Mosrite Combo model Serial Numbers List (1966 - 1974.)
Postby 101Volts » Fri Jun 30, 2023 7:10 pm
Thread Introduction:
Welcome to the serial numbers list for Mosrite Combo Models. The Combo appears to have started production in Late 1966, no earlier than November (this excludes possible prototypes.) The lowest serial number Combo on the list, H0003, has Potentiometers from November 1966. The number of 1970s models isn't as clear, and it's not certain when exactly the last one was made in the 70s (not counting parts-rites,) but it's not expected to be later than 1974.
Either check this initial post, or go to the most recent post (or close to it) for the most recent update of the list. I've changed the format compared to other lists, so this initial post will be updated, too. The 1st reply of mine (just after this post) will tally up each update.
If you want to link the thread, link the main thread and not one of my replies; I'm likely to delete some of my replies.
Contributing to this List:
If you happen to own a Mosrite Combo of any type and would like to contribute information, I'll need info (and I'd also like pictures, if possible) of these areas:
1 - Pic of the front of the guitar.
2 - Pic of the back of the guitar (to show how the neck is attached - Mosrite usually had a neck plate for these, but sometimes had 3 or 4 screws with ferrules.)
3 - Pic of the sticker seen through the F-hole (if still present.)
4 - Pic of the serial number, stamped into the end of the fretboard near the Neck Pickup (if still present.)
5 - Pic of the headstock, front and top side.
6 - Pic of the headstock, rear.
7 - (Only applies to 6 String Guitars, unless there's somehow a 12 string with this tailpiece) - A pic of the Moseley Tailpiece, where it says "Moseley." Some of the tailpieces have a Patent Number which will be referred to as "PAF # Tailpiece," and I'd like to tell when that starts (though maybe all of them have it.)
These last 3 are not absolutely necessary, but would also help:
8 - Pic of the Dates on the Potentiometers (if the pots are original.) They come in either Week-Year Format (so 45-66 would be in November 1966) or it's the reverse. The pot codes are on the sides of the Potentiometers.
9 - Pic of the Neck Heel where it meets the body (if there's a date stamped, but that probably doesn't exist for any Combo models as they seem to have stopped date stamps the month before Combo models may have started production. If you don't want to take the neck off, you don't have to.)
10 - Pic of the Neck Pocket (if there's a date, again, which may not exist past October 1966.)
Model Specifications:
The Mosrite Combo model is a Semi-Hollow Body Instrument with an F Hole. It has the same shape as the Joe Maphis model, but the Maphis uses different body wood, and the Maphis also does not have an F Hole.
24.50" Scale Length (Guitar - 6 String & 12 String) - with 22 Frets
30.25" Scale Length (Bass) - with 20 Frets
Mosrite Single Coil Pickups (possibly with AWG 44 in the Guitar Pickups, and AWG 42 in the Bass Pickups.)
500k Pots (Bass confirmed, possibly the same on guitar)
The 1967 - 1968 Mosrite Brochure also says that the 12 string could be ordered with the Moseley Vibrato Tailpiece as an option, but so far, I haven't seen any with one.
Body Wood:
Basswood. May also have a Maple Top (I don't have a complete spec sheet to refer to.)
Neck Wood:
Maple with Indian Rosewood Fretboard.
Tuners:
Typical tuners are Kluson Deluxe type, but late Combo models from approx. 1968 (somewhere after H1000) may have the Japanese "Diamond" Tuners.
Unconfirmed specifications (but likely to be right:)
1960s Neck Width and Depth:
Width: 1.550" - 1.560" at the Zero Fret
Depth: Roughly 0.860" from frets 2 through 12
1960s Frets:
If they're original and the guitar is a 1960s model, 0.070" wide, with fret height of 0.022" tall on the Low E side, tapering down to 0.015" on the High E side. This is Mosrite's 1960s "Speed Fret" size, and it has a flat crown. They allow strings to feel like a lighter gauge.
1970s Neck Width and Depth:
Uncertain.
1970s Frets: Spec:
Uncertain, but expected to be taller.
Recent Updates:
October 6, 2025:
Moved location of "1970s" under the tally below the 12 String Section instead of above it; the previous version could give a false impression of 12 string models existing in the 70s, which they may, but I haven't seen any yet if they do.
October 7, 2025:
Partsrite added:
2J238 (Has a Combo body and a 6 String Neck from a Doubleneck) - Blue Body Finish, Neck Back is Blue-Green Burst, Back of Headstock is blue, Front of Headstock is Blue-Green Burst --- https://reverb.com/item/70338634-1966-m ... aphis-neck
October 14, 2025:
Updated details of R0029. Added some basses, too.
R0193 - Red Burst, Red Burst Neck, Black Headstock - 4 Bolt Neck with Plate, Bound F Hole. --- https://www.creamcitymusic.com/vintage- ... st-finish/
R0307 - Red - Bound F Hole, 4 Bolt Neck with Ferrules. Tortoiseshell Pickguard (unclear if this pickguard's original.) --- https://www.gbase.com/gear/mosrite-comb ... 967-cherry
October 20, 2025:
Added H0980 - Sunburst. Showed up on Reddit on October 20 2025. --- https://www.reddit.com/r/guitars/commen ... o_og_post/
October 23, 2025:
Added H0321 - Red (Faded.) Showed up on Facebook in October 2025.
December 3, 2025:
Added:
R0070 - Sunburst, slightly modified with strap buttons on the back of the Bass and a new wiring harness.
H0699 - Red Burst - Has PAF # Tailpiece. 4 Bolt Neck with Plate. 2 Piece Neck, Original Frets. Has some fretboard fingernail divots. Showed up on Facebook on December 1st 2025. --- https://www.facebook.com/share/p/1AGmS7ByFG/
December 6, 2025:
Added:
H0970 - Red Burst - With Bound F Hole, and Vibrato with Baseplate (Outlier.) 4 Bolt Neck with Ferrules. Has belt buckle rash, and original frets. --- https://reverb.com/item/93420012-mosrit ... case-video
December 12, 2025:
R0070 Updated - the pot code information dates to the 8th week of 1967. Also added pot specs to specs.
2026:
January 6, 2026:
Added:
H1073 - Sunburst. Signed by The Ventures. Showed up on eBay in early January 2026.
