Info On 350 Bass Pickups
raygun85
Postby raygun85 » Mon May 28, 2012 2:53 pm
Looking for info on the 350 Stereo Bass Pickups...I'm assuming they were probably about the same as the Moseley humbuckers, internally. Anyone know the pole spacing? Especially on the neck pickup?
Re: Info On 350 Bass Pickups
Postby oipunkguy » Mon May 28, 2012 10:11 pm
why wouldnt they be any different then the single coil bass pickup spacing? besides adjusting the coils for the angle?
raygun85
Postby raygun85 » Tue May 29, 2012 12:07 am
Just trying to cover all the "basses". ;)
Postby oipunkguy » Tue May 29, 2012 2:19 am
sure I can understand that. on my guitar versions, the 350 model i have the pickups were wound to about 10k for each pickup, my v II models were 5.5 or so, but ran in parallel. also a small note, the VII versions had the screw hole on the pickup cover drilled big enough so the whole screw could go all the way into the pickup, but the 350 model I have, the holes were drilled just big enough so the threaded part of the screw could go in, but not the head. I personally didnt like this because when the screw was tighten down if caused warp in the plastic cover, so i modded my own so the screw head would go all the way through. not sure if this infomation is any use to you, but hey, there it is. :)
Users browsing this forum: No registered users and 742 guests
