strings gauge-Ranger-Excellent
brunob
Postby brunob » Sat Mar 28, 2009 4:21 am
I put some 0.10 on the Ranger,but I wander to go 0.11 ,are there no problem.
The E slot seems to be made for 0.10.
are the -excellent-different stuff ?
thanx Bruno :twisted:
FritzCat
Re: strings gauge-Ranger-Excellent
Postby FritzCat » Sat Mar 28, 2009 9:03 am
I put 11's on my Excellent and like it better than 10's. I did have to play around with the spring, as the higher tension would pull the arm too close to the body for my liking.
brunob
Postby brunob » Sat Mar 28, 2009 9:15 am
which spring size will be good for 0.11?
Chemo
Postby Chemo » Mon Mar 30, 2009 12:11 am
brunob wrote:which spring size will be good for 0.11?
The original spring that came with my Ranger is just fine with 11-set. You could just try & change the strings and see how the arm settles.
It will be a good idea to do this before you take your guitar to the pro, so you'll have the setup made for the right gauge... ;)
Users browsing this forum: No registered users and 437 guests
