How do you remove a factory polyurethane finish?
Postby Sarah93003 » Mon Aug 02, 2010 6:05 pm
I have a trashed out Gretsch guitar that I want to do quite a bit of modifications to, including repainting. It still has the factory polyurethane finish on it. I'm wondering if anyone here has ever done such a task and how you'd recommend it.
I've seen on the internet where some folks use a heat gun, but, they were doing a solid body guitar and I'm doing an archtop.
Suggestions?
PS: This is a project I really want to do myself. My guitar tech wanted me to let him do the hardest parts, but after waiting for a year I'm ready to just jump in and do it myself.
Re: How do you remove a factory polyurethane finish?
Postby dubtrub » Mon Aug 02, 2010 6:11 pm
Your choice is either going to be a heat gun or a thousand hours of labor and a ton of sand paper. The heat gun will play havoc on any binding and may even effect glue joints. Either way, I pity you.
I've heard that there is some chemicals used for stripping anodized aircraft aluminum that will work but I don't know what it's called.
Postby KRamone27 » Mon Aug 02, 2010 6:27 pm
I've seen guys on the strat-talk forum use the Jasco premium stripper to remove a polyester finish with great results but not sure it'll work with polyurethane. Maybe Aaron will chime in.
sleeperNY
Postby sleeperNY » Tue Aug 03, 2010 4:02 am
There are some great strippers at you local hardware store that will remove the poly finish. Thats the easy part, but do not let it get on the bindings as it will also eat them away. I tape over the bindings with 3/4 masking tape and after all the other paint is removed just sand the edges with a good sand paper. Stripper is not hard to use, just follow the directions on the can and have fun. LOL
Mr Pink
Postby Mr Pink » Tue Aug 03, 2010 4:35 am
It's a real pity there's no strippers at my local stores.
I know what you're thinking. "Did he fire six shots or only five?" Well, to tell you the truth, in all this excitement I kind of lost track myself.
saf
Postby saf » Tue Aug 03, 2010 5:58 am
I did it a couple of time with a heat gun. But those were solid bodies. I don't know if the heat gun is a very good idea on a hollow.
Otherwise it's sanding but men that's one heck of a job.
Postby GattonFan » Tue Aug 03, 2010 7:50 am
I wouldn't try a heat gun on an archtop, may burn it up (scorch marks happen on solid bodies, imagine what the heat woould do to thin wood) - unfortunately, stripping would be as tedious as sanding if there's binding - so sanding is the best option, if you're not in a hurry. Just take your time, grab a block, and start sanding.
Postby oipunkguy » Sun Aug 08, 2010 7:21 am
hey sarah,
removing poly is my most hatred part of guitar refinishing. it's awful. but here's a few things to check out. how thick is the finish? the poly finishes that came of guitars like jackson and fender in the 1990's were extremely thick. so much in fact, i once thought the bodies were dipped in a vat instead of sprayed still I wonder about that to this day ;) :lol:
In the case of a 90's jackson i worked on, the finish was actually thicker then the top wood on the guitar! :roll: if your guitar's finish is this thick, i really would avoid a refinish unless it's really really really important to you.
usually modern guitars that are done in poly are done right, and the finish isn't too thick. my 1995 epip LP custom that i refinished it didn’t have a too thick poly finish either. if your guitar’s finish is somewhat thin, if it was me, I would sand it off. If your not sure the thickness, places like screw holes will give you some clues.
just be careful not to remove any binding, on some guitars this stuff can be extremely thin (i'm talking about things like the abalone multiple binding you find on guitars like a martin of taylor for example)
and be aware when you sand it, you will be making a TON of dust, and cover up anything in the room that you don't want covered in poly dust, and I would use a face mask too, just to be on the safe side. And have fun washing the poly dust out of your hair later on ;) it’s that bad, trust me.
you can use a heat gun too, but follow the caution danny mentioned, because he's right on with what he said. also a heat gun can put a burn in the wood if you aren't careful. one other thing that a bit annoying is removing poly with a heat gun is you really can’t use a plastic scrapper to remove the finish, cuz the plastic will just melt too, so really your only other option is using a metal scrapper. if you do use a metal scrapper, be very careful not to go into the wood itself. it's not hard to do even on a flat area, and getting the poly off the sides of a strat body is hellish. If you do go into the wood it’s not the end of the world, but now you have to sand out these area, and add some wood fill to cover up your mistake. And then prepping your body for the refinish will now take you a lot more time. When the finish is completely off the finish always try to get the body as perfect as you can with no dings or makes in it before adding a new finish. You will thank yourself later on.
if you get pass the color coat on the guitar, and if you still have the undercoat to go, you can stop from there. i've had no issues with having a poly undercoat, and a nitro top coat. it's usually not what i prefer, but it can work for ya. Sometimes it’s even better, in the case of a swamp ash body, since nitro sometimes has trouble sticking to this wood, and a poly undercoat will keep it a little more stable.
Then there are times when you might be just better off sanding the poly finish down some, and just add nitro on top of it. again, not a preferred choice, but sometimes this is your only realistic option. I did this on the headstock on my LP custom, since I didn't want the headache of redoing the headstock inlay, in case I accidentally removed it.
if you need some guidance, just gimme a call sarah. you know my number :D
good luck!
Postby oipunkguy » Sun Aug 08, 2010 7:29 am
oh, by the way that stuff to remove poly is called "aircraft remover". although i've never used it, so i dont know if it works. there's poly strippers out there too, but keep in mind this stuff is pretty much used on furniture, and the poly on furniture is paper thin compared to a poly on a guitar. in the case of my 95 strat body that was finished in poly, I enclosed in a stripper tub, covered in stripper for a week, and it barely removed any finish. so i would avoid trying it, honestly use the stripper just made a big mess to clean up. not only i had a guitar with the finish still intact, but now i had all this dried up caked on stripper sludge inside all the cavities on the guitar. it was a royal pain to remove all that stuff.
Postby Sarah93003 » Sun Aug 08, 2010 8:02 am
Boy! Maybe I'm going about this all wrong. It doesn't matter if I put a Poly finish back on and actually I wasn't even thinking whether I'd put Nitro or Poly. I just want to change the color. Can I sand the red poly finish to the point where I can change the color to and off white if I keep it Poly?
Users browsing this forum: No registered users and 499 guests
