Do the Brass Rail, Bluesbender and S.M. models have the same shape?
Postby 101Volts » Thu Mar 22, 2018 7:32 am
I saw chad3006's topic about Brass Rail plans;
viewtopic.php?f=20&t=7339
I looked and realized the Bluesbender and Brass Rail bodies look very close if not the same.
I then remembered the S.M. model (few of these were made:)
They look like they all share the exact same body shape, only the S.M. model doesn't have a German Carve. Is this the case?
sumlin
Re: Do the Brass Rail, Bluesbender and S.M. models have the same shape?
Postby sumlin » Sun Apr 01, 2018 4:52 pm
Letttttttttt's find out....
They're the same size but the Bluesbender feels like it's made out of lighter wood than the Brass Rail. Hard to tell though as there's more metal and hardware on the BR.
Brass Rail #43
Acoustic Black Widow #BC1092
MkV #B735
sumlin
Postby sumlin » Sun Apr 01, 2018 4:53 pm
Brass Rail #43
MkV #B735
Postby 101Volts » Sun Apr 01, 2018 5:48 pm
Thanks, Sumlin! It makes sense if the Brass Rail's body's heavier to counterbalance the neck. If I recall right, I read that the Brass Rail's body is either made out of Wenge or Black Walnut. Since I have a Brass Rail and they're the same size and shape I might build a Bluesbender copy.
sumlin
Postby sumlin » Fri Apr 06, 2018 4:36 am
101Volts wrote:Thanks, Sumlin! It makes sense if the Brass Rail's body's heavier to counterbalance the neck. If I recall right, I read that the Brass Rail's body is either made out of Wenge or Black Walnut. Since I have a Brass Rail and they're the same size and shape I might build a Bluesbender copy.
Not sure what my Brass Rail is made of, other than the routing looks like it was done at 4.55pm on a friday after a liquid working lunch...
Brass Rail #43
MkV #B735
Postby 101Volts » Fri Apr 06, 2018 4:57 am
I'm not sure if that's stock or not? I know Mosrite's quality in the 70s can be spotty at times.
sumlin
Postby sumlin » Sat Apr 07, 2018 4:35 am
101Volts wrote:
It's factory but maybe not done all at the same time - seems to be routed on the back originally (as though it was going to be a 'Deluxe' Brass Rail) and then re-routed on the top to house controls on a scratchplate (like the ones with brass lower scratchplates).
The scratchplate material is identical though so it was likely done at Mosrite according to those in the know...
Brass Rail #43
MkV #B735
Users browsing this forum: No registered users and 117 guests