Jan 9, 2026:
Added:
Gxxxx - Black - 12 String Combo in Black. Surprising. Number not stated in listing, and it's difficult to tell what it says but this should be a later one.
March 31, 2026:
Added:
H0335 - Red. Parted out by Gibsondependable in March 2026.
April 2, 2026:
Update to H0802, added detail that the finish is Dark Red and not just the normal Bright Red.
October 8, 2026:
Added H0040 - Red. Original Tuners may have been changed.
Serial Number List:
1960s Models:
Co Mark X [4 String Bass:]
(Note: the Combo Basses and Joe Maphis Basses' serial numbers both started with the same letter prefix: "R.")
R0003 - Red - Un-Bound F Hole. --- https://www.facebook.com/groups/5297862 ... 654287139/
R0021 - Sunburst, Neck Sunburst, Black Headstock - Un-Bound F Hole, 4 Bolt Neck with Plate. Was on eBay.
R0023 - Red - Un-Bound F Hole.
R0029 - Red - Un-Bound F Hole, 4 Bolt Neck with Plate. Has sticker through F Hole. --- https://reverb.com/item/87453279-1967-m ... -condition
R0070 - Sunburst - Un-Bound F Hole. Appears to be modified with a strap button near the neck plate and also on the back on the other side of the instrument, plus the original wiring harness seemed to be out of the guitar in the Facebook Marketplace Ad. Thanks to Bob for sharing the Marketplace Ad with me. --- Update, December 12 2025: Bob bought this Bass, and he says the Pot Codes date to the 8th week of 1967; CentraLab 134 67 08 model BA811 3901, 500k pot.
R0193 - Red Burst, Red Burst Neck, Black Headstock - 4 Bolt Neck with Plate, Bound F Hole. One pot is dated "1346647" which is Late November 1966, but I expect this Bass is more Early 1967 since the 3rd numbered Guitar (H0003) also has this code. --- https://www.creamcitymusic.com/vintage- ... st-finish/
R0214 - Red - Bound F Hole, 4 Bolt Neck with Plate.
R0255, Red Burst - Bound F Hole. Page saved.
Strange Numbers Section:
0145 - Red. This might be R0145, but the page says 145 at Kiyoshi Mochizuki's page. https://www.ne.jp/asahi/mochizuki/kiyos ... rlist.html
SPR-0117 - Seems to have originally been Sunburst, refinished Natural. Electronics were replaced before the current owner got it, then he replaced those electronics. Owned by forum member AltGrendel. Pic saved. --- viewtopic.php?f=6&t=8112
Partially Accounted For:
R0x30, Dark Red. 3 Bolt (Ferrules) Neck with 2 extra bolts added. All Electronics and Pickguard missing. Page saved.
R0x35 (possibly R0135,) Red Burst. 4 Bolt Neck with Plate. Has bound F hole. Missing electronics. Page saved. --- https://www.gbase.com/gear/mosrite-comb ... -red-burst
Co Mark I [6 String Guitar:]
Confirmed Numbers:
Early Construction - Un-Bound F Hole, Vibrato with Baseplate Construction:
H0003 - Red (Faded) with Natural Headstock. Has the Mosrite Logo stamped on the inside of the body, and seems to have the serial number written in pen, seen through the F Hole. Has PAF # Tailpiece. One of the Potentiometer (Pot) codes reads "1346647" (the 4th week of November 1966,) therefore, the Combo model should at earliest be a Late 1966 instrument and there should not be any date stamps on the neck heel or in the neck pocket (neck heel and neck pocket dates stopped in October 1966, predating the Combo model.) This example was posted at the forum (thanks!)
H0005 (most likely) - Sunburst with ??? neck, Black Headstock. Advertised as H0003, but it's not the same guitar that is described just above. Has the Mosrite Logo stamped on the inside of the body. Listed from 440 Instruments LLC. https://reverb.com/item/91867962-mosrit ... o-sunburst
H0007 - Red with Natural Headstock. Mentioned here at Kiyoshi Mochizuki's page: https://www.ne.jp/asahi/mochizuki/kiyos ... rlist.html
H0014 - Red with Natural Headstock. Showed up on Reddit. https://www.reddit.com/r/Mosrite/commen ... ite_combo/
H0066 - Red with Natural Headstock. Showed up at FB Group "Mosrite Guitar Owners." Has the Mosrite Logo stamped on the inside of the body.
H0076 - Sunburst with Black Headstock. Has Mosrite Logo stamped inside the body. Has PAF # Tailpiece. All original. Pot Codes read "1346647" (the 4th week of November 1966.)
H0084 - Red. Can't see headstock in photos. Has the Mosrite Logo stamped on the inside of the body.
H0096 - Belongs to forum member Dennis. No photos saved.
H0100 - Red with Natural Headstock - 4 Bolt Neck with Plate. Has the Mosrite Logo stamped on the inside of the body. The serial number on the inside reads "H0010," however. This guitar is also missing a screw (it was never drilled for) on the pickguard near the neck pickup. Tuners replaced, and screws for truss rod cover may also be replaced. --- https://reverb.com/item/86377695-red-mo ... _sold=true
H0113 - Red with Natural Headstock - Has the Mosrite Logo stamped on the inside of the body. Has a PAF # Tailpiece. --- https://www.facebook.com/photo/?fbid=10 ... 5646215229
H0136 - Red with Natural Headstock. First confirmed example with a Mosrite Serial Number Sticker on a Combo seen through the soundhole instead of a stamp. Showed up on Facebook with its original case.
H0145 - Red, Worn and Refretted. Has the Mosrite Logo stamped on the inside of the body. Showed up in France from a Reverb ad around September 25, 2025. --- https://reverb.com/item/92371350-mosrite-combo-1967-red
H0154 - Blue with Natural Headstock - No stamp or sticker seen through the F Hole, so maybe it had a sticker and that's now lost. It does say "Helen" through the F hole, though. Shared with me on Facebook.
H0159 - Red Burst with Red Burst Headstock - 4 Bolt Neck with Plate. Has the Mosrite Logo stamped on the inside of the body, and either paint on the inside of the body, or something else looks dirty in photos. Mosrite Logo on Headstock is far off-center. --- https://reverb.com/item/67219956-mosrit ... 6-sunburst
H0167 - Sunburst with Sunburst Neck & Black Headstock - 4 Bolt Neck with Plate. Has the Mosrite Logo stamped on the inside of the body.
