Semi - Mosrite?
Re: Semi - Mosrite?
Postby MWaldorf » Fri Dec 19, 2008 11:51 am
Well gang, I've been busy busy busy with my guitar. Here are the updates:
First, the search for a proper trust rod ends. The bent rod that came with the guitar never worked properly. It had more tendency to twist than bend and wasn't easily adjustable. My first attempt at a replacement was a Stew-Mac double action rod, but as it turns out, this won't fit. Thankfully, I found the LMI standard rod http://www.lmii.com/CartTwo/thirdproducts.asp?CategoryName=Truss+Rods%2FNeck+Parts&NameProdHeader=Truss+Rod+%2D+Standard+welded+end which is very similar to the stock Mosrite rod, and fits like a charm. First a picture of the three rods, LMI on top, hokey bend rod in the middle, and Stew Mac on the bottom.
Here a close up of the threaded ends of the rods.
Here, a look at the finished installation.
Next I wanted to fix the over-sanding I did in the neck pocket. I got a wooden shim at my local hardware store and sanded it as thin as I could. Then I glued it to the side of the neck pocket, using this high-tech apparatus to keep it in place.
Here you can see the shim, shaped and sanded.
The neck pocket is much tighter now, and actually makes contact with the neck on all three sides.
Re: Semi - Mosrite?
Postby MWaldorf » Fri Dec 19, 2008 12:00 pm
Next, a day of painting! It had been my goal from the start to fill out the sunburst on this guitar. I have very amateur finishing experience, so I decided to go with re-ranch sunburst aerosols. Their sunburst set includes three paints, a yellow, a "three-color edge" and black. The idea is to first spray the yellow, then the black around the sides, then the three color edge, which is a brown with red tinit. To see if it was worthwhile, I first bought a can of the three color edge to see how it works.
First a picture of the back of the guitar as I got it. I taped over the control cavity to protect the electronics.
After a few passes of paint. It goes on very lightly, which makes it forgiving to an amateur like me. Of course, by this time I noticed that the tape on the control cavity was getting painted too, and thereby leaving an edge, so I took off the tape and stuffed some paper towel in the cavity.
Here's the result of an entire can of three color edge. It looks nice, but the transition from the black painted around the side to the brown/red is very obvious, particularly in direct light. At this point I realized a) I can do this, and b) I'll need the full kit to do this right. So I ordered more paint from re-ranch.
Re: Semi - Mosrite?
Postby MWaldorf » Fri Dec 19, 2008 12:06 pm
While I was waiting for the paint to arrive, it was time to brighten up the moseley plate. I had buffed it with a demel, but wasn't able to get a real shine to it, so a friend who restores vintage scooters (lots of polished aluminum) offerred to help me get it together.
Here's the plate as I had it. I bolted it to a plank of wood to make it easier to handle on the buffing wheel.
Here's buffing in action. Note that in addition to using the buffing wheel, we used a polish called "SIMICHROME" with a rag. This polish is pretty amazing!
Here's the polished plate compared to the chrome on my friend's motorcycle.
Here's the plate with the chrome vibrato parts. Now it's in the same league. I expect it will tarnish with time, but a little simichrome when I change strings ought to maintain the shine.
Re: Semi - Mosrite?
Postby GattonFan » Fri Dec 19, 2008 12:19 pm
Wow, Mel - Looking very nice. Just be sure to pour on the clear lacquer, then let that nitro cure properly - it's looking like a first rate guitar. I think I'm going to order one of those truss rods ... you guys have been kind of trail-blazers for me ..
Re: Semi - Mosrite?
Postby MWaldorf » Fri Dec 19, 2008 12:24 pm
Finally, the paint arrived, and coincided with a couple of days of nice weather! Here are the re-ranch paints I got. Note that I didn't buy the yellow from the sunburst kit as the guitar body already had the yellow base. I bought black, three color edge, clear, and Fender Neck Amber, which I used when finishing the neck.
So, picking up where I left off, I wanted a smoother transition from black to red. I made a cardboard trace of the body and cut out a rough of the area where I didn't want black. Holding this an inch or so off the body while I sprayed the black allowed me to protect the center of the burst without having a solid edge to the paint. I held the can over the center of the body and painting in an outward direction, the same way I did the three color edge.
