combo bolt on neck question
dave m
Postby dave m » Sat Jun 23, 2012 1:06 am
I own a 68 combo and am curious about the different methods used to bolt on necks. 3 bolts or 4 bolts with or without neck plate. Is there a timeline for variations?
evolution or convience?
Re: combo bolt on neck question
Postby olrocknroller » Sat Jun 23, 2012 6:55 pm
It has been seen on this forum...some folks use...NAILS!!! :shock:
ElBrewski
Postby ElBrewski » Thu Jun 28, 2012 4:00 pm
Dave, my combo has 3 screws with no plate. You can see it on the pics in this thread:
http://www.mosriteforum.com/forum/viewtopic.php?f=6&t=5225
Unfortunately it's also the one that has (friggin) nails on the inside neck attach - they just should have been screws.
So it's important to remember that the neck attach screws on the back of the guitar may not be the only ones and you have to remove the neck pickup to see if yours has inside screws (and hopefully not nails).
Postby GattonFan » Thu Jun 28, 2012 4:54 pm
My '68 has the typical 4-screw, kidney-shaped neck plate.
dave m
Postby dave m » Sun Jul 01, 2012 6:11 pm
My 68 has 4 screws no neckplate. serial # h-1266. do you think mine is a later model?
surf-liner
Postby surf-liner » Tue Oct 16, 2012 2:07 pm
FWIW, my Ventures-style bass is a '65 and the neck is attached with 3 screws, no neck plate. It's my understanding that Mosrite did not exactly suffer from an excess of quality control.
The AmpFibian
Postby The AmpFibian » Tue Oct 16, 2012 6:36 pm
My H767 (year?) Combo has 3 screws and no plate. The washers seem to be cracked but still doing the job..if I ever loosened the neck screws the washers would probably fall apart and need replaced.
Users browsing this forum: Bing [Bot] and 521 guests
