Mosrite Celebrity III models Serial Numbers List (1960s - 1970s, Hollow Body.)
Postby 101Volts » Fri Nov 24, 2023 4:22 pm
Thread Introduction:
Welcome to the Mosrite Forum Serial Numbers List for Mosrite Celebrity III Models (which have a 1 7/8" deep body, and the smooth cover pickups.) Either check this initial post, or go to the most recent post (or close to it) for the most recent update of the list. This is also not the first list for Celebrity models. You can find Sarah's List for all Celebrity models here at Archive:
https://web.archive.org/web/20140910013 ... age29.html
If you want to see the Mosrite Forum Celebrity I or Celebrity II lists, here they are:
Celebrity I (2 7/8" deep body, pole piece pickups.)
viewtopic.php?f=6&t=8185
Celebrity II (1 7/8" deep body, pole piece pickups.)
viewtopic.php?f=6&t=8186
Contributing to this List:
If you happen to own a Mosrite Celebrity III (mind, the III model - not the I or II) of any type (6 string guitar, 12 string guitar, or bass) and would like to contribute information, I'll need info (and I'd also like pictures, if possible) of these areas:
1 - Pic of the front of the guitar.
2 - Pic of the back of the guitar (to show how the neck is attached - Mosrite usually had a neck plate for these, but sometimes had 3 or 4 screws with ferrules.)
3 - Pic of the sticker seen through the F-hole (if still present.)
4 - Pic of the serial number, stamped into the end of the fretboard near the Neck Pickup (if still present.)
5 - Pic of the headstock, front and top side.
6 - Pic of the headstock, rear.
7 - (Only applies to 6 String Guitars, unless there's somehow a 12 string with this tailpiece) - A pic of the Moseley Tailpiece, where it says "Moseley." Some of the tailpieces have a Patent Number, and I'd like to tell when that starts.
These last 3 are not absolutely necessary, but would also help:
8 - Pic of the Dates on the Potentiometers (if the pots are original.) They come in either Week-Year Format (so 45-66 would be in November 1966) or it's the reverse.
9 - Pic of the Neck Heel where it meets the body (if there's a date stamped, which probably doesn't exist past October 1966.)
10 - Pic of the Neck Pocket (if there's a date, again, which may not exist past October 1966.)
Model Specifications:
The Mosrite Celebrity III model is the cheapest of the Celebrity models. It is a Hollow Body Instrument with an F Hole. Its tailpiece is normally a Trapeze style, but you could also buy it with the Moseley Vibrato Tailpiece.
24.50" Scale Length (Guitar - 6 String & 12 String)
24.50" Scale Length (Bass - yes, really, the Celebrity III Bass has the same scale length as the guitar.)
Mosrite Single Coil Pickups (possibly with AWG 44 or 43 in the Guitar Pickups, and AWG 42 in the Bass Pickups.)
Body Wood:
I need to check this.
Neck Wood:
Maple with Indian Rosewood Fretboard.
Recent Updates:
March 11, 2026:
Big update, adding 6 string models from Sarah's list to here.
K0012 (neck put on body of K0362 body)
K0027 - Sunburst
K0107 - Red
K0114 - Red
K0139 - Sunburst
K0163 - Sunburst
K0210 - Sunburst
K0277 - Unknown Finish
K0284 - Red
K0326 - Sunburst
K0362 - Sunburst
K0371 - Sunburst
K0420 - Red
K0426 - Red (had Gibson Pickups when Sarah documented this around 2010.)
K0500 - Sunburst
K0503 - Sunburst
K0522 - Sunburst
K0547 - Unknown Finish
K0574 - Red
K0650 - Sunburst
K0665 - Red - with Vibrato Tailpiece
K0720 - Sunburst
K0746 - Sunburst
K0772 - Sunburst - with Vibrato Tailpiece
K0777 - Sunburst
K0779 - Sunburst
K0833 - Burgundy Burst
K0834 - Red - with Vibrato Tailpiece
K0835 - Green - with Vibrato Tailpiece
K0842 - Burgundy - with Vibrato Tailpiece
K0846 - Burgundy - with Vibrato Tailpiece
K0854 - Burgundyburst - with Vibrato Tailpiece
K0909 - White
K0922 - Burgundy
K0948 - Unknown Finish
K1013 - Sunburst - Had Vibrato Tailpiece (missing.)
