Does anyone know where I might find replacement intonation screws/acorn nuts for a MIJ (Fillmore/Firstman?) copy. I have tried 4-40 machine screws, and the metric equivalent, and neither of these fit as snugly as the originals. Any suggestions?
MIJ Mosrite Roller Bridge question
Re: MIJ Mosrite Roller Bridge question
GattonFan wrote:Does anyone know where I might find replacement intonation screws/acorn nuts for a MIJ (Fillmore/Firstman?) copy. I have tried 4-40 machine screws, and the metric equivalent, and neither of these fit as snugly as the originals. Any suggestions?
It DOESN'T FIT?!?
swapping one of the acorn nuts with your other guitar? If I remember correctly, both of
your guitars are MIJs? And if so, you should be able to swap acorns with no problem.
HOWEVER...if that's not the case, well, you might possibly have an American Bridge on
your Second guitar. And I believe the spacing between the Bridge Screws are that the
Bridge will fit with a little aggressive pressure without wrecking it, but I believe they will
fit. BUT, if that is the case, then maybe you need the acorns that are UNIVERSAL fit....
Users browsing this forum: No registered users and 64 guests
