Hi there!
All of the tremolos installed on Mosrites have tremolo string holes not alligned. I wonder why since, for example, Bigsbies are alligned if we can say so.
Is that's some sort of calibration? If yes, do you know "the rule of thumb" for that?
Thanks in advance!
It is crucial for me since I'm making a customized copy with "stratish" string spacing.
Mosrite tremolo drilled holes - not alligned. Why?
Defiler2004
Re: Mosrite tremolo drilled holes - not alligned. Why?
There are discussions about these hole arrangements in this forum. If memory serves, it has to do with tuning stability. The Mosrite patent might give you clues as well.
- LoveyX
Defiler2004
Hmmm, I've digged the forum, thanks for the clues! But Bob Shade's reply on one of the topic also left me thinking. There should be (if any) some real physics behind this pattern, not just "mojo" and that bothers me.
- zarfnober
When a guitar is properly intonated, the bridge saddles will be staggered, the Mosrite tailpiece has the strings staggered almost exactly the same. Also note, if you have a Stratocaster, Fender staggered the pole pieces on the pickups, because(I think I’m correct on this explanation) it put them at the proper height, regardless of the actual pickup height, in the right position to capture the vibration of the strings. If you’re patient, and know a really good setup guy, you can adjust your polepeices the same way, it really makes a difference.
On a final note, and take it for what it’s worth, Loretta Moseley told me that the idea/solution for in tune trem action came to him in a dream. That kind of stuff does happen with inventors. A properly intonated Mosrite will bend in tune when using the whammy bar, thanks to those staggered tailpieces and roller bridge saddles.
Rocco
Rocco
Defiler2004
zarfnober wrote:When a guitar is properly intonated, the bridge saddles will be staggered, the Mosrite tailpiece has the strings staggered almost exactly the same. Also note, if you have a Stratocaster, Fender staggered the pole pieces on the pickups, because(I think I’m correct on this explanation) it put them at the proper height, regardless of the actual pickup height, in the right position to capture the vibration of the strings. If you’re patient, and know a really good setup guy, you can adjust your polepeices the same way, it really makes a difference.
Rocco
Mr. Rocco,
there is another physics behind the 3rd (G) polepiece in strats - simply after music world switched from 3rd wound string to the unwound 3rd, with the setup where all the polepieces were heighted according to the radius made 3rd string sounding too loud (being the thickest if measuring by the core not the winding) thus 3rd is always compensated. As of the Mosrite bridges, almost if not all of them are pre-radiused and you simply cannot change the height of each string separately. This is easily visible on the photos in thread viewtopic.php?t=3539 - there is no compensation on G-string. Same goes with: tune-o-matics, Rickenbackers, etc. With fenders its a "different music" - all saddles could be adjusted individually.
Logically, Mr. Shade's drilling pattern should be more understandable, because it follows the thickness of each string.
Nick
Users browsing this forum: No registered users and 115 guests