K1067 - Sunburst
K1078 - Sunburst
K1081 - Sunburst
K1095 - Red Burst - with Vibrato Tailpiece
K2004 - Green
K2029 - Green
K2031 - Red - with Vibrato Tailpiece
K2049 - Sunburst
K2145 - Unknown Finish
April 12, 2026:
Minor update to ST040; I previously had ST046 double-posted as ST040, so ST040 really was a Red one that Gibsondependable parted out in 2022 and its neck did not go on that specific Sunburst body.
1960s Serial Number List:
Mark X (4 String Bass: )
Confirmed Numbers:
Early Neck Plate Models:
Z0001 - Dark Red. This is so early that it has a neck plate. The sticker inside just says "Style: Celebrity," but it's still a Celebrity III. https://www.facebook.com/groups/5297862 ... 074922139/
Models with Ferrule Neck Construction:
Z0084 - Sunburst. 3 Bolt Neck.
https://reverb.com/item/75077908-mosrit ... 7-sunburst
Z0095 - Sunburst. 3 Bolt Neck. Found in France:
https://www.leboncoin.fr/instruments_de ... mRd9XThzzw
Z0106 - Faded Red. 3 Bolt 2 Piece Neck. Found on eBay, located in Japan.
Z0208 - Faded Red Burst (Orange Burst in most places.) - 3 Bolt 2 Piece Neck. Sold on eBay, then Parted out by Gibsondependable shortly after.
Z0326 - Red. 3 Bolt Neck.
https://reverb.com/item/74416237-mosrit ... -w-gig-bag
Z0337 - Blue. Neck converted to Fretless.
Z0354 - Natural Finish, according to the owner, so maybe it was stripped or maybe not. Doesn't have its original pickups but has Bill Lawrence Pickups, and the owner got it from the trash.
https://reverb.com/item/73301893-mosrit ... _sold=true
Z0457 - Red. 3 Bolt Neck. Either missing original pickups, or had Pole Piece Pickups installed at the factory. --- https://reverb.com/uk/item/63894583-196 ... y-usa-made
Z0511 - Green, 4 Bolt Neck. 2 Piece Neck. Showed up on F.B. Marketplace in Bakersfield, Jan 23 2024. Ad said the color was "1967 NAMM Show Green."
Strange Numbers Section:
None yet listed.
Partially Accounted For and Speculated Numbers:
Z026? - Sunburst. 3 Bolt Neck.
https://reverb.com/item/40536173-vintag ... e-sunburst
Mark I (6 String Guitar: )
Some of these say "F.S.L." at the end, which is a note that just means I got this number "From Sarah's List" at Sarah's archived Mosrite Celebrity fan site.
https://web.archive.org/web/20120222021 ... age29.html
Confirmed Numbers:
K0012 - Neck only. (Put on the body of K0362, listed below.) - (F.S.L., From Sarah's List.)
K0027 - Sunburst. (F.S.L.)
K0068 - Faded Red (Orange.) 3 Bolt, 2 Piece Neck. Tuners changed for Grovers. Found on eBay on 2024 Jan 17.
K0075 - Red. 3 Bolt, 2 Piece Neck. Had a Bigsby added. Found on eBay on 2024 Jan 17.
K0083 - Sunburst. Parted out, but the current owner has the neck and body.
K0095 - Red. 3 Bolt 2 Piece Neck. Parted out.
K0105 - Unknown. Mentioned in a thread in 2022.
K0107 - Faded Red (Orange.) (F.S.L.)
K0111 - Sunburst. Later showed up again at Guitar Center, then again some time later around October 12 2025 on eBay. Was documented by Sarah around 2010 - 2012, too.
K0114 - Red. (F.S.L.)
K0139 - Sunburst. (F.S.L.)
K0149 - Sunburst. 3 Bolt Neck, Black Headstock, Sunburst Neck. Original knobs missing, replaced with Tele style knobs. --- https://www.cashconverters.co.uk/shop/m ... fWdDUhpORQ
K0162 - Sunburst, Neck Sunburst.
K0163 - Sunburst. (F.S.L.)
K0180 - Sunburst, Neck Sunburst + Black Headstock. 3 Bolt Neck. Showed up on FB Marketplace.
K0210 - Sunburst. (F.S.L.)
K0232 - Sunburst. 3 Bolt Neck. Tuners, Frets, and Bridge replaced. https://reverb.com/item/80389415-mosrit ... s-vegas-nv
K0240 - Natural. 3 Bolt 2 Piece Neck, Kluson Plastic Knob Tuners. Strangely, this one's Pickguard says "{m} Mosrite California" on it.
