Delta Blues amp
sleeperNY
Delta Blues amp
Postby sleeperNY » Sun Oct 09, 2011 7:54 am
Last night at the end of our gig I smelled that electrical burning smell coming from my amp. It played all night and I had no problems that I heard. This morning I took it apart for the first time after getting it and this is all that looked suspect to me. I couldn't smell any burning oder this morning but this cap is black' My question is, are there any caps that are black to start with? This is the first connection for the main power cord entering the amp.
Thanks for any info
Re: Delta Blues amp
Postby dubtrub » Sun Oct 09, 2011 8:28 am
Yes there are occasional black caps, and electrolytic capacitors can contain high DC voltages over 400 VDC that can stop your heart. Don't touch anything with your hand until all caps are discharged. Use a wooden chopstick to poke around under the hood.
Sorry Jim, I'm not familiar with the layout of that amp and I'm not seeing what you are referring to. There is a lot of information on the internet that should be able to help you diagnose the 'smell'. Type in a short question in your search engine and you should get some good starting points. Hopefully one of our more experienced techs will see this and provide your answer. Meantime try the search engine. Here's an example by typing in "Delta Blues burnning smell". http://forums.peavey.com/viewtopic.php?f=19&t=12377
oigun
Re: Delta Blues amp
Postby oigun » Sun Oct 09, 2011 10:40 am
I have a DB and if its more than a couple years old take it to a tech and let him/her check the tubes and caps. I did and the tubes where smoked and the El caps leaky he replaced them and my amp is better than ever!
sleeperNY
Re: Delta Blues amp
Postby sleeperNY » Sun Oct 09, 2011 3:51 pm
I bought it new in 04/2010, so I have had it for a year and a half. I may have to take it to a tech to have it looked at.
Danny the cap is just behind the blue wire and just in front of the green one. It is pitch black.
Re: Delta Blues amp
Postby Dennisthe Menace » Sun Oct 09, 2011 4:28 pm
Jim, Fender has a 5 year warranty on their amps, or have they changed that recently??... :?
Re: Delta Blues amp
Postby GattonFan » Sun Oct 09, 2011 4:28 pm
It appears that the cap's writing is still visible (in grey or white) - wouldn't that have charred to illegibility if the cap burned? Maybe I'm seeing things ...
sleeperNY
Re: Delta Blues amp
Postby sleeperNY » Sun Oct 09, 2011 7:19 pm
Fender still has 5 year warranties as far as I know. Peavey only has 1 year. This is just past it's warranty. Doesn't that sound just about right.
The marks you see on the cap are from me trying to clean it off.
Re: Delta Blues amp
Postby dubtrub » Sun Oct 09, 2011 7:46 pm
If Mr. Bill doesn't see this, send him a private message. He'll know what to do.
Re: Delta Blues amp
Postby Sarah93003 » Sun Oct 09, 2011 7:47 pm
dubtrub wrote:If Mr. Bill doesn't see this, send him a private message. He'll know what to do.
I was going to say the same thing! :)
Re: Delta Blues amp
Postby Dennisthe Menace » Sun Oct 09, 2011 8:37 pm
Me Threeeee.....Jim, the only thing that has me confused is you said you purchased it in
04/2010. So, if that's the case, I'd take it back to where you purchased it, and have them
check it out.....after all, it's still under warranty..... ;) .
Users browsing this forum: No registered users and 553 guests