H0174 - Sunburst with ??? Neck & Black Headstock - 4 Bolt Neck with Plate.
H0184 - Sunburst with Sunburst Neck & Black Headstock - 4 Bolt Neck with Plate. Has a Mosrite Sticker seen through the soundhole.
H0212 - Red with Natural Headstock. Seen in comments here: --- https://www.facebook.com/groups/3294258 ... 646215229/
H0224 - Red with Natural Headstock. Missing Bridge, Bridge Posts, and Bridge Pickup. Found on Reddit: https://www.reddit.com/r/Guitar/comment ... _identify/
H0231 - Red with Natural Headstock - Has a Mosrite Sticker seen through the soundhole. Had its pickups replaced with some Import Humbuckers, and knobs on pickguard do not look like they're in the right place. Guitar is or was owned by forum member Brutus.
H0237 - Sunburst with ??? Neck & Black Headstock - Has a Mosrite Sticker seen through the soundhole. Belongs to Peter Diedrichs. Found at these Facebook posts: --- https://www.facebook.com/groups/mosrite ... 499958378/ --- https://www.facebook.com/groups/mosrite ... 816098613/ -----
H0255 S P - Sunburst with Natural Neck & Natural Headstock (finish anomaly for Sunburst models) - 4 Bolt Neck with Plate. 2 Piece Neck. Has a Mosrite Sticker seen through the soundhole. No date on neck heel. Extra "S P" letters are below the number, closer to the neck pickup. Those may have been the original owner's initials. Refretted.
H0266 - Sunburst with ??? Neck & Black Headstock - Original Owner was a metal worker who crafted a baseplate for the bridge, and moved the Vibrato farther away from the neck.
Middle Construction - Bound F Hole, and Vibrato with Baseplate (and guitars I saw at some time, but saved no photos of:)
H0303 - Sunburst with ??? neck and Black Headstock. Has original frets as of this update just after it showed up on Reverb around September 24, 2025. --- https://reverb.com/item/92346213-mosrite-combo
H0308 - Red. No pics. Mentioned here at Kiyoshi Mochizuki's page: https://www.ne.jp/asahi/mochizuki/kiyos ... rlist.html
H0349 - Originally Red Burst or Sunburst. Seems to have been refinished, but I only have word of it in this comment section (the picture at this link is not of it:) --- https://www.facebook.com/photo/?fbid=16 ... 9325264874
H0358 - Possibly Sunburst, ??? neck and ??? headstock - I'm not sure where I read this, I saved no pics or links.
H0382 - Red Burst. 4 Bolt Neck with Plate. Has PAF # Tailpiece. Has black & white checkered pickguard. https://www.facebook.com/groups/1048518 ... 125179709/
H0388 - Seen at "Bernunzio's Uptown Music," but I have no photos.
"Middle Construction" Outliers:
H0579 - Red. No further details.
H0923 - Red / Burgundy Burst. With Bound F Hole, and Vibrato with Baseplate. --- https://reverb.com/item/70927473-66-mos ... w-hardcase
H0970 - Red Burst - With Bound F Hole, and Vibrato with Baseplate. 4 Bolt Neck with Ferrules. Has belt buckle rash, and original frets. --- https://reverb.com/item/93420012-mosrit ... case-video
The last three are outliers that are higher in number than the expected range (either D275 or D300 through D400) for the middle construction.
Later Bound F Hole, and Baseplateless Vibrato Construction:
H0408 - Red. Showed up on Facebook.
H0461 - Sunburst. Belongs to Jonathan Chaney. Showed up on Facebook on September 15, 2025.
H0509 - Red, 4 Bolt Neck with Neck Plate. 2 Piece Neck.
H0553 - Red. No pics. Mentioned here at Kiyoshi Mochizuki's page: https://www.ne.jp/asahi/mochizuki/kiyos ... rlist.html
H0555 - Sunburst. No pics. Mentioned here at Kiyoshi Mochizuki's page: https://www.ne.jp/asahi/mochizuki/kiyos ... rlist.html
H0642 - Red. No pics. Mentioned here at Kiyoshi Mochizuki's page: https://www.ne.jp/asahi/mochizuki/kiyos ... rlist.html
H0649 - Red Burst - --- https://www.facebook.com/photo/?fbid=16 ... 9325264874
H0654 - Burgundy (mostly solid, except by the horns, where it's darker) - 4 Bolt Neck with Plate. --- https://reverb.com/item/54735067-mosrit ... ombo-05-09
H0657 (H06557 misprint) - Red Back, Black (refinished) Front. 3 Bolt (Ferrules) Neck. https://reverb.com/item/72548781-mosrit ... _sold=true
H0667 - Sunburst - Has PAF # Tailpiece. Not sure of neck attachment - there's a non-original plate over it. --- https://reverb.com/item/70782355-mosrit ... iginal-hsc
H0677 - Burgundy - Has PAF # Tailpiece. 3 Bolt Neck with Ferrules. --- https://reverb.com/item/65793921-mosrit ... gsb019?bk=
H0697 - Sunburst - Has PAF # Tailpiece. 4 Bolt Neck with Plate. Owner replied in the comments here: --- https://www.facebook.com/groups/5297862 ... 702462139/
H0723 - Sunburst. Mentioned here at Kiyoshi Mochizuki's page: https://www.ne.jp/asahi/mochizuki/kiyos ... rlist.html
H0754 - Red Burst. 3 Bolt (Ferrules) Neck, but someone modified it to have a neck plate. Seller said pots / potentiometers dated to Late 1966. Has PAF # Tailpiece. Here's a Reverb Ad from before it was parted out by Gibsondependable: https://reverb.com/item/70265025-mosrit ... _sold=true
H0760 - Red Burst. 3 Bolt (Ferrules) Neck, 2 Piece Neck. Has PAF # Tailpiece. Showed up on eBay in early 2024, sold with original case which was kept in the basement while the guitar was in a closet.
H0766 - Sunburst - 3 Bolt (with Ferrules) neck. --- https://reverb.com/item/58192914-mosrit ... r-1966?bk=
H0801 - Unknown Finish. Also, unknown tailpiece style. Probably the baseplateless tailpiece, but I don't really know.
