Dennisthe Menace wrote:Bill, That's a Nice Lookin Bass! You DONE GOOD! What kind of Case came with it?
drbassman wrote:First, I was fortunate that my Ric nut driver fits this bass too. However, the nut is recessed way down below the string nut. Is this typical Mosrite design? The cavity looks original without any "new" routing.
drbassman wrote:Second, there was no washer under the rod nut. That doesn't look right to me.
drbassman wrote:Third, is there some sort of metal sleeve (or jacket) around the truss rod? When I look down onto the top of the rod, just beneath the top of the wood (which surrounds the truss rod), I see what looks like brass around the rod. It's a bear to get light down there, so I'm not sure. Any ideas about how the top of the rod is finished on these basses?
dubtrub wrote:First off, why are you wanting to remove the trussrod? If there is nothing wrong with it, don't try and remove it.
Here is the link to Mel's project.
The trussrod will NOT come out the front. You should be able to access it from the rear of neck. There may be a plastic cover glued on the rear of the neck concealing the access hole. If you loosen the nut (or remove it), you should be able to use a 1/4" hardwood dowel and drive it out the rear.
Users browsing this forum: No registered users and 824 guests
