Help with serial number dating
4th Dimension
Postby 4th Dimension » Fri Apr 19, 2013 5:55 pm
Evening all,
I'm looking to get some dates on 2 Combo serial numbers I have the opportunity to buy. I find it funny that they both need a little work and their serial numbers are eerily similar :shock:
H-0377
H-0733
It's like yin and yang here. One needs some body repair, the other needs a refret and a new tuner.
Any insight will help a lot!
Thanks.
-4th Dimension
BRRanger
Re: Help with serial number dating
Postby BRRanger » Mon Apr 22, 2013 3:18 pm
Hi 4th Dimension...
I'll check the serial number on my Celebrity III, when I bought it from Gruhn back in the '80's, it was list listed as a '67, but I'm not sure if the III was made that early. I don't have the s/n with me, but will check it when I get back home Tuesday.
Scott
dave m
Postby dave m » Mon Apr 22, 2013 3:40 pm
My Combo # H-1266. I have been told it is a '68
BRRanger
Postby BRRanger » Mon Apr 22, 2013 4:07 pm
Sorry 4-D, just read Dave's reply and realized I replied re: a Celebrity, I also have a Combo, I'll give you the serial number Tues/Wed, mine is an excellent-mint Candy Apple Red '67 or '68, came with the original case, hang tags, Manual, extra spring w/tag, warranty card and white Mosrite strap and came out of Clovis, not far from Bakersfield.
Scott
jeffee
Postby jeffee » Tue Apr 23, 2013 7:47 am
as far as i know.. you cannot tell the year from the serial number.. (like someone said.. they'd make the serial number your birthday, your favorite numbers, or whatever you wanted it to be.
pot dating is the best way..
and somewhere in 66 they went from pickups with no ® after the logo - to pickups with a ® after the logo.
but the pots are your best bet for gettting close on the year
jeffee
Postby jeffee » Tue Apr 23, 2013 7:51 am
my Combo pots date to august 1965... and my serial number stamped on the neck is: H 097504
4th Dimension
Postby 4th Dimension » Tue Apr 23, 2013 10:01 am
dave m wrote:My Combo # H-1266. I have been told it is a '68
Thanks Dave!
The Combo I went with was H-0733. It was local and required the least amount of work between the 2. The other Combo required a total refret and was missing a tuner. I'll have to check my pots to get a proper date.
jeffee wrote:my Combo pots date to august 1965... and my serial number stamped on the neck is: H 097504
My Combo doesn't have a serial number stamped on the neck. So many inconsistencies with these guitars it seems!
Guitar has been drilled and plugged, I reset the vibrato, now to just buy an arm from Bob @ Hallmark and I'll be ready to get her up and running :mrgreen:
4D
jeffee
Postby jeffee » Tue Apr 23, 2013 10:35 am
you'll love the combo!
BRRanger
Postby BRRanger » Wed Apr 24, 2013 10:05 am
Ok, my Combo s/n is H1210...I was told it's a 67 or 68.
Scott
Users browsing this forum: No registered users and 135 guests
