Mosrite Ventures Build
Postby 101Volts » Tue Jun 24, 2014 3:38 pm
So far (As of this posting time) I have a body blank (Not fully routed) made with Poplar and it's made with a template bought from eBay. Is that the proper placement for the bridge? I'm wondering if that's where a Tune-O-Matic would be drilled or if it's where the actual Mosrite Ventures Bridge and Vibrato (or stop-tail) are to be placed.
I think the neck pocket tracing is a bit off in this photo. Thoughts?
Re: Mosrite Ventures Build
Postby 101Volts » Sat Mar 07, 2015 4:07 pm
It's months later and I'm still wondering what people think about this.
Postby GattonFan » Sat Mar 07, 2015 5:06 pm
It does look like the neck angle-to-body is too much - just from this photo.
rcblair
Postby rcblair » Sun Mar 08, 2015 6:54 pm
Hey, it's only been 8 months. People on this forum like to think about their answers before they post. :)
I would make a cardboard mock-up of the neck and place it on the lines to see if it looks right. The Mosrite guitars look like they have a bit of an odd angle between the neck and body but those lines do look extreme.
Rick B.
Postby panther » Mon Mar 09, 2015 8:48 am
Two things jump out at me. One, The neck angle. Two The tail stop holes look misaligned to the bridge holes. The than that, the project look great. At ;least those two I mentioned are easy to change if in fact they are off.
Dimeman
Postby Dimeman » Mon Mar 09, 2015 9:39 am
Looks to me the top needs to be moved to the right a little and the bottom moved to the left a little.
Robbie
Postby 101Volts » Thu Mar 12, 2015 10:02 am
GattonFan wrote:It does look like the neck angle-to-body is too much - just from this photo.
I was thinking so. Thanks, Dennis.
rcblair wrote:Hey, it's only been 8 months. People on this forum like to think about their answers before they post. :)
Rick B.
Heh. I don't have a neck made now, but I do have a neck template that came with the template. I haven't made a guitar fully before, but no better time to learn than in the now. Thanks, Rick.
panther wrote:Two things jump out at me. One, The neck angle. Two The tail stop holes look misaligned to the bridge holes. The than that, the project look great. At ;least those two I mentioned are easy to change if in fact they are off.
I think I cut the neck pocket (changed from where it was in this photo) before I replied to the topic. But thanks, Dan. I do have more Poplar to work with if needed.
Dimeman wrote:Looks to me the top needs to be moved to the right a little and the bottom moved to the left a little.
Thanks, Do you mean the bridge post holes?
Postby 101Volts » Tue Apr 24, 2018 7:06 am
OK, so nearly a full 4 years later I began working on this project again; I've routed the first step of the German Carve. Nothing else is done yet.
Postby panther » Tue Apr 24, 2018 8:41 am
Post a few photos.
Users browsing this forum: No registered users and 574 guests