H0802 - Dark Red. 3 Bolt Neck. No dates in neck pocket. Pots / Potentiometer Codes' first numbers are 1346704 (Centralab Pots from 1967, 4th Week, so Late January 1967.) Has a black pickguard, probably not original but replaced. UPDATE, Jan 14 2025 - Showed up for sale again from Elderly Instruments. https://www.elderly.com/products/mosrit ... k_zb_OUbDA
H0828 - Natural (Refinished) - 3 Bolt, 2 Piece Neck. - https://reverb.com/item/77336706-mosrit ... -s-natural
H0875 - Dark Cherry Burst. Has a chip in the finish by the F Hole.
H0910 - Blue - 3 Bolt Neck. Neck had more bolts added later.
https://reverb.com/item/49680467-mosrit ... _sold=true
H0912 - Red Burst - 3 Bolt (with Ferrules) Neck. --- https://www.vintageandrare.com/product/ ... urst-72680
H0949 - Blue. 3 Bolt (with Ferrules) Neck. --- https://reverb.com/item/86439282-mosrit ... -pre-owned
H0968 - Red - Found in a YT Video that was mirrored: --- https://www.youtube.com/watch?v=C4Wx3ZnzL4k
H0969 - Red - Missing original Vibrato Tailpiece and Pickups, so I have no confirmation of this one's original tailpiece. Seen here: --- https://www.facebook.com/groups/3294258 ... 882251607/
H0975 - Gold. 3 Bolt (Ferrules) Neck, 2 Piece Neck. Found here: https://cartervintage.com/shop/mosrite- ... enSHzc2XaT
H0980 - Sunburst. Showed up on Reddit.
H0997 - Sunburst, 3 Bolt (with Ferrules) neck. Pot Code 134 68 01 (First week of 1968.) Owned by forum member t-bone.
H01003 - Refinished to Natural. 3 Bolt (With Ferrules) Neck. (Extra 0 in the number is not a typo.) https://www.facebook.com/groups/3294258 ... 794343541/
H01004 - Sunburst. Tuners are Plastic Button Klusons. Pots were replaced. (Extra 0 in the number is not a typo.) https://www.facebook.com/zanesguitarrep ... ZsyAAE4RBl
H1062 - Cherry Red. Has pot dates from 1968 - one is marked 1346801 BA811-4665 (1st week of 1968, January 1968) and the other is 1346806 BA811-4665 (6th week of 1968, Mid February 1968.)
H1073 - Sunburst. Has a neck plate. Signed by The Ventures. Showed up on eBay in early January 2026.
H1097 - Black, with Black Headstock. Found Here: https://www.facebook.com/groups/3294258 ... 662174825/
H1102 - Red. 4 Bolt (with Ferrules) Neck. Has severe belt buckle rash on the back that took much of the paint off. - Reverb, Early November 2025: https://reverb.com/item/75546292-mosrite-combo-1964
H1147 - Red. Mentioned here at Kiyoshi Mochizuki's page: --- https://www.ne.jp/asahi/mochizuki/kiyos ... rlist.html
H1172 - Blue - 4 Bolt (With Ferrules) Neck. Kluson Tuners. Paint's worn through on the body, above the F hole and below the bridge pickup. Also has cigarette burns on the back of the headstock, at the headstock's "M." Pics and page saved.
H1235 - Black. Refretted. Pot Codes are "EP4385 250k 2228" (E. F. Johnson Pots dating to 1968.) The last 4 digits are supposed to indicate the company, and the "8" is supposed to mean that it's from 1968. Forum member beatcomber posted about it at The Gear Page: https://www.thegearpage.net/board/index ... t-37747799 --- It was also listed on Reverb: https://reverb.com/item/72213730-1960-s ... shell-case
H1243 - Sunburst. Has PAF # Tailpiece. 4 Bolt (with Ferrules) Neck. "Diamond" Tuners.
H1252 - Green - Stolen from Mark Carter in the 1970s.
H1258 - Blue - "Diamond" Tuners. 4 Bolt Neck. --- https://reverb.com/ca/item/44132418-mos ... lacid-blue
H1259 - Green - "Diamond" Tuners. 4 Bolt Neck. Showed up in France from a Reverb ad around September 25, 2025. Sold on Septemmber 29 or 30 2025 at the price of about $5,200, but this one is in a rare finish, it looks to be in nearly unplayed condition with its original case, and it sold in France which might explain the high price due to Mosrite's rarity in France. --- https://reverb.com/item/92371285-mosrit ... 1966-green
H1268 - Sunburst. 4 Bolt 2 Piece Neck. "Diamond" Tuners. --- https://reverb.com/uk/item/45300220-use ... iaEQcDBdVo
"Later Construction" Outliers:
H0335 - Red. Parted out by Gibsondependable in March 2026. (Normally would belong under "Middle Construction," being between H0300 and H0399.)
Strange Serial Numbers and Blank # Guitars:
SP H0338 or H0338 SP - Red Burst with Red Burst Neck and Black Headstock. Late construction type with Baseplateless Tailpiece and F Hole Binding. PAF # Tailpiece. The Sticker seen in the body reads "SP H0338., and the neck serial number reads "H0338" and then "SP" is closer to the neck pickup. The pickups were replaced with Rio Grande Mosrite replicas, and the pots aren't original (sadly - there's no word on if they're included in the sale) and the original pickguard was altered but included with the purchase. The knobs included are also the Spun Knob type, which is unclear if they're original or not. The sales ad is copy-pasted and it says the radius is 7.25" and the scale length 22.75", so I'm not sure if the ad is correct or if they didn't proof-red it right. --- https://reverb.com/item/92438858-mosrit ... -red-burst
Blank - 7 layer paintjob. Quote from the owner in 1997: "Semie's experimantal painting that looks deep blue-green, but changes in the light. Combos were offered either red or sunburst. I found this blue one in Hawaii. When I took it to Semie, he held it all day long. He told me it was an experimental paint job, that was not supposed to leave the factory. It has at least five different layers of paint on it, including black, red and gold, and the blue-green." - D. Still - Mentioned here at at Kiyoshi Mochizuki's page: https://www.ne.jp/asahi/mochizuki/kiyos ... rlist.html
Possible Partsrites:
H1212 - Has a Hallmark Body that looks like a Celebrity II or III body. Red Finish, 5 Ply Body Binding. This neck either got the wrong number prefix, or (seemingly more likely) it's a case of a "Parts-Rite." The neck has "Diamond Tuners" (right era for them,) the body has a Trapeze Tailpiece, Flathead Neck Screws, the pickups aren't Mosrite Pickups, and the Neck Pickup Slot is angled when it shouldn't be if it was an official Celebrity II or III. There is also no potentiometer access plate.