K0268 - Red - 3 Bolt Neck, 2 Piece Neck. Pots date to 1966, according to the seller.
K0277 - Celebrity III? - Unknown Finish. (F.S.L.)
K0284 - Red. (F.S.L.)
K0326 - Sunburst. (F.S.L.)
K0330 - Sunburst, Neck Sunburst, 3 Bolt Neck. Has a Bigsby and Mosrite Roller Bridge added, and might read "Roy Clark" under the bridge and between the pickguard and control plate. So perhaps Roy Clark himself owned this one?
K0334 - Unknown Finish. Mentioned in a thread in 2020.
K0336 - Sunburst, Neck Sunburst, Headstock Black. 3 Bolt Neck. --- https://reverb.com/item/77448417-mosrit ... 7-sunburst
K0362 - Sunburst. (Has neck of K0012, listed above.) (F.S.L.)
K0371 - Sunburst. (F.S.L.)
K0384 - Sunburst, Headstock Black - Showed up on Facebook Marketplace in Maryland.
K0420 - Red. (F.S.L.)
K0426 - Red. Had Gibson Humbuckers on it when it was archived at Sarah's website in or around 2010. (F.S.L.)
K0429 - Sunburst, Neck Sunburst. - https://www.facebook.com/share/p/126zPabWT2w/
K0462 - Faded Red (Orange.) 3 Bolt 2 Piece Neck, Kluson Plastic Knob Tuners. Was documented by Sarah around 2010 - 2012, too.
https://reverb.com/item/63028530-1967-m ... nds-killer
K0500 - Sunburst. (F.S.L.)
K0503 - Sunburst. (F.S.L.)
K0522 - Sunburst. (F.S.L.)
K0526 - Sunburst, Headstock Black. 3 Bolt Neck. Parted out by gibsondependable on eBay.
K0541 - Faded Red (Orange) - 3 Bolt 2 Piece Neck. Kluson Metal Knob Tuners (not sure if replaced.)
https://reverb.com/item/76074601-1966-m ... _sold=true
K0547 - Unknown Finish. Celebrity III? (Unknown, not specified.) (F.S.L.)
K0574 - Red. (F.S.L.)
K0579 - Sunburst, Headstock Black. Unknown Neck Construction. Kluson Metal Knob Tuners. Belonged to Matty Ramone. (See comments in this FB page:)
https://www.facebook.com/groups/3294258 ... 983170722/
K0650 - Sunburst. (F.S.L.)
K0663 - Faded Red (Orange.) 3 Bolt 2 Piece Neck. Kluson Metal Knob Tuners. Has Moseley Vibrato without Baseplate.
https://reverb.com/item/72081303-mosrite-celebrity-iii
K0665 - Red. Has a Vibrato Tailpiece. (F.S.L.)
K0676 - Sunburst. 3 Bolt Neck. Kluson Plastic Knob Tuners. Bigsby added.
https://reverb.com/item/37463657-1960-s ... _sold=true
K0711 - Sunburst, Headstock Natural. Unknown bolt construction, 2 Piece Neck. Has Moseley Vibrato without Baseplate.
K0718 - Gospel Variant in Sunburst. Has a Moseley Tailpiece, non-original knobs, and a string retainer drilled through the headstock like some late 60s - 70s imports, which may or may not be original. Was documented by Sarah around 2010 - 2012, too. --- https://www.facebook.com/share/p/RV6QRxS4LS7fB4xr/
K0720 - Sunburst. (F.S.L.)
K0724 - Sunburst with Sunburst Neck & Black Headstock - 3 Bolt Neck. Showed up on Reverb in Late August or Early September 2025. https://reverb.com/item/91946770-mosrit ... TITcOvwPKQ
K0727 - Red. 3 Bolt 2 Piece Neck. Kluson Plastic Knob Tuners. In Neck Pocket, says "Carrico" and then seemingly "WLP" (which I may have ms-read.)
