How Are Early 70s Mosrites?
MozRite
I hear Semie Mosley went bankrupt and reorganized and went back into business in 1972. How are the guitars from this era? How do they compare to the 1960s models? Thanks
1966 Mosrite Mark V
1969 Firstman Avenger Mark 1
2007 Fillmore Mosrite Mark 1
1964 Gretsch Country Club
1962 Kay Swingmaster
2003 Fender Jazzmaster AVRI
2015 Fender Classic Player '60s Strat
1999 Danelectro Mod 6
2002 Tokai Jumbo Acoustic
Re: How Are Early 70s Mosrites?
I can only speak to the Celebrities. All of the era's were well made. The 1972 Celebrities, to me, are a transition period using up older inventory. For example the 1972's control plate is the same one used on the Mosrite Dobro (Mobro). My favorites are the 1973/1974 era with humbuckers and other options. I also very much like the Celebrity Gospels.
- 101Volts
The biggest differences (aside from the unusual models from the decade) are that the necks are wider (but not thicker, or so I heard,) and you could also get Humbuckers in 70s models.
- 101Volts
101Volts wrote:The biggest differences (aside from the unusual models from the decade) are that the necks are wider (but not thicker, or so I heard,) and you could also get Humbuckers in 70s models.
I really should have mentioned how the frets are taller on 1970s models. Perhaps not on all models right away (though I've never seen an exception in person,) but bit seems that by 1973, they should be using taller and wider fretwire than the 1960s Speed Fret height.
101Volts wrote:101Volts wrote:The biggest differences (aside from the unusual models from the decade) are that the necks are wider (but not thicker, or so I heard,) and you could also get Humbuckers in 70s models.
I have found that to be the case on Celebrities as well. I think 1973 was a purposeful move away from the speed frets of the earlier years.
- 101Volts
Sarah93003 wrote:101Volts wrote:101Volts wrote:The biggest differences (aside from the unusual models from the decade) are that the necks are wider (but not thicker, or so I heard,) and you could also get Humbuckers in 70s models.
I should be a bit more specific. I'm not quite sure that the earliest date for this change-over was in 1973, perhaps it's 1972, but it looks like the date is at least as early as 1973.
The reason is, I have a Mosrite Humbucker dated to late (October or November) 1973, and I've heard of one of the 350 models with its pickups dated to that year. But I'm also not sure when the 300, 350, and Blues Bender 500 models were first introduced for sale. It's a bit hard without having records of all dates on the bottoms of the pickups from each of these models.
It's hard to say for certain. All of the 1972 Celebrities I've seen had the speed frets. If I'm not mistaken, I think the move to jumbo frets went with introducing humbuckers in 1973. There may be a "cross over" specimen. I've seen that before.
- 101Volts
Sarah93003 wrote:It's hard to say for certain. All of the 1972 Celebrities I've seen had the speed frets. If I'm not mistaken, I think the move to jumbo frets went with introducing humbuckers in 1973. There may be a "cross over" specimen. I've seen that before.
Knowing Mosrite, that makes sense. Are there any dated pieces of sales literature we can refer to? I've seen the ad for the 300, 350, and Blues Bender 500 models; however, I saw no date on it.
Users browsing this forum: No registered users and 115 guests
