more mosporn...
connie_mack
more mosporn...
i figured as a new member i should post a pic of my new girlfriend....
Re: more mosporn...
You know how to pick 'em. She's a real beauty. When did you pick her up?
connie_mack
Re: more mosporn...
two weeks ago....
Re: more mosporn...
Wow! She's gorgeous. Congratulations!
Re: more mosporn...
She's got the best curves in all of guitar world...
- 64sunburst
Re: more mosporn...
She's real purty!
Re: more mosporn...
how does she sound?
connie_mack
Re: more mosporn...
she sounds great.
sort of.
turns out there was a problem with the pick up switch. i put a new one in and i'm not getting full output from the bridge pick up(this was the case before the switch replacement and i thought that replacing it might fix that problem. it didn't). i am going to take it to a builder acquaintance who had done the same for a vintage bass of mine and find out where the problem lies.
hopefully it's just a wire or bad connection solder joint. we'll see.
sort of.
- sleeperNY
Re: more mosporn...
I hope it is an easy repair. If it turns out to be in the pickup I would recommend you only sent it to E.F.Elliott for repair. He can repair it and make sure it retains that Mosrite sound.
connie_mack
Re: more mosporn...
thanks jim,
i will keep that in mind. the dealer i bought it from has, so far, stood behind their sale and are working with me. if it comes to a repair, i will suggest that, unless they have a better idea.
i checked out your band website.
sounds country. which some people don't even know what that is anymore. sad. although i will say that you really could use a steel guitar. but then i'm a bit biased in that department. and i'm sure you also probably agree.
nice job on your mosrite refin. she's a beaut.
c
c
Users browsing this forum: No registered users and 137 guests
