style" mosrite of burgundya"
ludobag
Postby ludobag » Tue Aug 14, 2012 1:48 pm
after a big headach seems to be good :shock:
the plan now seems to complete i have some hard time to find where miss some mm
now the neck is like dubtrub spec 28 1/8 ou 714 mm
on the overall lenght miss some mm again
i am at 1008 mm the body is shorter like 5mm in lenght need to allonge it a little and miss the lenght of strap lock (between 10 or 15 mm )
then 1008+5 mm +15= 1028 mm for 1031 mm ;40 5/8 seems to be good cause i haven't one under the hand :lol:
another thing i must do is the neck plate to see where the hole are located ;) it will avoid the hole not in the neck :lol: and tomorrow i will beguin my template :D
need to replace the pups and i angle the neck pick up with an angle 15 °it is written nowhere ? or i haven't find the answer then i have copy a picture :oops:
i have take the mesurement of ring by motiersbad,tanks a lot it help me to make fit all this little world
the correction made my eraser is out of order then like a teatcher i have rewritten in red :lol:
the neck more long in the neck pocket
and second correction the headstock more long with the string guide at his place and the fretboard more long too
fret ZERO string guide 1/4 inch string guide 1/3 inch and fretboard before string guide 1/8 inch
this one just for fun :lol: with the blank for the guard
sorry for crappy pics my camera didn't like garage light :oops:
ludobag
Postby ludobag » Wed Aug 15, 2012 3:24 pm
no much time to do , cause i have a dilemn about the headstock and i spend much time to look at pics to have the answer ;)
template ready to be saw
for the body in 10 mm it will be the final cause i haven't much more 3mm and i am too lazy to go to buy it :oops:
guard in 3 mm pretemplate after it it will be made i will recopy it on mdf 10 mm with the router but it avoid a long sanding like 10 mm needed
neck template upper in 3mm will be copy on 10 mm after and side view in 3mm
i have a question about the side view for me no need a big template cause the neck will be band saw not routed on the side (i haven't bit long for that in fact )it will just be a help for tracing on blank ?
then headstock dilemn :ugeek:
the headstock i have drawn don't please me ,miss something and i think i have find
today*
and yesterday
*i have change the position of the headstock in the blank more low and make a nicer volute
Do you think it is better ?
and with the help of my assistant i have choose my fretboard blank(not much present this days but today it rain :lol: )
the 2 first are indian rosewood
the 2 after are indian rosewood better grade
and the 2 last are macassar ebony
which one do you prefer ?
mikethemod1992
Postby mikethemod1992 » Thu Aug 16, 2012 4:40 am
I bow in shame at your amazing build :P. You and Oigun need to stop being so brilliant
ludobag
Postby ludobag » Thu Aug 16, 2012 5:32 am
thanks ;) but i am a amateurish not a pro
Oigun is far ahead
but it try to do better each time (sometimes it is not working like i want ,for exemple my XII neck is the second cause the first i have suck :oops:and i have prefer redo one instead of continu cause it will be really long to put all in the right way ,moreover something who is starting bad doesn't go better sometime cause of the lack of straight reference,need lot of jig and without precise machine the factor chance (or murphy s law :lol: ) become highter)
i find this pics
then if you extend the head you see it cross the second fret then my second placement is much better
TerryTNM
Postby TerryTNM » Thu Aug 16, 2012 8:15 am
You put amazing thought into your process. If I might offer my own observations on the transition from the neck to the headstock. When making that transition on any neck I build I never start the volute until after the zero fret. I don't think the volute should increase the neck thickness at the 1st fret. -FWIW -Terry
ludobag
Postby ludobag » Thu Aug 16, 2012 8:25 am
thanks Terry ;)
is it the way i do too but if i want vintage correct :mrgreen:
in fact mosrite neck are very complicated (the all guitar too in fact)
and like i said i haven't one in hand just pics for réference and as i see necks have big volute but like you said volute before 0 fret is not really confortable
i am at this point only 2 hours with my little band saw :o it doesn't cut straight and it is really hard to follow a lign (i have seen the blade isn't set up well ,need to modify some parts to have more tension on the blade :| )
hopefilly it is only basswood ; i have my neck to resaw too but i will do by hand with my japanese saw cause in my blank (60 mm thickness) i can avoid lot of waist wood if i resaw and have a fender neck (20 mm thick)blank if all come as i hope for sure
ludobag
Postby ludobag » Thu Aug 16, 2012 10:25 am
then i have rework this volute
it beguin just near the middle of first case if it go more than the fret 0 i loose the mosrite style :|
for me look cool but we see it really after carving :lol:
ludobag
Postby ludobag » Fri Aug 17, 2012 8:58 am
then i try to resaw my neck
but it sucks my band saw deviate too much :evil:
then i have this
hopefully i saw it in time
then i have the mosrite neck
and in the other parts
a fretboard for guitar or bass normally 7mm mini after planing
a bloc of 320 x 74 X 30 mm of thickness
and a waist part
that bad that my band saw deviate so much i could have a neck blank in the other part if all go wright
ludobag
Postby ludobag » Fri Aug 17, 2012 11:17 am
seams for the fretboard
it is hard when you have don't touch a plane for a long time :o more over this mapple is flame then only little chips cause if not the fiber scratch ;)
TerryTNM
Postby TerryTNM » Fri Aug 17, 2012 6:31 pm
Do you have a drill press? There's a handy tool called the Safety Plane that could level out the back of the neck among other things.
http://www.stewmac.com/shop/Tools/Planes/Wagner_Safe-T-Planer.html
Users browsing this forum: No registered users and 459 guests
