FritzCat wrote:Of course you should! Here's one way to do it without drilling any holes in case you change your mind and don't like it http://www.vibramate.com/vibramate-v7-lp-install.php
olrocknroller wrote:Most people find Bigsbys don't have a lot of range in the amount they change the note, which is fine if you only want a mild tremolo, but "dive-bombing" is definitely not on the menu with these trems. I have increased the range quite a bit by enlarging the back cross-shaft, but it still is pretty mild compared to more modern trems...
Sarah93003 wrote:If your Les Paul is an expensive model I'd give it a lot of thought before altering it.
Do you really use a tremolo a lot, or just trying to make the guitar look like Keith's?
For most of the music I play I don't really use the tremolo. I've taken the arm off of my Strat just to get it out of my way. On my Gretsches and Mosrites, I rarely use them unless I'm doing a particular Rockabilly tune.
vjf1968 wrote:Sarah93003 wrote:If your Les Paul is an expensive model I'd give it a lot of thought before altering it.
The Vibramate eliminates the need for any drilling. All you have to do is remove the tail piece and screws and replace that with the bracket and screw it in. Attach the Bigsby to the Vibramate and put it the whole assembly on the guitar. Secure the Bigsby on the strap button on the end. It is not permanent so if you sell the guitar its easily reversable.
All th parts that touch the guitar are covered in felt so your in no danger of scratching the top of the guitar.
Users browsing this forum: No registered users and 334 guests
