Mosrite Nokie model
MaxTib
Mosrite Nokie model
Does anyone know much about these guitars..? Seem like an old man version of the normal Ventures model with the contours etc.!
mosriteer
Re: Mosrite Nokie model
The Nokie models came in two flavors - the cheaper line with a flat headstock (that is a headstock surface that runs parallel to the fingerboard), non-adjustable pickups, no binding on the neck etc. The higher end (the "Anniversary" line) has a chambered body, neck and body bindings, adjustable PUs, custom colors - a pic of an anniversary model was posted a while back on this forum. Some of the Nokie Anniversary models from Mosrite also had a split pickguard and custom electronics.
Given the state of Mosrite at the time these guitars were produced, I am willing to bet that whatever parts were availabale got used in producing Nokie models that would not cleanly fall into either one of these two lines.
-Kanad
-Kanad
I'm putting together a Nokie model from parts I got from Curtis, you can check the progress in the "Projects ..." section of the forum.
Dennnis
Dennnis
Users browsing this forum: No registered users and 97 guests
