I have never had to remove a set neck before, and have heard of everything from steam to heat guns to soften the glue...can anyone here give me some pointers or things to avoid? The guitar is all mahogany...
olrnr
Sarah93003 wrote:Steaming is a good solution, but in my humble opinion, if you haven't done some pretty heavy duty guitar work this is not for a novice. Many set necks are also screwed together but you just don't see the screw and unless you know where to look wouldn't even know it's there. Some Gretsch set necks also have a hidden screw. I'll try to post a photo to illustrate.
panther wrote:Sarah93003 wrote:Steaming is a good solution, but in my humble opinion, if you haven't done some pretty heavy duty guitar work this is not for a novice. Many set necks are also screwed together but you just don't see the screw and unless you know where to look wouldn't even know it's there. Some Gretsch set necks also have a hidden screw. I'll try to post a photo to illustrate.
I agree Sarah, this is a tall order.
JimPage wrote:Hey, olrocknroller--
I took an eight-week 60-hour guitar-repair class about ten years ago, from a friend who was a highly regarded repairperson here in the DC area. The last three lessons were spent performing a neck reset on a early-1960s Gibson J45 of mine.
(...) So, while do-able, a neck reset on an acoustic guitar is indeed invasive surgery and not to be tackled without some consideration. If the guitar is, as you describe, a beater and a learning project, then full steam (pun intended) ahead!!! Please let us know how it turns out.
Users browsing this forum: No registered users and 295 guests
