1976 Mosrite Aluminum Rail Bass Prototype
Postby dorkrockrecords » Wed May 27, 2015 5:05 pm
There's been a decent amount of chatter surrounding this instrument, so it seems only right to post a more or less definitive thread here. I had known about its existence for a number years by way of Bill Gruggett who told me that a bass version of the Brass Rail guitar had been prototyped with aluminum for better balance / reduced weight, but ultimately this experiment met its demise in a factory dumpster. Apparently Bill's account was only half right. Whether fated for the dumpster or not, Semie gave this bass to a Mosrite investor who kept it safe for the next thirty-odd years. And now it's mine.
According to "Gruhn's Guide to Vintage Guitars: An Identification Guide for American Fretted Instruments" which confusingly lists four entries for the Brass Rail in its Mosrite section, a "Standard Bass" was shown at NAMM in 1977. I believe this to be that instrument.
Although the rail itself does appear gold through the yellowed clear coat, at the edges where the finish is chipped the aluminum color can be seen clearly. The pickups are extremely powerful humbuckers set in oversized wooden (or perhaps cardstock) surrounds with tortoise shell tops and brass rings. The two-piece maple neck has the standard Mosrite short scale length, but the sound is huge.
There is evidence that Mosrite did intend to make a Brass Rail bass as well, but to the best of my knowledge only a neck blank exists, and clearly neither of these instruments were put into production. Artie Niesen of Front Porch Music in Bakersfield, CA, has a similarly shaped bass in his collection with a standard adjustable trussrod neck and hardware, circa 1978, but the original greenburst finish is long gone.
Adam
BRRanger
Re: 1976 Mosrite Aluminum Rail Bass Prototype
Postby BRRanger » Thu May 28, 2015 8:01 am
Congratulations on your acquisition! A rare bird, indeed.
Scott
LoveyX
Postby LoveyX » Thu May 28, 2015 8:01 pm
Adam,
That bass is quite a coup, probably one of a kind!
A couple questions if you care to discuss it anymore.
Did the neck stay straight as designed?
How is the action?
Thanks in advance.
Postby dorkrockrecords » Thu May 28, 2015 8:14 pm
Neck's straight, action's low.
Postby 101Volts » Thu Jun 25, 2015 8:31 pm
Thanks for sharing, Adam. And now a question I'm not the only one to be thinking:
How's the sustain?
Postby dorkrockrecords » Tue Jun 30, 2015 8:02 am
101Volts wrote:Thanks for sharing, Adam. And now a question I'm not the only one to be thinking:
How's the sustain?
Excellent. Tonally the bass sits in a range between Rickenbacker and Travis Bean.
Postby Bob Shade » Tue Jun 30, 2015 12:55 pm
Wow! A Rickenbeaner! :shock:
Postby 101Volts » Thu Jul 02, 2015 8:17 pm
How's the sustain?
I already know how the sustain is on one of the guitars even with a set of .10s. Does the bass have even more sustain? (I'd guess so.)
Users browsing this forum: No registered users and 820 guests
