Anyone else have this problem? Or Fillmore's QC just suck really bad?
dubtrub wrote:Try loosening the strings, then loosen the screws holding the neck to the body. Now with everything loose, bump the bottom side of the neck upward. Hopefully there is any play in the pocket to allow this and you should be able to center the neck with the strings properly over the pickups. It doesn't take but a fraction of movement of the neck and the problem should be resolved.
Users browsing this forum: No registered users and 750 guests