K0736 - Sunburst with Sunburst Neck & Black Headstock - 3 Bolt with Ferrules Neck. Has a sticker saying "Orville Brown" on it. It's also missing the "M" before the Mosrite Logo on Headstock, and it has Non-M Knobs. The Pickup Ohm Readings are 10.75k Bridge and 10.62k Neck. Showed up on Reverb around September 20, 2025. Was documented by Sarah around 2010 - 2012, too. --- https://reverb.com/item/91504229-usa-ma ... shell-case
K0738 - Sunburst. Found in Sweden, missing original pickups. https://www.facebook.com/share/p/1Bxxed2p7p/
https://reverb.com/item/17616144-1967-m ... ebrity-iii
K0746 - Sunburst. (F.S.L.)
K0771 V - Sunburst, Headstock Black. 3 Bolt Neck. Kluson Plastic Knob Tuners. "V" is beneath the serial number, closer to the neck pickup. Was documented by Sarah around 2010 - 2012, too, as long as there's not a duplicate (she didn't mention the extra V in her list.)
https://reverb.com/item/41313299-mosrit ... rst-guitar
K0772 - Sunburst. Has a Vibrato Tailpiece. (F.S.L.)
K0777 - Sunburst. (F.S.L.)
K0779 - Sunburst. (F.S.L.)
K0808 - Red, Natural Neck. 3 Bolt Neck. Showed up on FB Marketplace.
K0833 - Burgundy Burst. (F.S.L.)
K0834 - Red. Has a Vibrato Tailpiece. (F.S.L.)
K0835 - Green. Has a Vibrato Tailpiece. (F.S.L.)
K0842 - Burgundy. Has a Vibrato Tailpiece. (F.S.L.)
K0846 - Burgundy. Has a Vibrato Tailpiece. (F.S.L.)
K0854 - Burgundy Burst. Has a Vibrato Tailpiece. (F.S.L.)
K0894 (over K0894, the 9 is double stamped.) - Sunburst. Thanks to Kenneth for sharing this one!
K0909 - White. (F.S.L.)
K0922 - Burgundy. (F.S.L.)
K0930 - Red. 3 Bolt 2 Piece Neck. Kluson Plastic Knob Tuners. Has Moseley Vibrato without Baseplate. Inner Label says "Style 220-v" instead of "Celebrity 3." Seen at the Mosrite Forum here, and also at MusicGoRound.
viewtopic.php?f=6&t=8182 --- https://www.musicgoround.com/product/gr ... guitar-red
K0947 - Red Burst. Unknown Bolt Construction, 2 Piece Neck. Kluson Plastic Knob Tuners. Seen in this 2010 Mosrite Forum Post:
viewtopic.php?p=41492#p41492
K0948 - Unknown finish. Celebrity III? Unclear. (F.S.L.)
K0983 - Stripped paint. No pickups or electronics or knobs. Found on Facebook Marketplace on 6 October 2024.
K1000 - Translucent Green. 4 Bolt Neck.
https://reverb.com/item/65080324-mosrit ... green-1968
K1013 - Sunburst. Had a Vibrato Tailpiece (missing.) (F.S.L.)
K1018 - Red. This had a misprint that seems to be K16 something or other, maybe K1615, then the misprint was filled in and the actual number was stamped next to the fretboard end instead of between the last two frets.
K1067 - Sunburst. (F.S.L.)
K1069 - Red Burst. 2 Piece 4 Bolt Neck. Guitar had its pots, switch, and output jack replaced but the owner still has them. Tuners seem to be the Japanese "Diamond" tuners, oddly enough. Guitar showed up on Facebook.
K1078 - Sunburst. (F.S.L.)
K1081 - Sunburst. (F.S.L.)
K1095 - Red Burst. Has a Vibrato Tailpiece. (F.S.L.)
K2004 - Green. (F.S.L.)
K2029 - Green. (F.S.L.)
K2031 - Red. Has a Vibrato Tailpiece. (F.S.L.)
K2049 - Sunburst. (F.S.L.)
K2068 - Red. 3 Bolt Neck. Has "Diamond" Tuners. Has a Moseley Vibrato Tailpiece with the Patent Number. --- https://www.facebook.com/share/p/iHQ2ywjz6qWaW7FU/
K2109 - Sunburst. 4 Bolt Neck.
https://reverb.com/item/76398689-1968-m ... tar-w-ohsc
K2119 - Green, 4 Bolt Neck. 2 Piece Neck. Has "Diamond" Tuners. Showed up on F.B. Marketplace in Bakersfield, Jan 23 2024. Ad said the color was "1967 NAMM Show Green."
K2145 - Green. (F.S.L.)
K2183 - Unknown finish. (F.S.L.)
