Bridge measurements
Bridge measurements
Postby KRamone27 » Fri Feb 18, 2011 1:45 pm
I had these written down somewhere but can't for the life of me find them. Does anyone have measurements for a mosrite roller bridge? I basically need the overall length of the bridge width and diameter of the saddles. Thanks, Kevin
Re: Bridge measurements
Postby KRamone27 » Sun Feb 20, 2011 8:35 pm
37 views and nobody has a tape measure?
Postby Sarah93003 » Sun Feb 20, 2011 9:02 pm
I don't have a roller bridge, but I have a non-roller bridge. Will that do?
Postby Veenture » Mon Feb 21, 2011 1:49 am
KRamone27 wrote:37 views and nobody has a tape measure?
I do...but not a Mo' :(
Postby KRamone27 » Mon Feb 21, 2011 8:07 am
Sarah93003 wrote:I don't have a roller bridge, but I have a non-roller bridge. Will that do?
It should work perfectly, I think the only difference is the saddles. Thanks Sarah
Postby Sarah93003 » Mon Feb 21, 2011 10:09 am
If you PM your email address to me, I'll make a sketch and pdf it.
The base of the bridge is 3 1/4" long by 13/16" wide. The sides are approximately 1/4" tall and scalloped. The material is 1 16" thick. I believe it is brass. The non-roller saddles are 5/16" diameter brass. The mounting holes are 2 25/32" on center. The bridge base is curved to match the radius of the neck.
Hope that helps!
Users browsing this forum: No registered users and 264 guests
