WTB Bridge, trem, neck plate for Mark V
sumlin
Postby sumlin » Fri Jan 29, 2016 4:00 pm
I have a 67 Mark V I'm restoring (as a player due to the previous owner sawing the end of the fretboard off to make the neck pickup slanted - doh!) and I need the following parts if anyone can help?
- Bridge (or a replacement that will fit)
- Either the whole trem unit or just the string retaining bar. I have a Firstman unit that fits the guitar but the string retainer section has broken (the metal has snapped at the corner) meaning it doesn't hold the pivot 'bolt' anymore (pics forthcoming). I guess a whole unit would be simpler but if anyone can help with either that'd be great.
- A neck plate (and screws or some advice on correct size)
Thanks!
Brass Rail #43
Acoustic Black Widow #BC1092
MkV #B735
Re: WTB Bridge, trem, neck plate for Mark V
Postby Bob Shade » Fri Jan 29, 2016 4:27 pm
I have everything you need. If you would like to PM me I can give you pricing.
Best, Bob Shade/ Hallmark Guitars
gaz
Postby gaz » Wed Feb 17, 2016 2:32 am
Hello, I have a few spares lying around. A 64-65 fulcrum for the strings, a spring and a base plate. The base plate, I think, is off a Japanese mosrite as there is no 'of California' under the mosrite logo. I could be wrong. The fulcrum is slightly too wide for the baseplate, so some modification is in order on the plate(not the 64 fulcrum). Spring is also standard U.S. Let me know if I can help.gaz
Return to “Wanted”
Users browsing this forum: No registered users and 193 guests
