For those that do not know, when a personal message is sent to a member, a small pop up window appears on the screen notifying the member they have a message. In order to receive the 'pop up' the member must have their home computer set to receive pop up's from the forum otherwise known as 'notify me when a new message arrives'. If you are not receiving the 'pop up' window notifying you of a pending personal message and would like to use this feature, you can use the following procedure to set up your computer. Go to 'Tools' then 'Internet Options' then 'Privacy' then "Settings'. From there you enter the website you would like to bypass popup blocker and hit the 'add' button. You're done.
BTW, this process does not effect your normal popup blocker settings for any other sites. If you need further assistance contact me via pm.
Pop up window for PMs
Users browsing this forum: No registered users and 141 guests
