Pickup for Selmer style guitar
Postby MWaldorf » Mon Mar 31, 2014 1:36 am
I've got a cheap knockoff Selmer/Maccaferri style guitar, and I wanted to amplify it. Pickups for Selmers are special purpose and expensive, so I decided to take a crack and making my own.
My main requirement is that whatever I made couldn't include permanent modifications. There's not much room under the strings, so I decided the best solution was a pickup/bridge combo. I made a steel base plate and mounted a coil from an Epiphone humbucker. The coil is held in place by the pole screws. It was important to use pole screws so I could adjust for the lower output of bronze wound strings. There was no room for a magnet below, so I mounted it alongside the coil in a channel in the plate - the steel holds the magnet in place, and the magnet magnetizes the steel plate and the poles. I used a couple of screws mounted from underneath to be the bridge posts. Finally, I sprayed the base plate with some bronze rustoleum.
As you'd expect from a pickup mounted so close to the bridge, it's very bright. Kind of goofy, but it works!
Here's the result:
View from below:
And mounted:
Re: Pickup for Selmer style guitar
Postby Bob Shade » Mon Mar 31, 2014 5:25 am
Reminds me of an early Les Paul gizmo.
Postby Mr. Bill » Mon Mar 31, 2014 10:02 am
Yes, but made with a higher level of craftsmanship. Nice job, Mel.
Technically there are some things that I don't understand, but if it works, cool.
Postby dubtrub » Thu Apr 03, 2014 5:00 pm
New ideas are always spinning around in Mel's head. What will he think of next! :o
Postby Dennisthe Menace » Fri Apr 04, 2014 7:02 am
A THREE Pick-up Version :shock:
Postby MWaldorf » Mon Apr 07, 2014 11:29 pm
Three pickups??? Why, I never thought of that!
Here's a quick video demo:
http://youtu.be/uI1_AR7pahc
Haole Jim
Postby Haole Jim » Sun Dec 28, 2014 12:42 am
Mel, tres clever and great process-engineering, good on you.
Finished project looks reaaly nice...a vibrato on a Selmer-style! Whodathunkit?
Users browsing this forum: No registered users and 271 guests