K2199 - Red. 4 Bolt Neck.
https://reverb.com/item/57561642-mosrit ... 60-s-w-hsc
K2806 - Translucent Green, "Diamond Tuners," 4 Bolt Neck. Also has a truss rod cover that looks more sharp and not quite Mosrite-ish. Showed up on Reverb: https://reverb.com/item/86792721-mosrit ... late-1960s
Strange Numbers:
ST040 - 2 Piece 3 Bolt (Ferrules) Neck Only. Parted out by Gibsondependable in 2022.
ST041 - 2 Piece 3 Bolt (Ferrules) Neck. Dark Cherry-ish finish with darker red paint around the edges and F Holes. Also does not have a Mosrite Bridge on it, but has a 1 piece bridge that a cheap 60s archtop would have, but there are no indications in the photos given that this guitar was ever equipped with a Mosrite Bridge. The knobs are a cheaper black plastic type. --- https://www.elderly.com/products/mosrit ... 9aSBueCKRw
ST046 - 2 Piece 3 Bolt (Ferrules) Neck. Sunburst. Has replacement M3 pickups, and a neck shim added to counteract the collapsed neck block. Non original knobs, seemingly? But then again, these black plastic knobs are consistent with ST041. --- https://reverb.com/item/66219645-vintag ... i-sunburst
Unknown & Unconfirmed Numbers:
K0xxx - Faded Red (Orange) - Belongs to Kevin Kinney of Drivin' and Cryin'.
Mark XII (12 String: )
Mind that confirmed numbers for the 1960s Celebrity III-XII models are a bit of a mess. It's possible that workers put the wrong stamps on some of these documented examples, or there may be another reason.
Confirmed Numbers:
P0008 - Faded Red (Orange.) - Has Ventures I type pickups. Pot Codes are "1346708," "BA811," and the last code is hard to see in the pic; my best guess is "390x" (x = unknown.)
P0048 - Sunburst, Neck Sunburst, Headstock Black. 3 Bolt Neck. Was on eBay in November 2023.
N0130 - Sunburst. Found on Guitar Center's site on April 8 2025. I'm not sure why this one has a different prefix.
W0215 - Uncertain if this even belongs in this list, yet. The body's bridge block was either not placed right, or it was too short and so the Low E side bridge post wasn't properly anchored but it was half exposed to air.
W0227 - Blue. Showed up on Reverb in 2024. --- https://reverb.com/item/83823438-vintag ... -blue-case
P015x - Transparent Red, 3 Bolt Neck. I can't tell if the last digit is a 5, 6, 8, or 0.
https://reverb.com/item/62110759-mosrit ... ginal-case
1970s Serial Number List:
Confirmed Numbers:
None yet listed.
None yet listed.
None yet listed.
Confirmed Numbers:
3c0001 - Brown Burst, Comma Plate -Headstock end broke off, pickup switch replaced, bridge pickup replaced with a Humbucker.
https://www.facebook.com/share/p/ysmC6vqerHrfjmjT/
3c0017 - Sunburst with Sunburst Neck and Headstock. Has Neck Plate. Control Plate is "Comma" type. Tuners are "Diamond" Tuners.
https://reverb.com/item/69451294-mosrit ... _sold=true
3c0063 - Red Burst. Natural 2-piece Neck with Neck Plate. Control Plate is "Bananna" type. Tuners are "Diamond" Tuners. https://reverb.com/item/68447877-mosrit ... y-iii-70-s
3c0086 - Sunburst, Headstock Sunburst, Narrower Headstock than 60s counterparts. Control Plate is "Banana" type. Found on Reddit. https://www.reddit.com/r/Mosrite/commen ... ?context=3
3c0171 - Red Burst. "Banana" Control Plate. 2 Piece Neck, with Neck Plate. Control Plate is "Bananna" type. "Diamond" Tuners. https://reverb.com/item/76436845-mosrite-celebrity-1967
3c0181 - Sunburst. Natural 2-piece Neck with Neck Plate. Control Plate is "Bananna" type. Tuners look like Klusons with Metal Knobs, but they don't say it. Was on eBay in June 2023. - Update, August 18 2025: Showed up on Facebook, bought by Doug Wright. https://www.facebook.com/share/p/1ETGLEYGse/
3c0303 - Sunburst. 3 Bolt Neck. Control Plate is "Comma" type. Tuners are Kluson Deluxe with Plastic Knobs. Pot Code reads 1346647 and then BA811-3901.
https://reverb.com/item/64126108-mosrit ... urst-1970s
Strange Numbers:
None yet listed.