2J238 - Has a Combo body and a 6 String Neck from a Doubleneck. Painted by Bill Gruggett who worked at Mosrite. Blue Body Finish, Neck Back is Blue-Green Burst, Back of Headstock is blue, Front of Headstock is Blue-Green Burst --- https://reverb.com/item/70338634-1966-m ... aphis-neck
Unknown & Unconfirmed Numbers:
H0066 - Red - Can't see "H" at start. Has Unbound F Hole, and Vibrato with Baseplate. Also has original hard case. Pics saved.
H0157 (or H0137 or H0177) - Sunburst with ??? Neck & Black Headstock. Has PAF # Tailpiece. Seen in this Facebook Post: https://www.facebook.com/groups/mosrite ... 736963176/
Unknown Construction:
H0567 - Sunburst - With Bound F Hole, Vibrato type unknown (guitar was listed for parts.) 4 Bolt Neck with Plate. This number guess is the best I could discern from saved pics. Missing original tuners, electronics, and pickguard.
H0573 or H0575 - Red. With Bound F Hole, and Baseplateless Vibrato. 4 Bolt Neck with Plate.
Hxxxx - Transparent Green - With Bound F Hole, and Baseplateless Vibrato. 4 bolt (with ferrules) neck. "Diamond" Tuners.
Hxxxx - Red - with Bound F Hole, and Baseplateless Vibrato. It seems like the German Carve is carved strangely.
Hxxxx - Red - with Bound F Hole, and Baseplateless Vibrato. Posted by JustStrings.com on Facebook in 2012. --- https://www.facebook.com/groups/5297862 ... 293372139/
Hxxxx - Red Burst - with Bound F Hole, and Baseplateless Vibrato. Has a Neck Plate. Also has 3 knobs and 2 pickguards and a tortoiseshell truss rod cover, so it seems like Gene Moles assembled this one?
Co Mark XII [12 String:]
G0005 - Sunburst with Sunburst Neck & Black Headstock - Pot Codes read "1346651" (CentraLab, 3rd Week of December 1966.) Says "Helen" in the neck pocket in red. Found in a thread at the forum here from 2011. Has damage surrounding the truss rod slot, it seems like the rod was poorly removed at one point. viewtopic.php?p=46880#p46880
G0011 - Red - Unbound F Hole, Neck Plate.
G0016 - Sunburst - Unbound F Hole, Neck Plate. Sales ad claims pots date to the 50th week of 1966. --- https://www.elderly.com/products/mosrit ... HsLfElzQj1
G0017 - Red - Unbound F Hole, Neck Plate. --- https://www.facebook.com/groups/5297862 ... 361242139/
G0022 - Red. Mentioned here at at Kiyoshi Mochizuki's page: https://www.ne.jp/asahi/mochizuki/kiyos ... rlist.html
G0028 - Red - Unbound F Hole - Bigsby Added. Pics & Page Saved. Sold for $1,890 + $99 shipping, some time from April to July 2023. --- https://reverb.com/item/67114965-1966-m ... -12-string
G0032 - Red.
G0047 - Sunburst - Unbound F Hole. --- https://www.facebook.com/groups/5297862 ... 267167139/
G0064 - Sunburst - Bound F Hole. Pic saved.
G0096 V - Sunburst - Bound F Hole. Pics & Page saved. Seller said the number was "60096 V," but it's probably mis-read.
Gxxxx - Sunburst - Unbound F Hole. Moseley Vibrato Tailpiece. Seen at this Facebook Post, described as being located in Seattle: https://www.facebook.com/permalink.php? ... 9037182483
Gxxxx - Black - Number not stated in listing, and it's difficult to tell what it says but this should be a later one.
1970s Models:
Confirmed Numbers:
c0024 - Sunburst. Says "by Moseley" under Mosrite logo on headstock. Has Gotoh Prsm Tuners. Has Neck Plate. Pot codes 137 71 06 (Centralab Pots, 1971, 2nd Week of February.) Baseplateless Vibrato, and White-Black-White Body Binding. Owned by forum member t-bone. viewtopic.php?f=6&t=7310
Unknown & Not Fully Confirmed Numbers:
cxx3x - Sunburst with Sunburst Headstock - With Bound F Hole, and Baseplateless Vibrato. Has Mosrite Humbuckers, a strange pickguard, and a Neck Plate.
Total Instruments Accounted For:
1960s:
4 String Basses:
11 Known # 4 String Basses (2 with a strange number, one that may or may not be 1970s,)
2 Unconfirmed # 4 String Basses.
6 String Guitars:
78 Six String Guitars
1 Strange # Guitar,
1 Blank Guitar,
2 Parts-rites,
9 Unconfirmed & Unknown 6 String Guitars
12 String Guitars:
10 Confirmed Guitars,
2 Unknown.
1970s:
1 Six String Guitar
1 Unconfirmed & Unknown # 6 String Guitar
Total:
118 Instruments. 103 Confirmed Numbers, 1 Blank, 14 Unconfirmed.
Finishes & Variants Accounted For:
Black
Blue
Burgundy / Dark Red
Green
Red
Red Burst
Sunburst
Reference Photo of a Combo Model for Facebook Preview:
Re: Mosrite Combo (4 String Bass, 6 String Guitar, 12 String Guitar) Serial Numbers List
Postby 101Volts » Mon Jul 03, 2023 10:51 am
Total Updates Tally:
2023:
June 30:
Posted list.
Added Mark Carter's Green H1252, which was stolen from him.
July 3:
Bass:
R0214 - Red - Bound F Hole, Neck Plate.
Guitars:
H0023 - Red - Un-Bound F Hole, and Vibrato with Baseplate.
H0697 - Sunburst. With Bound F Hole, and Baseplateless Vibrato.
