Mosrite Brass Rail Models Serial Numbers List (1976 - 1978, Les Paul-ish Shape) (Brass Rail Registry?)
Re: Brass Rail Registry?
Bumping this in light of recent serial registry posts on the Stereo and Bluesbenders...
Brass Rail #43
Acoustic Black Widow #BC1092
MkV #B735
MkV #B735
- 101Volts
Deluxe #7 is on eBay again and the neck is either sunburst or natural on the back. It's also a set neck model.
https://www.ebay.com/itm/1976-Mosrite-B ... SwpDdVa3UC
My Deluxe #10 also has a set neck.
- 101Volts
101Volts wrote:My Deluxe #10 also has a set neck.
BTW, although Deluxe #10 has a set neck it looks as though it may have been drilled to be a bolt-on at first; either that or they inserted dowels into the neck to help keep it in place, I don't know. I think the former idea's more likely.
- 101Volts
I'm bumping this up because I found Deluxe #11. In light of what Adam mentioned earlier, that Brass Rails must be separated into different batches, I've changed the list; I've separated the deluxe models out of the others. I'm not sure what else to do at this point, or if I even should put all the deluxe models together. Sorry if this isn't quite correct yet.
Deluxe Models:
3 - Black - sold by a mosriteforum member
5 - Black, commemorative plaque on back of body - for sale by Expat Guitars
7 - Black, commemorative plaque - for sale on EBay in Michigan 2014
10 - Black - owned by Austin (101Volts)
11 - Black - Owned by forum member Eric L. viewtopic.php?f=20&t=7210
38 - Black - owned by forum member coanda
All other models:
6 - Standard, Greenburst - owned by Expat Gtrs
8 - Standard, Cherryburst w/white binding - owned by Expat gtrs
22 - no more info other than it was for sale in 2010 and is mentioned as a 'Gene Moles Custom' - is this the BR neck on Celebrity body?
24 - Standard, Black - commemorative plaque, owned by forum member dtribby
26 - Gruggett Custom, sunburst with white binding - owned by Expat Gtrs
35? - Gruggett Custom - constructed with unique body shape for Expat Gtrs in 2010.
43 - Standard, Black - owned by me.
48 - Gruggett Custom, black with chequered binding - owned by Elisha Weisner
49 - Standard, Black - with Moseley trem, assembled by E.Elliott - (was?) owned by forum member The Jester
74 - Standard, Red - sold on EBay in 2008
76 - Gospel (Celebrity shape), Honeyburst - built for Rev Beatty, owned by Expat Gtrs
80-something - Standard, dark red - owned by forum member Beatnikbandit
82 - Standard, off-white - sold by Expat Gtrs in 2009
84 - Standard, off-white - owned by Expat Gtrs
102 - Standard, off-white - for sale on EBay 2014, has been refinished
125 - Standard, sunburst - owned by Expat Gtrs
D1 - Dolly Parton Acoustic
No serial - Wenge, 3 pickup - made for Mark Moseley, owned by Expat Gtrs
No serial - Wenge, 2 pickup - owned by Expat Guitars
No serial - Gruggett Custom, surfburst - built 2012 (from old BR neck?), owned by Expat Gtrs
No serial - Gruggett Doubleneck, natural ash - built in 1976 for Lonnie Hyde
No serial - Gruggett Doubleneck, black with white binding - built in 1983 for Waco Shan
Not known - Standard, Black - owned by Efrim Menuck
N/K - Prototype, Black with large scratchplate and angled neck pickup, full Moseley trem - in the Phil X Fretted Americana 2012 You Tube Special
N/K - Standard, Black - shown as for sale in Michael Mark's Mosrite website in unfinished (and unfretted?) state
N/K - Gene Moles Custom - Celebrity body and BR neck. For sale on EBay 2009. Is this #22?
N/K - Standard, Black, white pickguard - pictured online but looks like it may not be a Brass Rail, possibly a Bluesbender or SM with changed hardware. Full Moseley trem. Owned by M. Ayukawa
and then there are 2 modern Gruggetts both owned by Expat Guitars that are serials 1 and 2 but have been built from new necks presumably.
