Mosrite Knobs Falling Off? Simple fix.
Postby 101Volts » Fri Sep 24, 2021 6:11 pm
On some Mosrites, the knobs are a press-fit. Over time, they wear out, and do not hold on. A good example of this is Ricky Wilson's 1966 MK V model, which was missing a knob when it was photographed for the first B-52s album.
(The 1966 MK V, much later. Not the best pic, but the only one I could find online.)
In order to prevent loss of a hard to find M Knob or Spun Knob, you can simply use a drop of superglue.
Alternatively, use some Thread Locker.
Actually, we guitar players should probably use Thread Locker (bought at a car parts store) on different things anyway. I was tired of the pickup selector switch tip (and ring) coming off on my 66 Mosrite, so I used it there. I also used it on the output jack ring, and it works wonderfully; none of the parts ever come loose anymore. I'd suggest using this on guitar tuners, too: it can hold the bushing on, and if it's a cheap acoustic tuner with the screw holding the gear on the post, you can also use it there.
Re: Mosrite Knobs Falling Off? Simple fix.
Postby Sarah93003 » Mon Oct 04, 2021 7:08 pm
Great tips.
duojet55
Postby duojet55 » Thu Oct 07, 2021 12:28 pm
When you have loose press-on knobs, the culprit is usually the pot's split shaft. Using a small flat tip screwdriver, gently bend the two sides of the shaft outward, creating a better grip on the knob's knurling. Be extremely careful not to bend the them too far as the aluminum shaft prongs can be brittle if flexed too radically.
Postby 101Volts » Fri Oct 08, 2021 2:14 pm
Sarah93003 wrote:Great tips.
Thanks, Sarah.
duojet55 wrote:When you have loose press-on knobs, the culprit is usually the pot's split shaft. Using a small flat tip screwdriver, gently bend the two sides of the shaft outward, creating a better grip on the knob's knurling. Be extremely careful not to bend the them too far as the aluminum shaft prongs can be brittle if flexed too radically.
I hadn't considered that. Thanks, Duojet.
Users browsing this forum: No registered users and 680 guests
