MKII slab body dimensions?
Lordwhimsey
Postby Lordwhimsey » Mon Apr 10, 2017 3:11 am
Hi all,
Could anyone tell me how wide the body of a slab body MKII should be? I've been inspired by all these great build projects and I'm going to have a go at making my own.
I'm trying to work out how big the body should be. I know it's a bit smaller than the MKI; by my calculations it looks like it's about 13 1/2" wide?
If anyone has a tracing they'd like to share they would be even better. :D
Many thanks!
Lordwhimsey
Re: MKII slab body dimensions?
Postby Lordwhimsey » Sat Apr 15, 2017 9:37 am
So in the absence of any evidence to contrary I'm going to go with 13 1/2".
Now does anyone know the dimensions of the headstock?
Dino Boreanaz
Postby Dino Boreanaz » Sat Apr 15, 2017 5:08 pm
Not sure if this will help as it's not a Mosrite, but my Hallmark Johnny Ramone measures right on 13 1/2" wide. The headstock is 7" long from the zero fret and 2 5/8" wide across the top.
Lordwhimsey
Postby Lordwhimsey » Sun Apr 16, 2017 5:27 am
Thanks so much Dino, that's exactly the information I need! Could I be a pest and ask you how thick the body is? Current best guess is 1 5/8" (42mm).
I hope to get a Hallmark Johnny Ramone eventually but until then I'll have to make do with my shoddy attempt!
Dino Boreanaz
Postby Dino Boreanaz » Sun Apr 16, 2017 7:12 am
You're welcome. Your research is spot-on once again ... the body measures 1 5/8" thick. There is some tapered belly/forearm thinning which appears to be equal on the front and back sides taking the thickness down to 1" at the edge of the top-side lower bout as best I can tell given the roundover radius all around.
Lordwhimsey
Postby Lordwhimsey » Mon Apr 17, 2017 9:13 am
Brilliant! Thanks again Dino. I didn't know the underside was tapered as well, thanks for the info.
