On Mosrite Combos:
Is the body completely hollow or is it considered semi hollow?
Is the body chamber routed out of a solid piece or are the sides bent plywood?
Is the top carved on the bottom side to match the german carve on the top side?
Are the tops of consistent thickness? If so, how thick?
questions about Mosrite Combos?
chad3006
Re: questions about Mosrite Combos?
1) the body is completely hollow
2) the construction is similar to a Tele slimline, except the top is thicker and has some hogging out too.
3) Carve is on top only
4) the tops are about 1/2" thick, but thinner, maybe 1/4", around the sound hole.
Long and short of it - these are really cool guitars.
chad3006
Yes, I have never met one in real life, but from recordings I've heard, they are really sweet sounding guitars.
Thanks.
Thanks.
Users browsing this forum: No registered users and 497 guests