July 4:
Guitars:
H0667 - Sunburst. With Bound F Hole, and Baseplateless Vibrato with Patent Number. Not sure of neck attachment - there's a non-original plate over it. https://reverb.com/item/70782355-mosrit ... iginal-hsc
H0677 - Burgundy. With Bound F Hole, and Baseplateless Vibrato with Patent Number. Neck Attached by 3 Bolts in Ferrules. https://reverb.com/item/65793921-mosrit ... gsb019?bk=
H0969 - Red. With Bound F Hole, and Bigsby in place of original Tailpiece. https://www.facebook.com/groups/3294258 ... 882251607/
H1097 - Black. Found here: https://www.facebook.com/groups/3294258 ... 662174825/
Hxxxx - Red. Unknown number, late model run - Bound F Hole, Baseplateless Vibrato. I saved a pic because it looks fairly recognizable. --- https://www.facebook.com/groups/5297862 ... 293372139/
(12 String:) G0017 - Red. Unbound F Hole. --- https://www.facebook.com/groups/5297862 ... 361242139/
Removed H0023 (Red) as it seems to be the same exact guitar as H0231.
Added info of how the necks are attached to which guitars (4 bolt with plate, 4 bolt with ferrules, 3 bolt with ferrules) if I had reference.
Also split 6 String list into sections to show differing construction methods.
July 5:
Bass:
12 String Guitar:
G0047 - Sunburst. Found here: --- https://www.facebook.com/groups/5297862 ... 267167139/
8th of July:
H0923 (Red Burst) updated with a link.
July 27:
H0754 (Red Burst)
17th of August, 2023:
H0066 (Speculated) Added. I can't see the "H" in the pics. Showed up on Facebook Marketplace in South Abington, PA for $1,950. Pics saved.
August 28:
Added a Mystery # 12 String in Sunburst that has no F Hole Binding, but has a Moseley Tailpiece.
October 11:
Changed the list so you can either check the first post, or one of my most recent replies to the thread to find the most recent update. Also changed my first reply to the thread to show how the list grew and was updated.
Also added more details about the finish of H0654.
A photo of a Combo model was re-added to the most recent reply and the main post.
Lastly, I added a likely H1235 (Black) to the post.
October 12:
H0177 (Speculated, Sunburst) added.
October 13:
H0382 (Red Burst) Added. Found here:
October 23:
H0912 (Red Burst) Added. --- https://www.vintageandrare.com/product/ ... urst-72680
November 11:
Added H01003 (Refinished to Natural) to the list.
Also, H1235 is correct for that Black guitar. It was re-fretted with taller fretwire.
November 12:
H1102 (Red, Belt Buckle Rash) Added. - Was on Reverb, early November 2023: https://reverb.com/item/75546292-mosrite-combo-1964
November 20:
Added these from member t-bone:
H0997 - Sunburst, 3 Bolt (with Ferrules) neck. Pot Code 134 68 01.
c0024 - Sunburst. Says "by Moseley" under Mosrite logo on headstock. Has Gotoh Prsm Tuners. Has Neck Plate. Pot codes 137 71 06. Baseplateless Vibrato, and White-Black-White Body Binding. - Update, later in the day: a thread of the guitar was posted here: viewtopic.php?f=6&t=7310
December 10:
H0657 (H06557 misprint) - Red Back, Refinished Front to Black.
H0910 - Blue, 3 Bolt - Added.
Update to H0754, which was parted out - I found more photos from before it was parted out.
December 14:
H01004 (Sunburst) Added.
December 19:
H0408 (Red) Showed up.
H0828 (Refinished to Natural) - https://reverb.com/item/77336706-mosrit ... -s-natural
H1268 (Sunburst) - https://reverb.com/uk/item/45300220-use ... iaEQcDBdVo
December 28:
H0801 found, but no photos.
2024:
January 10:
R0021 (Bass) added.
January 15:
H0760 (Red Burst, 3 Bolt Neck) Added.
January 16:
H0509 (Red, 4 Bolt w/Neck Plate) Added.
January 30:
H0066 (Red) Added.
February 8:
H0975 (Gold, 3 Bolt, 2 Piece) Added.
February 26:
H0802 - Red, 3 Bolt, Added.
April 5:
H0802 updated with potentiometer codes and a note that there are no dates in the neck pocket.
H1258 also updated with the Reverb link that I had omitted.
May 24:
Added:
September 18:
Updated H1235 with information about pot dates.
October 6:
H224 (Red) added.
November 24:
H0014 (Red) added.
December 30:
H0100 (Red) added.
2025:
January 6, 2025:
Added more info to H0003, and also some to H0100.
January 14, 2025:
H0802 (Red) showed up again, but it's already on the list.
February 28, 2025:
H0949 (Blue) Added.
[b]March 3, 2025:[/b]
H1062 (Cherry Red) added.
March 7, 2025:
R0029 (Red) Added. https://reverb.com/item/87453279-1967-m ... -condition
March 18, 2025:
H0875 (Dark Cherry Burst) Added.
April 6, 2025:
H0174 (Sunburst) Added. Told to me by the owner on Facebook.
August 12, 2025:
Added: H0076 (Sunburst.) All original, Pot Codes read 1346647, which is the last week of November 1966.
August 16, 2025:
Many guitars copied from the list here:
Bass:
0145 - Red. This might be R0145.
6 String Guitars:
H0007 - Red
H0553 - Red
H0555 - Sunburst
H0642 - Red
H0723 - Sunburst
H1147 - Red
Blank - 7 Layers of Colors, appears blue
12 String Guitar:
G0022 - Red.
September 1, 2025:
H0136 (Red) added.
September 2, 2025:
H0005 (likely) added. It's advertised as H0003, but I already have that number in the list and it's a faded Red guitar, but 5 here is Sunburst.
I also noticed with this addition that this guitar, H0003, and H0076 have the Mosrite Logo stamped or painted on the inside of the guitar seen through the soundhole. By H0136, there's a sticker instead.
September 15, 2025:
H0461 - Sunburst - Added.
September 29, 2025:
Added these three:
H0145 - Red, Worn. Showed up in France from a Reverb ad around September 25, 2025. --- https://reverb.com/item/92371350-mosrite-combo-1967-red
H0303 - Sunburst. Showed up on in Iowa from a Reverb ad around September 24, 2025. --- https://reverb.com/item/92346213-mosrite-combo
H1259 - Green - Showed up in France from a Reverb ad around September 25, 2025. --- https://reverb.com/item/92371285-mosrit ... 1966-green
Also, updated early construction models with more details of finish and which models I could tell had either a Mosrite Stamp through the soundhole, or a sticker.