None yet listed.
Confirmed Numbers:
None yet listed.
Strange Numbers:
None yet listed.
None yet listed.
1990? Serial Number List:
Confirmed Numbers:
W0038 - Sunburst. Has a neck plate. I'm not sure when this fits in with the timeline, I'm not sure if Guitar Center were accurate. But this is still an oddity in the list.
https://www.guitarcenter.com/search?typ ... tt=mosrite
Total Instruments Accounted For:
1960s:
4 String Basses:
10 Known # 4 String Basses,
1 Partly Known # 4 String Basses,
0 Unconfirmed # 4 String Basses.
6 String Guitars:
85 Known # Guitars,
1 Partsrite,
2 Strange # Guitars,
0 Partly Known # Guitars,
1 Unknown # Guitar.
12 String Guitars:
5 Confirmed # 12 String Guitars,
1 Partly Known # 12 String Guitars,
0 Unknown # 12 String Guitars.
1970s:
4 String Basses:
0 Known # Basses,
0 Partly Known # Basses,
0 Unknown # Basses.
6 String Guitars:
7 Known # Guitars,
0 Unknown # Guitars.
12 String Guitars:
1 Confirmed # 12 String Guitars,
1990 [if the sales site was accurate:]
1 Confirmed # 12 String Guitar.
Total Instrument Tally:
1960s Instrument Tally:
102 Confirmed Serial #s,
3 Strange # Instruments,
2 Partly Known #s,
1 Unknown # Instrument.
1970s Instrument Tally:
8 Confirmed Serial #s,
0 Strange # Instruments,
1 Partly Known #s,
0 Unknown # Instrument.
1980s - 1995 Instrument Tally:
1 Confirmed # Guitar.
Total:
109 Confirmed Serial #s.
3 Partly known #s,
119 Instruments Total.
Finishes & Variants Accounted For:
Blue
Green
Red
Red, Faded to Orange
Sunburst
1970s:
Brown Burst
Sunburst
Reference Photo of a Celebrity III 6-String Guitar Model for Facebook Preview:
Re: Mosrite Celebrity III Serial Numbers List (1960s - 1970s)
Postby 101Volts » Fri Nov 24, 2023 4:23 pm
Total Topic Updates Reply:
2023:
November 24th:
Started list.
Added:
Z-0337 (Blue Bass)
K-0384 (Sunburst Guitar)
K0541 (Faded Red - Orange)
K0xxx - Faded Red (orange) - Belongs to Kevin Kinney
P0008 - Faded Red (Orange 12 String Guitar)
November 25th:
Added:
Z0084 - Sunburst.
Z026? - Sunburst.
K0526 - Sunburst.
K0663 - Faded Red (Orange.) Has Moseley Tailpiece without Baseplate.
K0711 - Sunburst. Has Moseley Tailpiece without Baseplate.
K0727 - Red.
K0947 - Red Burst.
K2199 - Red.
November 29th:
Added Bass, Z0095 (Sunburst.)
November 30th:
Added Guitar, K0579 (Sunburst.) Belonged to Matty Ramone. (See comments in this FB page:)
December 1st:
Added Bass Z0326 - Red, 3 Bolt.
December 10th:
Added:
1960s:
K0676 - Sunburst.
K0771 V - Sunburst.
K2109 - Sunburst.
P015x - Transparent Red 12 String.
1970s:
3c0017 - Sunburst Guitar.
3c0303 - Sunburst.
December 11th:
Added:
1960s:
ST040 - Sunburst. Strange Number.
1970s:
3c0063 - Red Burst.
3c0181 - Sunburst.
Also fixed the numbers from being "300017" and such to show they're 3c0017 and such.
December 12th:
3c0171 - Red Burst. Banana Neck Plate.
December 20th:
Added:
Bass: Z0208 - Faded Red Burst (Orange Burst in most places.) - 3 Bolt 2 Piece Neck. Parted out by Gibsondependable.
12 String: P0048 - Sunburst, Neck Sunburst, Headstock Black. 3 Bolt Neck.
Also re-organized the list so that the 1970s section is lower in the list.
December 22nd:
Added:
K0095 - Red
K0111 - Sunburst
K0240 - Natural.
December 28th:
K0105 added.
K0334 added.
