Mosrite Mk II project and a few questions
marcus
Postby marcus » Fri Apr 26, 2013 5:52 pm
Hi,
So I decided that I want to build a Mark II. As of now I'm just looking up the materials and tools that I will need.
I have so far two questions that I haven't figured out yet, is the shape of the Mark I the same as the Mark II? Since that's what the template from Guitar building templates is, right? And is there any plans/traces of the pickguard available somewhere?
Thanks in advance!
Re: Mosrite Mk II project and a few questions
Postby KRamone27 » Sat Apr 27, 2013 5:35 am
Hi Marcus, the MK1 and MK2 are two different animals. The body's and necks have two very different shapes and routes. The templates online are for the MK1. Kevin
Postby Bob Shade » Sat Apr 27, 2013 6:05 am
I think you may be speaking of a Mark V or Ventures II. There were two versions of the Ventures II.
marcus
Postby marcus » Sat Apr 27, 2013 6:12 am
I guess I should have said in the beginning that I want to build the same model as the ones Johnny Ramone played.
Could I still use the template if I change the routing, the pickguard and made the neck straight at the end or would it look weird?
SanchoPansen
Postby SanchoPansen » Sat Apr 27, 2013 6:31 am
I guess you mean like this
or like that?
marcus
Postby marcus » Sat Apr 27, 2013 6:50 am
SanchoPansen wrote:I guess you mean like this
or like that?
Like the second one except for that I'll use a humbucker at the neck and a single coil at the bridge.
marcus
Postby marcus » Sat Apr 27, 2013 3:40 pm
I found this blueprint:
https://dl.dropboxusercontent.com/u/876 ... 20Body.pdf
I'm guessing it's the second version of the Venture II, is there a big difference in the outer shape of the body? Compared to the first.
Postby 101Volts » Sun Apr 28, 2013 4:17 pm
Yes, That blueprint is of a later model Ventures II. I'm not sure if they have the same body shape as the Ventures II "Generation I" Model.
marcus
Postby marcus » Mon Apr 29, 2013 3:37 pm
I compared it with a Johnny Ramone Mosrite and the only difference seem to be that the neck is connected to the body at a different angle. And tomorrow I'll see if I can get the it printed on one paper. So I guess the biggest problem is solved. Thanks for all the help so far!
Users browsing this forum: No registered users and 60 guests