September 30, 2025:
Added:
6 String H0154 - Blue (strangely.) Shared with me on Facebook.
12 String G0005 - Sunburst with Sunburst Neck & Black Headstock - Pot Codes read "1346651" (CentraLab, 3rd Week of December 1966.) Says "Helen" in the neck pocket. Found in a thread at the forum here from 2011. viewtopic.php?p=46880#p46880
Also re-organized the list a bit and added further details to model names according to the catalog scan.
October 4, 2025:
SP H0338 or H0338 SP - Red Burst with Red Burst Neck and Black Headstock. Late construction type with Baseplateless Tailpiece and F Hole Binding. The Sticker seen in the body reads "SP H0338., and the neck serial number reads "H0338" and then "SP" is closer to the neck pickup. The pickups were replaced with Rio Grande Mosrite replicas, and the pots aren't original (sadly - there's no word on if they're included in the sale) and the original pickguard was altered but included with the purchase. The knobs included are also the Spun Knob type, which is unclear if they're original or not. The sales ad is copy-pasted and it says the radius is 7.25" and the scale length 22.75", so I'm not sure if the ad is correct or if they didn't proof-red it right. --- https://reverb.com/item/92438858-mosrit ... -red-burst
Also changed term of "Has Patent Number Tailpiece" or "Has Patent Number on Vibrato," etc, to "Has PAF # Tailpiece"
October 6, 2025:
October 7, 2025:
Partsrite added:
October 14, 2025:
Also added R0307 - Red - Bound F Holt, 4 Bolt Neck with Ferrules. Tortoiseshell Pickguard (unclear if this pickguard's original.) --- https://www.gbase.com/gear/mosrite-comb ... 967-cherry
Re: Mosrite Combo model Serial Numbers List (1960s - 1970s.)
Postby 101Volts » Mon Dec 30, 2024 11:33 am
7 - (Only applies to 6 String Guitars, unless there's somehow a 12 string with this tailpiece) - A pic of the Moseley Tailpiece, where it says "Moseley." Some of the tailpieces have a Patent Number, and I'd like to tell when that starts.
9 - Pic of the Neck Heel where it meets the body (if there's a date stamped, which probably doesn't exist past October 1966.)
Body Wood:
Basswood.
Neck Wood:
Recent Updates:
October 6, 2024:
H224 (Red) added.
November 24, 2024:
H0014 (Red) added.
December 30, 2024:
H0100 (Red) added.
Serial Number List:
Mark X (4 String Bass: )
(Note: the Combo and Joe Maphis Basses both started with the same letter, R.)
Mark I (6 String Guitar: )
Confirmed Numbers:
H0014 - Red. Showed up on Reddit. Interestingly, this early version has the truss rod at the headstock, unlike other Mosrites in their early stage. https://www.reddit.com/r/Mosrite/commen ... ite_combo/
H0066 - Red. Showed up at FB Group "Mosrite Guitar Owners."
H0084 - Red.
H0113 - Red - Has a Patent Number on the Vibrato. --- https://www.facebook.com/photo/?fbid=10 ... 5646215229
H0100 - Red - 4 Bolt Neck with Plate. Tuners replaced, and screws for truss rod cover may also be replaced. --- https://reverb.com/item/86377695-red-mo ... _sold=true
H0159 - Red Burst - 4 Bolt Neck with Plate. Mosrite Logo on Headstock is far off-center. --- https://reverb.com/item/67219956-mosrit ... 6-sunburst
H0167 - Sunburst - 4 Bolt Neck with Plate.
H0184 - Sunburst - 4 Bolt Neck with Plate.
H0212 - Red. Seen in comments here: --- https://www.facebook.com/groups/3294258 ... 646215229/
H0224 - Red. Missing Bridge, Bridge Posts, and Bridge Pickup. Found on Reddit: https://www.reddit.com/r/Guitar/comment ... _identify/
H0231 - Red - Also has Humbuckers for some reason, and is or was owned by forum member Brutus.
H0237 - Sunburst - Belongs to Peter Diedrichs. Found at these Facebook posts: --- https://www.facebook.com/groups/mosrite ... 499958378/ --- https://www.facebook.com/groups/mosrite ... 816098613/ -----
H0255 S P - Sunburst - 4 Bolt Neck with Plate. 2 Piece Neck. No date on neck heel. Extra "S P" letters are below the number, closer to the neck pickup. Those may have been the original owner's initials.
H0266 - Sunburst - Original Owner was a metal worker who crafted a baseplate for the bridge, and moved the Vibrato farther away from the neck.
H0308 - Red.
H0358 - Sunburst? - I'm not sure where I read this, I saved no pics or links.
H0382 - Red Burst. 4 Bolt Neck with Plate. Has Patent No. on Tailpiece. Has black & white checkered pickguard. https://www.facebook.com/groups/1048518 ... 125179709/
(Outlier) H0923 - Red / Burgundy Burst. With Bound F hole, and Vibrato with Baseplate. https://reverb.com/item/70927473-66-mos ... w-hardcase
H0667 - Sunburst - Vibrato has a Patent Number. Not sure of neck attachment - there's a non-original plate over it. --- https://reverb.com/item/70782355-mosrit ... iginal-hsc
H0677 - Burgundy - Vibrato has a Patent Number. Neck Attached by 3 Bolts in Ferrules. --- https://reverb.com/item/65793921-mosrit ... gsb019?bk=
H0697 - Sunburst - Vibrato has a Patent Number. 4 Bolt Neck with Plate. Owner replied in the comments here: --- https://www.facebook.com/groups/5297862 ... 702462139/
H0754 - Red Burst. 3 Bolt (Ferrules) Neck, but someone modified it to have a neck plate. Seller said pots / potentiometers dated to Late 1966. Tailpiece had Patent No. on it. Here's a Reverb Ad from before it was parted out by Gibsondependable: https://reverb.com/item/70265025-mosrit ... _sold=true
H0760 - Red Burst. 3 Bolt (Ferrules) Neck, 2 Piece Neck. Tailpiece shows Patent Number on it. Showed up on eBay in early 2024, sold with original case which was kept in the basement while the guitar was in a closet.
