Mosrite Serial Numbers - Organized Links to Each List (On-Site and Off-Site.)
Postby 101Volts » Sun Jul 09, 2023 4:07 pm
Since there are many Serial Number Lists for Mosrite Models now, here's a more organized chronological (by decade) and alphabetical way of getting to each list.
If the list is at the Mosrite Forum (and I oversee each list here,) then you will need to check the most recent reply (or close to it) of the linked thread for the most up to date information, but this thread is just for the sake of organization.
If the list is at Maxkat's site (which I do not oversee,) then I've mostly linked as directly as I can to the start of each section, except for the 1976 - 1995 parts, and I also did not link to sub-versions of each model (such as the few Gospel Mark Vs.)
Lastly, some of these aren't yet as organized as I'd like them (the 350, Blues Bender, and Brass Rail topics in particular.) I started (or otherwise worked on) multiple lists before I was an Admin, so I updated them by one reply at a time since I couldn't edit a topic, and those topics have many replies. For those topics, you'll need to check the most recent reply for the most recent update to that topic.
|=====|1960s:|=====|
Acoustics:
Balladere Models (four types:)
viewtopic.php?f=6&t=8148
Serenade Models (four types:)
viewtopic.php?f=6&t=8075
Electrics:
Celebrity Models:
Sarah's List for All Celebrity Models [at Archive:]
https://web.archive.org/web/20140910013 ... age29.html
Celebrity I:
viewtopic.php?f=6&t=8185
Celebrity II:
viewtopic.php?f=6&t=8186
Celebrity III:
viewtopic.php?f=6&t=8184
Other:
Combo Models:
viewtopic.php?f=6&t=8170
Joe Maphis models:
viewtopic.php?f=6&t=8105
Mel-O-Bar (Stand-up Slide Guitar) Models:
https://hang10.de/lists/mosrite-venture ... s/#melobar
The Ventures models:
4 String Bass:
https://hang10.de/lists/mosrite-venture ... s63-69bass
6 String Guitar:
https://hang10.de/lists/mosrite-venture ... tures63-69
12 String Guitar:
https://hang10.de/lists/mosrite-venture ... ventures12
The Ventures II "Slab Body" Models (the type Johnny Ramone used:)
https://hang10.de/lists/mosrite-venture ... bers/#slab
The Ventures II "German Carved" Models (replaced the Slab Body, more or less is a Mark V, but without the name:)
https://hang10.de/lists/mosrite-venture ... ers/#trans
The Ventures Mark V model and Non-Ventures Mark V models:
https://hang10.de/lists/mosrite-venture ... ers/#vbody
The Ventures Mark V Bass Prototype model:
https://hang10.de/lists/mosrite-venture ... ers/#vbass
|================|1970s:|================|
(note that for the Combo and Celebrity types, the lists are mostly for 60s models. 70s models are also listed, but few are in the lists.)
300 and 350 Models:
viewtopic.php?f=6&t=7380
500 Blues Bender Model:
viewtopic.php?f=6&t=8217
Brass Rail models:
viewtopic.php?f=6&t=8216
Celebrity I:
Celebrity II:
Celebrity III:
Combo Models:
Joe Maphis models (a few carried over from the 1960s:)
S. M. (Semie Moseley) Model (though that's an unofficial name, it's the closest we have:)
viewtopic.php?f=6&t=7907
Ventures-Shaped (but not endorsed) 1971 - 1974 models:
Bass:
B-I Model:
https://hang10.de/lists/mosrite-venture ... s70-74bass
B-II Model:
https://hang10.de/lists/mosrite-venture ... 70-74bass2
Guitar:
V-I Model:
https://hang10.de/lists/mosrite-venture ... res70-74v1
V-II Model:
https://hang10.de/lists/mosrite-venture ... res70-74v2
|==============|Later Years:|===============|
1980s Joe Maphis models (check list, the section is in there.)
If you want to check for serial numbers of most other models made after 1974, Max has another section of his site here that you can check out, ranging from 1976 - 1995:
https://hang10.de/lists/mosrite-the-las ... ooneville/
I may edit this post again later on, for completion's sake.
|===============|Misc. Lists:|===============|
There's another site with numbers that Kiyoshi Mochizuki hosted. Some (if not all) numbers on it may already have been taken from this site, but I've posted it here for completion's sake:
http://www.ne.jp/asahi/mochizuki/kiyosh ... rlist.html
Image for Facebook Preview:
Users browsing this forum: No registered users and 175 guests
