Hello everybody,
I want to build my own Mosrite ventures copy but im a bit low on cash. I was wondering, (besides originals) what would be the best pickups to put into the project. If not that, at least what would fit.Im a bit new to Mosrite in terms of specs. Cheers everybody!
Pickups?
- mikethemod1992
vjf1968
Re: Pickups?
mikethemod1992 wrote:Hello everybody,
Go to www.hallmarkguitars.com
Bob Shade's pickups are wound to Mosrite specs.
Re: Pickups?
Or, Eddy Elliott is selling Mosrite p'ups for @ $200 a pair ...
Re: Pickups?
Ed Elliott's pickups are great. Also consider M3 California pickups - they make a cool split coil model that can be switched full Mosrite output to a more P-90ish level.
saf
Re: Pickups?
not exactly mosrite specs. But eastwood hiflyer pups are dirt cheap and will give you more or less the desired look
Re: Pickups?
if you wanted to go real cheap, just get some generic p-90's, although it's not exact the same sound.
Users browsing this forum: No registered users and 560 guests
