Carbon fiber rods in neck?
Johnny
Postby Johnny » Mon Dec 07, 2009 5:35 pm
Would it be possible to strengthen a Mosrite Ventures II (slab) neck with carbon fiber rods? Would they fit in there, the neck is very narrow and thin after all.
TerryTNM
Re: Carbon fiber rods in neck?
Postby TerryTNM » Mon Dec 07, 2009 6:51 pm
Carbon fiber rods are installed during construction. They need to be securely glued into a provided slot to provide the rigidity.
-Terry
Johnny
Postby Johnny » Tue Dec 08, 2009 12:22 am
TerryTNM wrote:Carbon fiber rods are installed during construction. They need to be securely glued into a provided slot to provide the rigidity.
-Terry
Yes I know. I was just wondering would they even fit.
Postby oipunkguy » Tue Dec 22, 2009 12:07 am
I think unless you use a bass or use very high gauged strings on an acoustic, carbon rods would be a bit overkill. some of the martin acoustics from the 80's have bad warping in the necks that could be fixed by adding carbon rods. But despite the thin necks on mosrites, there necks are usually straight as an arrow in my experience.
a main reason for using carbon rods in a bass neck is to prevent the wood from twisting opposed to front or back bow. twisting might be possible on a bass neck when adjusting the truss rod, but I don't run into this problem much for guitars, there's just not enough tension on the neck.
if you are concerned with the neck, sometimes using a two way adjustable truss rod is more preferable then the one way adjustable rods. I have had more issues with keeping les paul necks straight then any of my mosrites, because mahogany is a softer wood then maple, and if you have a 2 or more piece maple neck, you should be more then okay. just my two cents 8-)
Postby oipunkguy » Tue Dec 22, 2009 12:09 am
but the short answer is yeah it would probably fit. :lol: :lol: :lol:
Johnny
Postby Johnny » Sun Dec 27, 2009 8:45 am
oipunkguy wrote:but the short answer is yeah it would probably fit. :lol: :lol: :lol:
Thanks.
Users browsing this forum: No registered users and 55 guests
