Mosrite string guides
- bluther
Where can I find the brass string guides that are used on Mosrite guitars? Also I have never built a zero fret neck before. How much taller is the 'zero fret", if any, than the others?
Re: Mosrite string guides
Sorry, not a guitar tech, (don't have the proper measuring tools) but I observe that the frets on my Hallmark 60 Custum stand 1 mm tall [thickness: 2 mm] whereas the zero fret measures 1.2 to 1.3 mm in height [thickness: 2.5 mm]. I took both measurements from the surface of the fingerboard up. (the rest is submerged
Bob Shade of Hallmark Guitars may be able to supply you with a metal string guide but not sure about a brass one. (my Hallmark 60 Custom has a chromed one and the string spacing is a tad wider than the Mosrite).
Owners of the real McCoy (i.e. Mosrite) will no doubt be able to tell you more.
Hope this helps.
Hope this helps.
- bluther
Thats exactly what I needed to know
Appreciate the info
Cool. Hey bluther, if you've got any pics of your build/mod, we're all ready to 'devour' them!
on my semie mosrites the zero fret is the same size as the rest, on my japanese reissue, the zero fret was never dressed, so it sits slightly higher. more importantly as long as the string guide behind your zero fret sits lower then the zero fret you should be fine as long as you don't get any fret buzz.
- bluther
Thanksagain. I will post what I've done so far on my build Friday or Sat.
raykozi
Andy Moseley, Semi's brother, sells original round or half-round string guides. They are on Ebay quite often for around $10.00. Contact him at mosriteno1parts2@bellsouth.net and I am sure he will accomodate you.
- bluther
I contacted Andy and will have one from him in a week or so. Thanks for the info.
- bluther
Received 2 string guides from Andy Moseley
One is half round the other is quarter round.
One is half round the other is quarter round.Return to “Mosrite & Clone, Projects, Parts & Accessories Q&A”
Users browsing this forum: No registered users and 54 guests
