Body Repair.
Brian
Body Repair.
Postby Brian » Tue Dec 16, 2008 10:58 am
I was given a Mosrite body that was "Re-Routed" by someone (not sure why) but now the cavity is larger than it should be, and the pickguard doesn't cover it. Now, I'm a bit weary about cutting a "plug" so to speak and glueing it into the cavity, then routing it again in the correct shape.
My main concern is that the different pieces of wood might expand and contract at different rates causing the finish to crack and show where the repair is. Any sugguestions?
Re: Body Repair.
Postby Mr. Bill » Tue Dec 16, 2008 2:16 pm
I don't think that a properly selected and glued in patch will move any different than the original body wood. Pick a wood of similar characteristics, and install with matching grain and direction.
What will the final finish be?
Brian
Re: Body Repair.
Postby Brian » Tue Dec 16, 2008 2:38 pm
I'll most likley finish it in lacquer. Any clue what sort of wood would (say that three times fast) have been used by Mosrite in '65?
Re: Body Repair.
Postby KRamone27 » Wed Dec 17, 2008 6:58 am
I would say that they were more than likely Alder or swamp ash. But I steer more towards alder.
Brian
Re: Body Repair.
Postby Brian » Wed Dec 17, 2008 10:41 pm
Anyone else?
Re: Body Repair.
Postby dubtrub » Wed Dec 17, 2008 10:56 pm
The production guitars of the '60s were either Alder and Basswood. You will find both. After the original Bakersfield factory closed different woods were used on custom builds but again most were Alder or Basswood.
Brian
Re: Body Repair.
Postby Brian » Thu Dec 18, 2008 10:41 am
Ok, so I've got two votes for Alder (I've also read this elsewhere) and one vote each on Swamp Ash and Basswood... Is there anyway I can tell the difference? Grain pattern? Weight? Etc...
Re: Body Repair.
Postby dubtrub » Thu Dec 18, 2008 11:18 am
Brian wrote: Is there anyway I can tell the difference? Grain pattern? Weight? Etc...
http://www.warmoth.com/guitar/options/o ... ywoods.cfm
Re: Body Repair.
Postby oipunkguy » Tue Jan 06, 2009 11:17 am
most mosrites I've come across are basswood. that is the ventures one/mark one style. i've seen them in alder too, but mostly the japanese models. but again thats just what i've seen. I can't recall any mosrite in swamp ash or regular ash. many times finishers stay away from swamp ash because it's so hard to finish. I had to refinish a custom shop fender swamp ash strat, cuz the finish crack up and separated from the guitar. sometimes you have to put a poly undercoat to keep the nitro lacquer stable enough. amazing tone though, for my money swamp ash is the best wood for guitars with that real nice vintage fender like twang. alder is on the treble side too, but not as much, basswood has more bass with a lot more midrange. a lot of metal guitars are made of basswood, like jacksons, ESP, for example.
most joe maphis/combo models were walnut. at least the back was. it's been so long since I've played one to remember what's on the top. but my guess would be either alder or basswood.
I've always wanted a ventures one mosrite with a mahogany body. I'l make one, some day.
if you could post some pictures of the guitar in question, i could tell you what kind of wood it is.
ps-make sure that the guitar was indeed rerouted out. some mosrites have bigger pick guards, and maybe it was made that why from the factory.
hope this helps,
cheers,
Brian
Re: Body Repair.
Postby Brian » Sat Jan 10, 2009 10:45 am
Cool, thanks for all of the input, I really appreciate it. The body was definitely routed out, and poorly at that (a chisel or two may have also been involved :) ) The pickguard is off by at least an inch and there's some extra holes drilled into the body. It was a pretty bad hack job.
Users browsing this forum: No registered users and 149 guests
