Mosrite Celebrity Double Neck
Postby Sarah93003 » Thu May 27, 2010 7:49 am
I put this thread in this category as I have never heard that Semie made a Celebrity double neck. I've often wondered why that is. It seems to me it would have been a straight forward project for him. I think it would be a great guitar. It would be lighter than the solid body versions and I think it would look pretty cool.
As I've daydreamed about such a guitar I decided to ask my friend who is so good with Photoshop if he could render such a guitar. I would do a few things differently such as the layout of the pickups (I would do typical Celebrity style) and I may have selected the Moseley half trem for the six neck or no trem at all. I'd also use the Celebrity pickguard configuration. There would, of course, have to be the correct control layout as well. I would likely use the humbuckers from the seventies on the 12 neck, and the single coils on the 6 neck. Or a coil tap arrangement might be an option. I'd have separate tone and volume controls for both necks with a master volume on the treble side horn. On the bass side horn I'd have a neck selector switch. But I think you can get an idea of what such a guitar would look like.
I'm going to try my hand at making an archtop guitar so maybe this will be my first project. We shall see!
Re: Mosrite Celebrity Double Neck
Postby dubtrub » Thu May 27, 2010 8:32 am
It certainly looks interesting but those necks sticking out there on a hollow body would get mighty heavy pulling on your shoulders.
Postby Veenture » Thu May 27, 2010 11:12 am
My eyes popped when I saw the pictures ...and then I started reading about your dream Sarah, wonderful. I was thinking, for a doubleneck Celeb. you'd need to have a lot of bracing inside the body to keep two necks firmly in position for as long as an average guitar life lasts (whatever that may be) ;) But I'm sure you'll come up with something yet!
Postby Dennisthe Menace » Thu May 27, 2010 11:30 am
Cool concept Sarah, but I got to agree with Danny. You are going to have one heck of a
muscle build up with your left arm just in supporting the 2 necks :shock: .
Postby Sarah93003 » Thu May 27, 2010 11:47 am
Veenture wrote:My eyes popped when I saw the pictures ...and then I started reading about your dream Sarah, wonderful. I was thinking, for a doubleneck Celeb. you'd need to have a lot of bracing inside the body to keep two necks firmly in position for as long as an average guitar life lasts (whatever that may be) ;) But I'm sure you'll come up with something yet!
One solution might be a neck through design terminating into a tailblock. That way there could be attachment points at the neck block as well as the tailblock. The extended neck and tailblock would add additional weight to the bout and may help balance the weight of the double neck. I've strapped up a few double necks and they always seem neck heavy, some worse than others. Yesterday I played the new BC Rich double neck and it is very neck heavy. It seems to me that they are not putting the strap pins in the right location. I think if the top strap pin was placed below center and the rear strap pin was placed above center that it might help some.
The other thing I would do is some parellel bracing or trestle bracing of the top. The first Celebrities had very thick side rims at 5/8" that were solid wood and not plywood. Later he went to 1/4" plywood sides. For a double neck I think I'd go with the solid 5/8" sides.
I've played the Gretsch Duo Jet double neck and it weighs about 14 pounds. I played it for 1 1/2 hours strapped and standing and it was not bad at all. It has the best balance I've encountered so far. If I could keep this one to that weight I think it would be okay. I wonder how much a Maphis double neck weighs?
Of course, time will tell as I think all of this through and actually give it a go!
Postby MWaldorf » Thu May 27, 2010 11:54 am
The Ellison Maphis custom is well balanced, but it's got a solid body and an octave neck, so the weight distribution is different. You might consider a semi-solid design with a single solid block down the middle under both necks.
Overall I think it's a cool idea and if it's your dream then you should go for it. If you haven't already, look over Terry's build photos on the TNM guitar website. I think that would give you an idea of what's involved.
http://tnmguitars.com/
Postby Sarah93003 » Thu May 27, 2010 12:19 pm
MWaldorf wrote:The Ellison Maphis custom is well balanced, but it's got a solid body and an octave neck, so the weight distribution is different. You might consider a semi-solid design with a single solid block down the middle under both necks.
Thanks Mel! Where do I find the build page?
Postby dubtrub » Thu May 27, 2010 12:22 pm
Sarah93003 wrote:Thanks Mel! Where do I find the build page?
Boy! Someone is sure missing a lot of stuff on this forum. :shock:
Click on the link Mel posted or clik on Terry's signature logo. You have to scan through his website for photo's. ;)
Postby Sarah93003 » Thu May 27, 2010 1:33 pm
I've been all through Terry's site before and today. I see lots of beautiful photographs but I don't see any build photos. Obviously, I'm overlooking something.........
handbrake
Postby handbrake » Thu May 27, 2010 2:14 pm
Sarah93003 wrote:I've played the Gretsch Duo Jet double neck and it weighs about 14 pounds. I played it for 1 1/2 hours strapped and standing and it was not bad at all. It has the best balance I've encountered so far. If I could keep this one to that weight I think it would be okay. I wonder how much a Maphis double neck weighs?
11lbs. if I remember right. I think that's what mine weighs in at.
Users browsing this forum: No registered users and 660 guests
