style" mosrite of burgundya"
ludobag
Postby ludobag » Sat Dec 03, 2011 1:58 pm
:lol: the title is a joke ;) in burgundy there is only wine
pics stolen from hallmark site
i am hesitate beetween 59 model
and the 60
this one is really beautifull
for the body i have a basswood blank (ithis blank may be first a télé, after a mustang an then now it will be a mosrite :twisted: i hope)
need to glue an hear cause it is little short in larger
i have find this pdf for a mosrite is it the same size than the one i want ? (with the slanted pick up)
it have a thickness of 45 mm at this time, but it will be less after some planing cause i have suck when i glue it! my clamps have made one part go a 1 mm highter than the other :roll: but on the topic for made a clone the thickness is 1 5/8 inch then in metrics it is 42mm
for the neck
i have some rosewood for the fretboard
and some mapple to make the neck but i haven't big blank like EFElliott use to make one piece ,my thickest is 35mm or 1, 37 inch then i think i will have to glue a headstock after a 7° cut or do a laminated
for the heel if i made a screweed neck it will be ok but if i want to glue it i will need to glue another piece of wood to have the mosrite tenon
for the nut i have seen in the topic of EFElliott the 0 fret and the nut fret it is really good idea and so easy ,and it will avoid to find a rare part i think
for the pups i don't know what to put ? i have time for that before i must find the more harder the trem ;) hope my friend will be ok to make 2 one for him and one for me :D
Postby KRamone27 » Sat Dec 03, 2011 7:29 pm
ludobag wrote:i have find this pdf for a mosrite is it the same size than the one i want ? (with the slanted pick up)
The answer to this question is no. That pdf was made by none other than forum member Bushers, he used his Mosrite MK5 to create it. I have a set of templates of a MK1 (style pictured above) I maybe able to trace and send to you.
ludobag
Postby ludobag » Sun Dec 04, 2011 1:43 am
thanks KRamone27
this week i will try to put this pics in inkscape to make a plan
with the information on the thread to make clone i found some mesurements
but i don't find the lenght of the head ?
and i must go to laminated neck cause my wood aren't thick for one piece ,i have seen a venture model with a laminated at fretted americana http://www.frettedamericana.com/details ... &counter=7
for sure it will be more easy if i ever seen one and note all the needed to ;)
on this
4. Neck volute thickness at the headstock is 1 3/8", referring to the area at the nut guide (side view).
with the thickness of fretboard or not ?
cause in fact it is really thick :shock:
Postby KRamone27 » Sun Dec 04, 2011 9:53 am
ludobag wrote:4. Neck volute thickness at the headstock is 1 3/8", referring to the area at the nut guide (side view).
with the thickness of fretboard or not ? cause in fact it is really thick :shock:
Maybe Danny will chime in as he's the one who had the guitar these measurements came from but I think the measurements includes the fretboard.
ludobag
Postby ludobag » Thu Feb 02, 2012 10:22 am
no big work in fact
i beguin to think to make my trem at work
i need to find some mesurement but it is not hard at first seen to make one
3 parts
first the bar
2 the plate
3 the part where the string are put where is the axis is
i will made all in aluminium machined (i have think to cast but to much dangerous in fact :oops:and i didn't have the thing to do it)
need to find 2 bearing for ,as i see bigby have needle bearing ,i don't know for mosrite trem ?
it will not be a clone cause it ll be machined then i will made it more simple
after i can beguin the wood working i will have laser cut template soon for
ludobag
Postby ludobag » Thu Feb 02, 2012 12:49 pm
i find lot of mesurement here :D
ludobag
Postby ludobag » Sun Feb 05, 2012 6:04 am
i find the mesurement of the base plate ,i will do a plan (in paper cause i am not good with computer)
but i need some other mesurements
can some one help me
need the high of the rocking part under the plate where the arm is fix H1
the hight of the axis between under the plate where the arm is fix H2 and the center of axis
and the offset between the the plate were the strings are fix and the center of the fixation of the arm L1
the all rest of the mesurement i will try to have with pics (more of them are just to make it nice and there not very crucial ;)
ludobag
Postby ludobag » Sat Feb 18, 2012 12:55 pm
i try to work with inkscape but it is hard :shock:
even if i pull the tongue :lol:
result is more or less at scale
then with the mesurement i found and the help of Mel (thanks so much) i could beguin my plan ;)
ludobag
Postby ludobag » Sun Feb 19, 2012 5:00 am
i have found one more clear there is some angular distortion but i will have a good base to start
cause is less or more at scale 8-)
Postby dubtrub » Sun Feb 19, 2012 8:34 am
ludobag, are you planning to cast the plate and rocker out of aluminum?
I've got a Moseley vibrato that I could make a drawing, I wouldn't know where to begin making a drawing using a computer. I would have to make a hand drawing with the measurements, photograph it and save it to Photobucket then display it here on the forum. It will be a process I could do when I have some extra time if no one else here on the forum can help you sooner.
Users browsing this forum: No registered users and 943 guests
