:
A0260 - Red, Headstock Black on Front and Red Burst on Rear. 2 Bolt Neck, No Control Plate. Belongs to Lec Tron.
A0398 - Red (Refinished.) Headstock Black on Front and Red Burst on Rear. 2 Bolt Neck. Has Control Plate with seemingly not original extra switches.
Thinner Body (1 7/8": )
A0504 - Strange guitar. Pots read "1346647" then "BA811-3901," dating to November 1966. "Helen" is written inside the guitar, and also "1 of 2." This guitar is in terrible condition - the top and back have wood splits and wood separation, the guitar had its paint badly "repaired," and the original finish was covered with another paint that reacted badly to the paint underneath it. Whoever painted it with clear coat even painted the fretboard and strings, they were horribly sloppy with it.
Celebrity I:
None yet listed.
1970s Models:
Confirmed Numbers:
None yet listed.
Confirmed Numbers:
None yet listed.
None yet listed.
4 String Basses:
3 Known # 4 String Basses,
6 String Guitars:
1960s:
4 Known # Guitars (3 earlier "2 Bolt Tenon" type, 1 the more common neck type.)
1970s:
3 Known # Guitars
12 String Guitars:
0 Confirmed # 12 String Guitars,
Total: 10 Instruments. 10 Confirmed Numbers, 0 Partial Numbers, 0 Unconfirmed.
Sunburst
Postby 101Volts » Sat May 03, 2025 11:21 am
I added 7 Celebrity I models from the 1970s to the list, from Sarah's list (linked.)
Users browsing this forum: No registered users and 193 guests