H0802 - Red. 3 Bolt Neck. No dates in neck pocket. Pots / Potentiometer Codes' first numbers are 1346704, so these are early 1967 Centralab Pots. Has a black pickguard, probably not original but replaced.
H0997 - Sunburst, 3 Bolt (with Ferrules) neck. Pot Code 134 68 01. Owned by forum member t-bone.
H01003 - Refinished to Natural. 3 Bolt (With Ferrules) Neck. https://www.facebook.com/groups/3294258 ... 794343541/
H01004 - Sunburst. Tuners are Plastic Button Klusons. Pots were replaced. https://www.facebook.com/zanesguitarrep ... ZsyAAE4RBl
H1097 - Black, with Black Headstock. Found Here: --- https://www.facebook.com/groups/3294258 ... 662174825/
H1235 - Black. Pots date to 1968 with E. F. Johnson Pots reading "EP4385 250k 2228." The last 4 digits are supposed to indicate the company, and the "8" is supposed to mean that it's from 1968. Forum member beatcomber posted about it at The Gear Page: https://www.thegearpage.net/board/index ... t-37747799 --- It was also listed on Reverb: https://reverb.com/item/72213730-1960-s ... shell-case
H1243 - Sunburst. Vibrato has a Patent Number. 4 Bolt (with Ferrules) Neck. "Diamond" Tuners.
H1258 - Blue - "Diamond" Tuners. 4 Bolt Neck. https://reverb.com/ca/item/44132418-mos ... lacid-blue
H1268 - Sunburst. 4 Bolt 2 Piece Neck. "Diamond" Tuners. https://reverb.com/uk/item/45300220-use ... iaEQcDBdVo
1970s Models - 1:
c0024 - Sunburst. Says "by Moseley" under Mosrite logo on headstock. Has Gotoh Prsm Tuners. Has Neck Plate. Pot codes 137 71 06. Baseplateless Vibrato, and White-Black-White Body Binding. Owned by forum member t-bone. viewtopic.php?f=6&t=7310
H0177 - Sunburst. Has Patent No. on Moseley Tailpiece. Seen in this Facebook Post: https://www.facebook.com/groups/mosrite ... 736963176/
1970s Models:
xxx3x - Sunburst with Sunburst Headstock - With Bound F Hole, and Baseplateless Vibrato. Has Mosrite Humbuckers, a strange pickguard, and a Neck Plate.
Mark XII (12 String: )
G0032 - Red.
4 String Basses:
6 Known # 4 String Basses (1 with a strange number that may or may not be 1970s,)
6 String Guitars:
52 6 String Guitars (1 from the 1970s.)
9 Unconfirmed & Unknown 6 String Guitars (1 1970s.)
12 String Guitars:
8 Confirmed Guitars,
1 Unknown.
Total: 78 Instruments. 65 Confirmed Numbers, 12 Unconfirmed.
Black
Blue
Burgundy / Dark Red
Green
Red
Red Burst
Sunburst
Postby 101Volts » Tue Aug 12, 2025 4:32 pm
Bump reply.
Body Wood:
Basswood. May also have a Maple Top (I don't have a Mosrite Catalog to refer to.)
Neck Wood:
Tuners:
Recent Updates:
October 6, 2024:
H224 (Red) added.
November 24, 2024:
H0014 (Red) added.
December 30, 2024:
H0003 (Red, Faded) added.
viewtopic.php?f=4&t=8206
H0100 (Red) added.
January 6, 2025:
January 14, 2025:
February 28, 2025:
H0949 (Blue) Added.
March 7, 2025:
March 18, 2025:
April 6, 2025:
August 12, 2025:
Serial Number List:
R0029 - Red - Un-Bound F Hole. --- https://reverb.com/item/87453279-1967-m ... -condition
Confirmed Numbers:
H0003 - Red (Faded) with Natural Headstock. Has Patent Number on Moseley Tailpiece. A Potentiometer (Pot) code reads "1346647," so the pots are from the 4th week of November 1966; therefore, the Combo model should at earliest be a Late 1966 instrument and there should not be any date stamps on the neck heel or in the neck pocket. This example was posted at the forum (thanks!)
H0014 - Red with Natural Headstock. Showed up on Reddit. Interestingly, this early version has the truss rod at the headstock, unlike other Mosrites in their early stage. https://www.reddit.com/r/Mosrite/commen ... ite_combo/
H0076 - Sunburst with Black Headstock. Has Patent Number on Moseley Tailpiece. All original. Pot Codes read "1346647," the 4th week of November 1966.
H0100 - Red with Natural Headstock - 4 Bolt Neck with Plate. The serial number sticker reads "H0010," however. This guitars is also missing a screw (it was never drilled for) on the pickguard near the neck pickup. Tuners replaced, and screws for truss rod cover may also be replaced. --- https://reverb.com/item/86377695-red-mo ... _sold=true
H0113 - Red with Natural Headstock - Has a Patent Number on the Vibrato. --- https://www.facebook.com/photo/?fbid=10 ... 5646215229
H0159 - Red Burst with Red Burst Headstock - 4 Bolt Neck with Plate. Mosrite Logo on Headstock is far off-center. --- https://reverb.com/item/67219956-mosrit ... 6-sunburst
H0174 - Sunburst.
H0308 - Red.
The last two are outliers that are higher in number than the expected range (either D275 or D300 through D400) for the middle construction.
H0802 - Red. 3 Bolt Neck. No dates in neck pocket. Pots / Potentiometer Codes' first numbers are 1346704, so these are early 1967 Centralab Pots. Has a black pickguard, probably not original but replaced. UPDATE, Jan 14 2025 - Showed up for sale again from Elderly Instruments. https://www.elderly.com/products/mosrit ... k_zb_OUbDA
1970s Models - 1:
1970s Models:
G0032 - Red.
4 String Basses:
7 Known # 4 String Basses (1 with a strange number that may or may not be 1970s,)
6 String Guitars:
57 6 String Guitars (1 from the 1970s.)
12 String Guitars:
1 Unknown.
Total: 84 Instruments. 70 Confirmed Numbers, 12 Unconfirmed.
Black
Blue
Burgundy / Dark Red
Green
Red
Red Burst
Sunburst
Re: Mosrite Combo model Serial Numbers List (1966 - 1974.)
Postby 101Volts » Tue Oct 14, 2025 10:36 am
Minor update to R0029.
Users browsing this forum: No registered users and 201 guests
