How to Make a Bass String Guide
riverboat
Postby riverboat » Sat Apr 02, 2011 10:12 pm
Here's what I want to make
1) First, you need a piece of brass (old toilet bolt will do)
2) Grind one side flat
3) Make 2 sides square and flat
4) Measure the original (mine was 1.57 inches)
5) Cut it off a little oversize
6) Grind it square
7) Glue it into a piece of wood
8) Grind it down. Every few seconds, I had to quench it in a can of water and sometimes reglue it
9) Grind it to a 3/16 radius
10) Make a fence for the bandsaw so the blade protrudes exactly the depth of the string slots (about 1/16 of an inch)
11) I painted it with machineist's ink and marked the string spacing with an x-acto blade
12) Cut the string slots, rolling the brass along the fence
13) I rechecked my measurements often
14) Round the edges, and buff it until it shines
15) I had some other things nickel plated, too
16) Here it is in place!
17) I made some out of aluminum, too
I also had to make a new pickup for it
But that's another story
Re: How to Make a Bass String Guide
Postby Veenture » Sun Apr 03, 2011 4:19 am
Keith, incredible DIY, thanks for sharing.
Postby GattonFan » Sun Apr 03, 2011 5:27 am
Very good information. All this DIY stuff is great!
Postby JimPage » Sun Apr 03, 2011 5:33 am
Thanks, Keith, for posting that. Fascinating.
Postby olrocknroller » Sun Apr 03, 2011 8:25 am
Nice tips for handling such a small piece of metal! I'm going to make a brass nut this summer, and this post will help make that job a lot easier! Thanks!
Postby MWaldorf » Sun Apr 03, 2011 10:34 am
Wow, that's great! Do you have pictures of the pickup build as well?
oigun
Postby oigun » Sun Apr 03, 2011 1:00 pm
That looks familiar :mrgreen:
did you use a regular bandsaw blade?
mikethemod1992
Postby mikethemod1992 » Sun Apr 03, 2011 8:08 pm
what did you use to grind down the brass? :) amazing work
riverboat
Postby riverboat » Sun Apr 03, 2011 8:56 pm
No, I didn't take pictures of me making the pickup because I learned how to do it on this website at viewtopic.php?f=20&t=3240&start=100
I also looked up pickup re-winding online. I made my winding machine out of an old wood lathe and a variable speed DC motor.
riverboat
Postby riverboat » Sun Apr 03, 2011 9:11 pm
To grind down the brass I started with a grinding wheel but most of it was done on my sanding disc. grind a little-drop it in a can of water-fish it out with some tongs-grind a little more-ect. Many times it got so hot that the super glue lost it's hold so I would re-glue it and drop it in the water harden the glue. Sounds like a lot of work but it's not really that hard.
Users browsing this forum: No registered users and 600 guests