December 29th:
Z0457 added. --- https://reverb.com/uk/item/63894583-196 ... y-usa-made
2024:
January 5th:
K0149 added. (Sunburst.)
January 17th:
Bass:
6 String Guitar:
K0068 - Faded Red (Orange.) Tuners changed for Grovers.
K0075 - Red. 3 Bolt, 2 Piece Neck. Had a Bigsby added. Found on eBay.
K0268 - Red - 3 Bolt Neck, 2 Piece Neck. Pots date to 1966, according to the seller. Found on eBay.
January 20th:
Added:
K0180 - Sunburst, Neck Sunburst, 3 Bolt Neck.
K0808 - Red, Neck Natural, 3 Bolt Neck.
January 23rd:
Added:
Z0511 - Green
Z2119 - Green
Both of these showed up for sale in Bakersfield's Facebook Marketplace.
February 20:
Added K0894 over K0894 - Sunburst. The "9" is double stamped.
April 16:
Added:
Z0001 (Dark Red.) This first stamped Celebrity III Bass has a neck plate.
April 29:
Added:
K0232 (Sunburst.) 3 Bolt (Ferrules) Body. Tuners, Frets, and Bridge replaced.
ST046 Added. This might be a Celebrity II along with the other one, so I may have to move the ST040 and ST046 ones to another list.
August 25:
Added K2068 - Red. 3 Bolt Neck. Has a Moseley Vibrato Tailpiece with the Patent Number. --- https://www.facebook.com/share/p/iHQ2ywjz6qWaW7FU/
August 26:
Added W0038, which Guitar Center said was a "1990 reissue" of a 12 String Celebrity III. It's Sunburst, and it looks a lot like a 1960s version. I don't know what it is for sure.
September 26:
Added:
K0718 (Gospel Variant in Sunburst.)
October 6:
Added:
K0983 (Stripped paint, no pickups or electronics or knobs)
October 17:
Added:
2025:
[b]January 18:[/b]
Added:
K0162 Sunburst, Neck Sunburst.
Ko429 - Sunburst, Neck Sunburst.
K1018 (Red.) This had a misprint that seems to be K16 something or other, maybe K1615, then the misprint was filled in and the actual number was stamped next to the fretboard end instead of between the last two frets.
January 25, 2025:
Added K0330 (Sunburst, 3 Bolt.) Has a Bigsby and Mosrite Roller Bridge added, and might read "Roy Clark" under the bridge and between the pickguard and control plate. So perhaps Roy Clark himself owned this one?
January 28, 2025:
Added K2806 - Translucent Green, "Diamond Tuners," 4 Bolt Neck. Also has a truss rod cover that looks more sharp and not quite Mosrite-ish.
March 7, 2025:
Added 3c0086 - Sunburst, Headstock Sunburst, Narrower Headstock than 60s counterparts. Control Plate is "Banana" type. Found on Reddit. https://www.reddit.com/r/Mosrite/commen ... ?context=3
April 8, 2025:
Cleaned up a duplicate section of the list for the 1970s 6 string models.
Added:
12 String:
N0130, which is a 12 string that had an unusual number.
Also saw these two pop up at Guitar Center, but they're already on the list:
6 String:
K0111 - Sunburst with Black Headstock.
K0808 - Dark Red. Has a noticeable finish defect on the lower horn, possibly started due to a scratch.
May 3, 2025:
Added ST041 - 2 Piece 3 Bolt (Ferrules) Neck. Dark Cherry-ish finish with darker red paint around the edges and F Holes. --- https://www.elderly.com/products/mosrit ... 9aSBueCKRw
May 4, 2025:
Added K0083 - Sunburst (Parted Out, but with the body and neck.)
May 5, 2025:
Added K0738 - Sunburst. Found in Sweden, missing original pickups. https://www.facebook.com/share/p/1Bxxed2p7p/
June 25, 2025:
Added W0215 - This might not belong in this Celebrity III list, although it is a 12 String. I don't know why the number prefix is different here.
June 27, 2025:
Added Z0354 - Natural Finish.
August 18, 2025:
3c0181 showed up again. https://www.facebook.com/share/p/1ETGLEYGse/
September 6, 2025:
K1069 (Red Burst) Added. Guitar had its pots, switch, and output jack replaced but the owner still has them. Tuners seem to be the Japanese "Diamond" tuners, oddly enough.
