Buzz, buzz, buzz...not talking about bees.
timtwo
Postby timtwo » Wed Jul 03, 2013 12:12 pm
Hi All,
I am the proud owner of a very clean late 60s early 70's 2 p/up mosrite bass.
My bass buzzes/hums pretty loudly...and it is not a constant or consistent sound either.
It changes intensity depending on the angle that I am playing in regards to my amp/speakers...up down left or right.
I could be right on top of the amp or 15 feet away and it wouldn't make any difference.
I don't believe it is a grounding issue...there is next to no popping/snapping when I touch metal parts.
I expect a bit of noise from old p/ups but not this much...is there anything I can do to remedy without slapping a bunch of
goop or adhesive in the body of the bass? Or is this just the nature of the beast.
Thanks in advance all!
Tim
Re: Buzz, buzz, buzz...not talking about bees.
Postby panther » Sun Jul 14, 2013 10:42 am
3 things come to mind.
1-Ground
2-cable
3-Feedback
I would try setting my amp at an angle, leaning back to see if that might help cut down on possible feedback. Try another cable.
I suspect a loose wire or bad ground.
timtwo
Postby timtwo » Mon Jul 22, 2013 8:54 am
Hey Dan,
Thanks for your input.
The cable is a ok...I use it on a Jazz Bass and it sounds clean as a whistle.
The ground I am unsure of but I have taken off the pickguard and inspected the wiring to the
best of my ability and everything seems tight and connected...and I dont get that "pop" when touching
metal on the bass.
Looks like I may just have someone who knows what they are doing take a look and get some more
professional advice...my knowledge on the inner workings of electronics if minimal.
rcblair
Postby rcblair » Tue Jul 30, 2013 8:47 am
There is a ground wire going to the bridge also. Check to see if the connection is intact. If the noise stops or decreases when you touch the strings that is a good indication that the bridge isn't grounded. The pickups are sensitive to noise from flourescent and neon lights also.
My 65 bass is a lot noisier than it used to be. I had hacked up the wiring before I knew anything about circuits so I need to check to see if anything is wonky. The potting in the pickup looks like it has dried out over time so I wonder if that might be a contributor also.
Rick B.
Users browsing this forum: No registered users and 518 guests
