Weird string height problem on my Deke
TriflerShawn
Postby TriflerShawn » Thu Jul 25, 2013 7:15 am
Greetings all............I've noticed a weird little "issue" on my Deke.
It appears that either the A string is sitting a bit low, or the E is riding high.
Look at the pics below........ It really doesn't bug me that much, but it has tripped me up
a few times when I'm transitioning from the E to the A. Any ideas?? Maybe that's the wrong saddle?
String guage might be to big for saddles and the E is riding a bit high?
Re: Weird string height problem on my Deke
Postby Bob Shade » Thu Jul 25, 2013 1:51 pm
Like on the rest of our Hallmarks, I designed the bridge saddles themselves to be uniform to the radius of the fingerboard unlike Mosrite which has rollers that are different heights.
So, the two E strings should be the lowest pair, then the A and B should be the second lowest pair, then the D+G should be the highest pair.
Hope this helps.
TriflerShawn
Postby TriflerShawn » Thu Jul 25, 2013 2:44 pm
Bob, that's how it is on my 60C and Hallmark II. There is a gradual rise from the lower E to D.
On my Deke, the A is slightly LOWER that the E, so it cause a bit of a problems when transitioning from string to string.
It's not a huge problem, but it's a bit weird.
Postby dorkrockrecords » Thu Jul 25, 2013 3:39 pm
So just try swapping the position of those two saddles and see if that does the trick.
TriflerShawn
Postby TriflerShawn » Thu Jul 25, 2013 8:14 pm
dorkrockrecords wrote:So just try swapping the position of those two saddles and see if that does the trick.
That's my plan. :D
Postby Bob Shade » Fri Jul 26, 2013 7:41 am
Yes the previous owner could have played with the bridge. Let me know how it works out.
Oh, one more thing, when tightening the locking pins on the bottom of the saddle, turn them until they are just snug. Do not attempt to tighten it down hard or the threads in the saddle will strip. I do have a fix for that too if it were to happen but try to be careful.
Let me know if you need any further assistance,
Best, Bob
TriflerShawn
Postby TriflerShawn » Fri Jul 26, 2013 8:39 am
Thanks Bob!
MarkyKobane
Postby MarkyKobane » Fri Aug 02, 2013 7:58 pm
Bob,
Quick question.
Hope it's not too stupid or wasting your time.
The last few times I've played my low E pops outta the saddle.
Should I raise the action?
File down saddle?
Buy new bridge off ya?
Strings are pretty new, maybe bum set? D'addario 11's.
......or even better should I just buy 3 more Hallmarks as back up?
:lol:
Postby Bob Shade » Sat Aug 03, 2013 5:50 am
While I really like the last option the best, try raising the action a hair and use the heavy spring included with your guitar. You must really hit the strings!
1234!
MarkyKobane
Postby MarkyKobane » Sat Aug 03, 2013 7:03 pm
Haha! heck yeah I do! At least that's what I am told. I think when I go to palm mute I punch the bridge and/or saddles. It usually happens when I am playing live and/or heavy drinking is involved!
THANKS AGAIN BOB!
Return to “Hallmark Guitars”
Users browsing this forum: No registered users and 152 guests