Deluxe Models:
All other models:
- 101Volts
Correction, and note, added to #43. No new instruments at this update.
Deluxe Models:
May have been a Deluxe at one point:
43 - Standard, Black - owned by Sumlin. Doesn't have Deluxe electronics, and it had a 1 vol. 1 tone setup when he bought it. It also had much crude routing done to it, and a non original pickguard over this routing.
All other models:
Deluxe Models:
All other models:
- olrocknroller
There is a photo on the 'net of Nokie playing one...whether it was his or not isn't given in the comments...
- 101Volts
Notes to No. 49 (which has been moved to a "partsrite" section) and the "Prototype" in the Unknown Numbers section added; they may be the same guitar. Fretted Americana may have seen 49 on eBay in 2010, bought it, and put it up for sale. It's possible, since there are only 3 Brass Rails with a Moseley Vibrato. This is according to Ed Elliott, who assembled the 3 as partsrites.
Deluxe Models:
7 - Black, commemorative plaque - for sale on eBay in Michigan 2014
Partsrites:
49 - Standard, Black - with Moseley trem, assembled by E.Elliott in 1978 if I remember right. (Was?) owned by forum member The Jester. It was for sale on eBay in late 2009 and/or early 2010, and Fretted Americana may have bought it for resale.
All other models:
N/K - "Prototype," Black with large scratchplate and angled neck pickup, full Moseley trem - in the Phil X Fretted Americana 2012 You Tube Special. This may be No 49. It's not a prototype, it's a partsrite that Ed Elliott put together. Ed put 3 Brass Rails together with a Moseley vibrato.
Deluxe Models:
Partsrites:
All other models:
- 101Volts
No. 69 (White) added. I've also rearranged the list.
Deluxe Models - 6:
May have been a Deluxe at one point - 1:
Gruggett Instruments - 8:
1: Owned by dorkrockrecords.
2: Owned by dorkrockrecords.
Mosrite and Gospel Models - 12:
69 - White. Formerly owned by Steve Young.
Partsrites - 1:
Ed Elliott assembled 3 Partsrites just like this one.
No Serial Numbers - 2:
Unknown:
? - Standard, Black - owned by Efrim Menuck
? - "Prototype," Black with large scratchplate and angled neck pickup, full Moseley trem - in the Phil X Fretted Americana 2012 You Tube Special. This may be No 49. It's not a prototype, it's a partsrite that Ed Elliott put together. Ed put 3 Brass Rails together with a Moseley vibrato.
? - Standard, Black - shown as for sale in Michael Mark's Mosrite website in unfinished (and unfretted?) state
? - Gene Moles Custom - Celebrity body and BR neck. Was for sale on eBay in 2009. Is this #22?
? - Standard, Black, white pickguard - pictured online but looks like it may not be a Brass Rail, possibly a Bluesbender or SM with changed hardware. Full Moseley trem. Owned by M. Ayukawa
Deluxe Models - 6:
Partsrites - 1:
Unknown:
- 101Volts
No new models have surfaced yet, this update's mostly to make the list easier to navigate.
Deluxe Models - 6:
May have been a Deluxe once - 1:
Partsrites - 1:
Unknown:
? - "Prototype," Black with large scratchplate and angled neck pickup, full Moseley vibrato - Was in the Phil X Fretted Americana 2012 You Tube Special. This may be No 49. Whether or not it is, it's not a prototype; it's a partsrite that Ed Elliott put together in 1978, if I remember right. Ed put 3 Brass Rails together with a Moseley vibrato.
Deluxe Models - 6:
Partsrites - 1:
Unknown:
- 101Volts
Second update today, since I remembered about one that Ed Elliott assembled. It's not a Mosrite instrument, but it does deserve its spot on the list.
Deluxe Models - 6:
E. F. Elliott Instruments - 1:
? - Built for Michael Gnapp in the 1970s. Ed posted about this on Facebook on March 9, 2020.
Partsrites - 1:
Ed Elliott assembled 3 Partsrites just like this one. I'm not going to put those in the list yet, since I don't know what color their finishes are.
Unknown - 5:
Deluxe Models - 6:
Partsrites - 1:
Unknown - 5:
Users browsing this forum: No registered users and 464 guests