Here's the result on the back. I got the mask a bit too close to the body on the top curve so the line there is more solid then I wanted, but decided it was't worth the effort to sand it out and do over. I shot a couple of coats of clear and let it dry.
While the body was drying I taped off the neck fretboard and got it together. First I sprayed two coats of Fender Neck Amber, and then about half a dozen coats of clear. Keep in mind, I laid the paint on heavy, not thin the way you're supposed to, mainly because I'm impatient and lack subtlety.
Here's the neck with the tint and clear coat.
After the body dried, I took on the front. Here's the body as I started.
Here's the body with the mask on top.
After the first round of color. Note that on the top, the german carve goes all the way around, except at the inside of the horns. So. without thinking, I used the same positioning of the mask as over the carve, and got a really thick band. I should have stopped and sanded it out, but being in a rush, I decided to just do a thicker band of black.
Here's the thicker band. On the positive side, the dowel repair is pretty well masked.
After the black I shot more three color edge to smooth the transition. Where the three color edge is a very forgiving paint as it goes on very light on each pass, the black is very heavy and comes out dark on a single pass so you have to be very careful with it. I imagine that with a proper air brush you can get more control on the black, but I did what I could.
At the end of the day I shot a bunch of clear coats on the front of the guitar to prep for buffing.
Re: Semi - Mosrite?
Postby MWaldorf » Fri Dec 19, 2008 12:32 pm
Next I wanted to give the guitar a serial number. I got some letter punches on ebay, and gave it a go. Very importantly, I didn't want in any way to obfuscate the fact this is a parts-rite, so the stamps incorporate that. Since the body and neck were already stamped "C93" which I believe denotes parts that went to Canada in 1993, I made the serial number C9308 - ie it's a C93 guitar made in 08.
Here's the SN stamp. Pretty good, except I hit the 8 a bit hard and made a nice divot. At least you can see the eight in there.
Next I put a date stamp on the neck heel. I wanted a stamp that could be seen simply by removing the neck pickup. The stamp reads DEC 2008, for the month of final assembly.
Next, in case that would be too vague, I wrote a note on the inside of the control cavity cover.
On the next sort of nice day (no rain but cold) I buffed the body. I used meguiars polish and a drill bit buffing pad attached to my power drill. After a couple of passes it was close enough to shiny for me, and I assembled the guitar.
Here it is assembled as of last night. Here's the front:
Here's the back.
The front came out a lot darker than I had hoped; I was aiming for a burst more like the back. I'm going to try to live with it for a while and if it still bothers me come spring I may re-finish the front, hopefully having learned something from this time through!
Re: Semi - Mosrite?
Postby GattonFan » Fri Dec 19, 2008 12:34 pm
I really like that burst - and you're right about the ReRanch nitro - it is really forgiving, and easy to work with. Don't you just love these projects??? Everybody needs a hobby!
64sunburst
Re: Semi - Mosrite?
Postby 64sunburst » Fri Dec 19, 2008 2:02 pm
Wow, nice job! Quite a project. Even tho the front came out darker than you planned, I kinda like it. Have fun playing it.
Byron
Re: Semi - Mosrite?
Postby dubtrub » Fri Dec 19, 2008 2:41 pm
Looking good, Mel.
Are you ready to scratch build one yet? ;)
Re: Semi - Mosrite?
Postby MWaldorf » Fri Dec 19, 2008 2:53 pm
dubtrub wrote:Looking good, Mel.
Ha! If I had some reasonable woodworking tools I might consider it, but I think I'll stick with this one for a while. I've learned a heck of a lot in the process on this so it would be a shame not to gain from the experience with another instrument. At some point I might want to make a body more like the Mark I, as seen below, but with a few circuit adjustments (a tone control and a volume bypass switch) When the time comes, I may have to enlist your help...
Interestingly, while the finish on my VIII isn't what I had hoped, it looks a lot like this VIII from Michael Mark's page:
Users browsing this forum: No registered users and 71 guests
