Having a go at building a Fuzzrite, a few questions
mikethemod1992
Postby mikethemod1992 » Sat Dec 25, 2010 6:02 pm
I have the Transistors, Resistors, etc that were described on Mr. Bill's list. Does anybody have any advice as to how big my perf board should be? I am following the schematic from fuzzcentral.
excuse my ignorance, but what is EBC? this is my first time attempting anything like this so i dont know what some of this stuff means.
Could somebody possibly post a finished photo of the guts of one of theirs? Thanks
mikethemod1992
Re: Having a go at building a Fuzzrite, a few questions
Postby mikethemod1992 » Sat Dec 25, 2010 9:13 pm
After a bit of research i answered the EBC question, but the perfboard dimension question still remains. And would it matter if I use Germanium transistors instead of the 2N3904s? Cheers
mikethemod1992
Postby mikethemod1992 » Sun Dec 26, 2010 8:19 pm
After pulling an all nighter, i've finally figured out all i need to know about wiring this project.
(simplified wiring chart, at least for me)
x4 470k resistors (1/4 watt but 1/8 watt and 1/2 watt should be fine)
x2 npn bipolar transistors (2N2222,2N3409,2N4401 and others)
x2 .05uf caps film or ceramic(original used ceramic and .047uf should work)
x2 .002uf caps film or ceramic (again ceramic for the original and .0022uf will work)
x1 500k linear taper pot
x1 50k audio taper pot
I ordered most of my parts from this website
http://www.fuzzboxworld.com/index.html
I ordered the ceramic capacitors from another source. And if the snow lets up tomorrow i'm going to go to radioshack and pick up the resistors,transistors, and miniboard.
Olav
Postby Olav » Mon Dec 27, 2010 3:37 am
You've been a busy boy Mike!
Looking forward to seeing you do this. Might have to go "Olav See, Olav Do" on it.
va' sa' du? va' hete' du?
my guitars @ LGTf
my 2011TDPRI entry
mikethemod1992
Postby mikethemod1992 » Wed Dec 29, 2010 7:37 pm
finally started!
the first one was a bit sloppy for my taste, so i started over
Postby Sarah93003 » Wed Dec 29, 2010 8:08 pm
Very cool!
mikethemod1992
Postby mikethemod1992 » Wed Dec 29, 2010 9:22 pm
I have most of it wired up, im going to go drill holes in the case tomorrow, so i can fit the 9V adaptor and finish this thing up!
mikethemod1992
Postby mikethemod1992 » Thu Dec 30, 2010 12:35 pm
Victory is mine
one of my volume control holes is a bit off, i think im just going to transfer it into a new box. Had a good time though, will deffo be building more of these!
Olav
Postby Olav » Thu Dec 30, 2010 2:24 pm
Taste?
my guitars @ LGTf
my 2011TDPRI entry
mikethemod1992
Postby mikethemod1992 » Thu Dec 30, 2010 2:33 pm
Olav wrote:Taste?
afraid not, i had to go to the local music store to test it. haha
