MK I Neck Removal
kotadawg
MK I Neck Removal
Postby kotadawg » Thu Dec 25, 2008 7:03 pm
How difficult is it to remove and re-install the neck on the MK I? Are there a lot of adjustments that need to be made? Thanks.
Jack
Re: MK I Neck Removal
Postby dubtrub » Thu Dec 25, 2008 7:13 pm
kotadawg wrote:How difficult is it to remove and re-install the neck on the MK I? Are there a lot of adjustments that need to be made? Thanks.
Not difficult at all. First loosen all the strings then remove the neck pickup then remove the neck plate screws. Push the neck in towards the body (as some of them are tight due to the taper of the neck) then lift it straight up.
kotadawg
Postby kotadawg » Thu Dec 25, 2008 9:32 pm
Simple enough. After re-installing, are there any adjustments that have to be made other than tuning? Thanks.
Users browsing this forum: No registered users and 829 guests
