Greetings. I've posted in this forum a couple of times asking for advice about an issue I was having with my guitar, and I've received some pretty solid advice. Thanks for that. The issue I am having is that my strings are consistently breaking at the bridge, usually the E or D strings. I asked a few people about it and it was suggested that I go to a jeweler to have the bridge de-burred and polished. I took it to one today, and he basically just suggested I do it myself, which makes sense. I went out and bought a precision Dremel and a sanding / polishing kit and some 3 in 1 oil. I've only used the wire brush so far because the battery on the Dremel needs to charge, but I'm already seeing a marked improvement. The bridge is coated in corrosion, and it was transferring to the strings and weakening them. After I get all the corrosion off and lube it up with a little oil, it should be smooth sailing. Below is a link to an imgur album containing some photos of the guitar and close ups of the components. I'd appreciate it if any of you could take a look at the photos and tell me anything you think I should know. Cheers.
http://imgur.com/a/QBC3v
Kurokumo Super Excellent 65
- c4103
- FritzCat
Re: Kurokumo Super Excellent 65
Are you sure they were breaking right at the bridge? I was having problems with the B and E strings breaking right around the ball end, which I solved by coating the twists at the end with solder. Apparently D'Addario now sells strings with this already done> http://tinyurl.com/coj8apf
- c4103
Interesting. I'll try that if I have any more problems. I took apart the bridge and sanded & polished every part, put 3 in 1 oil on the rollers.
khai123
Had a similar problem breaking my E and B all the time, but I attributed it to using my tremolo too dramatically (which is more than true) so I blocked it to stave off temptation and continued on.
Thanks,
Eyan
Thanks,
Eyan
- c4103
So, a little update on this. After my last post, I took apart the bridge piece by piece and grinded / polished every part meticulously for basically an entire day. I also added some 3in1 oil to the roller surfaces for even greater friction reduction. It's been about a month and I haven't had any problems yet. No snapped strings, and the tremolo floats like a dream. Apparently there was some metal corrosion on the bridge that was transferring onto new strings very quickly and weakening them, causing them to snap. Gotta keep it clean!
Users browsing this forum: No registered users and 304 guests
