TKL - Squeaky handles - SOLVED!
Postby MWaldorf » Mon Nov 16, 2009 7:26 pm
Has anyone experienced squeaky handles on their Hallmark / TKL guitar cases? I've got a couple and both go "squeak squeak squeak" as I carry the case anywhere. Maybe it's just me, but I'm ready to cut the handles off and put on old-style leather buckle handles.
Re: TKL - Squeaky handles?
Postby Veenture » Tue Nov 17, 2009 2:26 am
How strange...no problem here (mine's the crocodile motiv). Are you sure it's the handle... :mrgreen:
Surely a wee-drop-a "Three In One Oil" would cure the ailment?! ....and otherwise a mouse trap???
Hey Mel, sometimes one of my guitars goes "quack, quack, quack"............but that's because it's a Strat :D :D :D
Good luck pal ;)
sleeperNY
Postby sleeperNY » Tue Nov 17, 2009 6:40 am
Mel, I have 2 Hallmark cases and one has the plastic handle and the other has a leather handle. I don't have any squeaks in either of them.
If I were you I would drill a small hole in both ends of the handle and install grease fittings and make sure it is full of grease. That should solve the problem. LOL
Postby Dennisthe Menace » Tue Nov 17, 2009 6:47 am
Castrol Motor Oil...Guaranteed for 3,000 Gigs..........uhm.........miles........ :roll:
Postby MWaldorf » Tue Nov 17, 2009 10:01 am
Hmmm. Mine have the plastic handles. I've got 3 in 1 oil handy, I'll give that a try.
LOSTVENTURE
Postby LOSTVENTURE » Tue Nov 17, 2009 10:13 am
My alligator has the squeaks too. Let me know if any of the "oil" products work.
And I discovered that if you leave the guitar at home (maybe accidentally), that the empty case doesn't sqeak near as bad.
Don
mark1
Postby mark1 » Tue Nov 17, 2009 1:02 pm
Try getting a little vaseline or chap stick inside between the handel and the pin that goes through it.You can use a q-tip or a toothpick.Chapstick will last longer because it it thicker. I have a Jaguar from 65 with the same problem and it works every time :) Let me know how you make out.....using oil can make a real mess!
jnslobaugh
Postby jnslobaugh » Wed Nov 18, 2009 12:29 am
graphite would be my choice, its dry and wont collect dust and debris.
JEFFREY S. LOBAUGH
Jazm
Postby Jazm » Wed Nov 18, 2009 6:36 am
Mel, if your 3 in one oil is a CLP gun oil product, you must be careful and know that CLP can eat/dissolve some types of plastic!
Other that that, you can try with a light coat of grease, but use very little so that it wont gunk up your handle. Like Jnslobaugh said, graphite might work better though.
Epiphone Casino '65 Elitist
Rickenbacker 360/6
Fender Jaguar '62 Reissue
Danelectro '63 "Silvertone Reissue"
Fender American Vintage Press Bass '62 Reissue
Vox AC30TB & Roland Jazz chorus 120
sleeperNY
Postby sleeperNY » Wed Nov 18, 2009 7:31 am
I believe that Dennis and I were just having some light hearted fun on how to solve the problem.
Users browsing this forum: No registered users and 437 guests
