I have a question for anyone that may be able to help me. 1 of my Mosrite pickups has virtually no magnetic pull and therefore has almost no sound coming from it. I can return it but if it is easy to recharge the magnet I would like to give it a try. I don't think I can hurt it anymore than it is. My question is, does anyone know how it can be done? It reads 11.5k and everything else looks ok with it. I have a PM into EFElliot but have not heard from him as yet. Any info is appreciated.
Pickup repair???
- sleeperNY
Pickup repair???
Re: Pickup repair???
The original Mosrite single coil pickups are very similar in construction to a Gibson P-90.
The screw/polepieces extend through the coil and tie into the two magnets under the coil form. If yours has lost its magnetic charge, then both magnets have either become discharged or they may have been installed incorrectly.
If you need to recharge the magnets, you will have to disassemble the pickup in order to charge each magnet.
Jim,
That ALMOST sounds like one of the wires to the pick-up might be 'grounding out' against
something else in the control cavity. Sometimes when something gets grounded, it doesn't
always quit working completely, but might work anywhere from 1/3 to 1/2 the power output.
Before you replace the pick up, I think I would "raise and check under the hood" to see if
everything looks good, and not getting 'pinched' somewhere.....
- sleeperNY
I heard from E.F.Elliot this morning and he also said that 1 of the magnets may be flipped over causing it not to work. He also said that the way these pickups are made it is not easy to open them up without hurting something inside. These have something like a bondo material sealing the bottom and I see no good way of opening them up. I am waiting to see what it will cost from E.F.Elliot for him to repair. I haven't had much luck from where I got them. I don't think Curtis sent anything knowing there were problems with them, I just think he is at the bottom of his parts and what is left isn't as good as they could be.
