Hi, I saw this case on eBay. The seller describes in the ad: "a vintage 1966 Mosrite Celebrity II guitar case"
http://www.ebay.com/itm/270928915122?ss ... 1423.l2649
Was this the original case Mosrite used for 1966 Mosrite Celebrity? Or it was an after market case? I thought shaped cases were used for Mosrite Celebrity Series. Could both rectangular and shaped cases were used in 1966?
I know this case won't fit my other regular Mosrite guitars so I have to be certain.
Thanks for your helps in advance.
Is this the original case for 1966 Mosrite Celebrity?
- Desert Surfer
Re: Is this the original case for 1966 Mosrite Celebrity?
Perhaps worth a try for 100 bucks.
The seller:
The seller:
...ouch, that hurts!I am parting out an entire 1966 Mosrite Celebrity. The guitar is 100% original and was in perfect working condition before I removed the parts.
Yes this is the early Mosrite Celeb. edition case. It is original.
- Desert Surfer
Thanks Bob and Veenture for your replies.
I will go for it. If I get it, it will be for my 1967 Celebrity III.
Do both type Celebs have the same body measurements (i.e. thickness) ?Desert Surfer wrote:it will be for my 1967 Celebrity III.
Yes, both types of the 60's Cleb's are the same measurements. Good luck!
Users browsing this forum: No registered users and 505 guests