October 3, 2025:
K0736 - Sunburst with Sunburst Neck & Black Headstock - 2 7/8" deep body. Also missing "M" before the Mosrite Logo on Headstock, and has Non-M Knobs. Is this a Parts-Rite, or just a "what we have on hand" guitar? Showed up on Reverb around September 20, 2025. --- https://reverb.com/item/91504229-usa-ma ... shell-case
October 6, 2025:
K0736 moved from "too deep wrong body" section.
W0227 (12 String in Blue) Added. Strangely, this seems to be "the wrong prefix."
October 12, 2025:
K0111 updated.
2026:
March 11, 2026:
K0027 - Sunburst
K0107 - Red
K0114 - Red
K0139 - Sunburst
K0163 - Sunburst
K0210 - Sunburst
K0284 - Red
K0326 - Sunburst
K0362 - Sunburst
K0371 - Sunburst
K0420 - Red
K0500 - Sunburst
K0503 - Sunburst
K0522 - Sunburst
K0574 - Red
K0650 - Sunburst
K0720 - Sunburst
K0746 - Sunburst
K0777 - Sunburst
K0779 - Sunburst
K0909 - White
K0922 - Burgundy
K1067 - Sunburst
K1078 - Sunburst
K1081 - Sunburst
K2004 - Green
K2029 - Green
K2049 - Sunburst
Reply 2 has been reserved as a space for where I can add a tally of all topic updates.
Reply 3 has been reserved as a space for where I can add a tally of all topic updates, or other updates.
Re: Mosrite Celebrity III models Serial Numbers List (1960s - 1970s, Hollow Body.)
Postby 101Volts » Sat Jan 18, 2025 4:09 pm
Welcome to the serial numbers list for Mosrite Celebrity III Models.
If you want to see the Celebrity I or Celebrity II lists, here they are:
Celebrity I:
Celebrity II:
Body Wood:
Neck Wood:
Recent Updates:
October 6:
Added:
October 17:
Added:
January 18, 2025:
Added:
Confirmed Numbers:
Z0001 - Dark Red. This is so early that it has a neck plate. The sticker inside just says Style: "Celebrity," but it's still a Celebrity III. https://www.facebook.com/groups/5297862 ... 074922139/
None yet listed.
Confirmed Numbers:
K0111 - Sunburst.
K0240 - Natural. 3 Bolt 2 Piece Neck, Kluson Plastic Knob Tuners. Pickguard says "[{m} Mosrite California" on it.
K0663 - Faded Red (Orange.) 3 Bolt 2 PIece Neck. Kluson Metal Knob Tuners. Has Moseley Vibrato without Baseplate.
K0718 - Gospel Variant in Sunburst. Has a Moseley Tailpiece, non-original knobs, and a string retainer drilled through the headstock like some late 60s - 70s imports, which may or may not be original. --- https://www.facebook.com/share/p/RV6QRxS4LS7fB4xr/
Strange Numbers:
ST040 - 2 Piece 3 Bolt (Ferrules) Neck. Neck now on what seems to be a Parts-Rite, since I documented the neck with a Red Body from an instrument that was parted out by GibsonDependable in 2022. The current instrument it's on is Sunburst, and it has non-original but close M3 California pickups with pole pieces. Non original knobs, seemingly. https://reverb.com/item/66219645-vintag ... i-sunburst
ST046 - 2 Piece 3 Bolt (Ferrules) Neck. Has replacement M3 pickups, and a neck shim added to counteract the collapsed neck block.
Confirmed Numbers:
Confirmed Numbers:
None yet listed.
Confirmed Numbers:
None yet listed.
None yet listed.
None yet listed.
Confirmed Numbers:
Strange Numbers:
None yet listed.
None yet listed.
Confirmed Numbers:
None yet listed.
Strange Numbers:
None yet listed.
None yet listed.
Confirmed Numbers:
4 String Basses:
8 Known # 4 String Basses,
6 String Guitars:
1960s:
34 Known # Guitars,
1 Strange # Guitar,
1 Unknown # Guitars.
1970s:
6 Known # Guitars,
12 String Guitars:
1990:
Total: 56 Instruments. 53 Confirmed Numbers, 2 Partial Numbers, 1 Unconfirmed.
Blue
Green
Red
Sunburst
1970s:
Brown Burst
Sunburst
Postby 101Volts » Sat May 03, 2025 11:03 am
Added ST041.
I'm not yet sure what the reason is for these different numbers.
Users browsing this forum: No registered users and 548 guests
